Pre-Wiring
Discussion in '3rd Gen Tundras (2022+)' started by Novotz21, May 6, 2022.
  1. May 6, 2022 at 10:17 AM
    Novotz21
    Novotz21 [OP] New Member
    Starting this thread as a place for us to post what these trucks are pre-wired for (e.g., Discovered that my XX Trim has wiring for the OEM Fog Lights, although it did not come with it) I know a few of us are struggling with this, so lets document what we are seeing. Some areas that I am interested in are:
    1. Fog Lights
    2. TRD Pro Light Bar
    3. Tailgate Bump Switch
    4. Cab power outlets in rear seat
    5. Bed Power Outlets
  2. May 6, 2022 at 10:19 AM
    joescho
    joescho New Member
    Joe
    Scranton,PA
    2024 Supersonic Red Platinum
    I installed the OEM Dash camera. The pigtail is in the headliner.
    Novotz21[OP] likes this.
  3. May 6, 2022 at 10:20 AM
    Novotz21
    Thanks, what trim do you have? Helps nail down who may have what.
  4. May 6, 2022 at 10:31 AM
    joescho
    joescho New Member
    Joe
    Scranton,PA
    SR5 Off Road. I'm thinking most if not all trims have the pre-wiring but not 100% sure. I'm sure others with other trims will chime in
  5. May 6, 2022 at 11:00 AM
    Maharisc
    Maharisc w/Patty
    Karl
    2023 Tundra Platinum MBM Hv CM Adv Pkg
    Build date: 12/05/22
  6. May 6, 2022 at 5:50 PM
    vichmr
    vichmr New Member
    Scott
    Suwanee, GA & Highlands, NC
    '25 MGM Platinum TRD OR 6.5 w/ factory lift
    Go Rhino Dominator D6, Diamondback HD
    I’d like to know if the wiring harness for the bed step is ther on the Limited and SR5 models.
    Yoda21 likes this.
  7. May 25, 2022 at 3:39 PM
    gulfcoast850
    gulfcoast850 New Member
    I am also curious for the fog lights I have the sr
    TheBandit181 likes this.
  8. May 26, 2022 at 11:31 AM
    TheRooster
    TheRooster New Member
    Andrew
    Idaho
    I really want to know if the SR5 TRD OR I am waiting for will have USB or some form of power to charge things in the back seat. And if it doesn't, I wonder if there is wiring already there.
  9. May 26, 2022 at 12:19 PM
    TheBandit181
    TheBandit181 New Member
    Todd
    North of Pittsburgh, PA
  10. Jun 20, 2022 at 1:51 PM
    ToyoMon
    ToyoMon New Member
    2022 White Tundra SR5
    It should be up there. I have a SR5 that came with the dealer installed dashcam. It was non TRD, but loaded SR5 with the Premium packages and all. Would be messed up if the wiring only came in the premium package
  11. Jun 20, 2022 at 2:33 PM
    Maharisc
    Maharisc w/Patty
    Karl
    Apica and ToyoMon like this.
  12. Jun 20, 2022 at 2:50 PM
    j.b.
    j.b. New Member
    Jake
    2022 Platinum MGM
    I have been curious about the terrain select mode from TRD models. Would swapping out the dial/switches for my Platinum enable the terrain selection features? What are those even changing? I have different drive modes, but nothing for mud/snow/rain/whatever TRD version get. I pulled my console apart to wrap the piano black trim and there are a ton of wires going into that selector dial, which got me thinking that it may be pre-wired for all the different variations.
  13. Jun 21, 2022 at 4:35 AM
    roth_nj
    roth_nj New Member
    +1
    I’ve seen it discussed in other threads that crawl control wouldn’t work because we don’t have the factory locker, but maybe the other stuff would. Then it’s if there would just turn on when plugged in, or if we would have to activate with techstream
  14. Jun 22, 2022 at 7:59 AM
    22platinumguy
    22platinumguy New Member
    Jesse
    2022 Silver platinum tundra
    What about swapping a platinum from coils to air bags? Are all the platinums pre wired for that?
