Power window not working properly
Discussion in 'Electrical' started by LTR9, Feb 10, 2022.
  1. Feb 10, 2022 at 1:52 PM
    LTR9
    LTR9 [OP] New Member
    California
    2016, Inferno Orange, SR5, TRD OFF ROAD, 4x4
    Working on it.
    Hi,
    I have a 2016 tundra TRD I just bought. The passenger window control goes down but won’t work to roll up. It rolls up from the driver side master controls. My first guess would be a lose connection. Anyone have similar issue?
  2. Feb 11, 2022 at 8:42 AM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    Could be a loose connection/damaged wire or pin on the passenger switch since it works from driver's master. Or that passenger switch could be bad.
    LTR9[OP] likes this.
  3. Feb 12, 2022 at 3:57 PM
    LTR9
    California
    Working on it.
    Strange, now the passenger window isn’t working at all. Driver side or passenger side. Probably needs a new switch, or the connection was loose. I’ll pop off the Manuel and check it out when I install the stereo I bought.
  4. Feb 15, 2022 at 8:55 PM
    vipgs3
    vipgs3 New Member
    CA
    2015 Toyota Tundra 4x4
    I would check the driver master window switch. That switch is used mostly versus a passenger operating the window. Typically if the master switch fails, it can cause communication issues for the passenger front switch receiving signal to operate. Let us know how it turns out
    LTR9[QUOTED][OP] likes this.
  5. Feb 15, 2022 at 9:14 PM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    I actually had this happen a few weeks ago on my 2021. The passenger window would not go up, then a minute later it did and stopped halfway up. Rolled down ok. I turned the truck on and off and it worked fine. I think it was because I was turning a bunch of offroad lights on and off trying to aim them. Must have been too much battery draw or something.....first and only time it happened.
  6. Feb 15, 2022 at 9:24 PM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
  7. Feb 16, 2022 at 5:15 PM
    LTR9
    California
    Working on it.
  8. Feb 16, 2022 at 9:28 PM
    1lowlife
    DADA
    2014 MGM DC SR5
    I use them for all kinds of stuff around the house...
  9. Feb 19, 2022 at 1:41 PM
    LTR9
    California
    Working on it.
  10. Feb 19, 2022 at 5:12 PM
    1lowlife
    DADA
    2014 MGM DC SR5
    WOW, I wonder what caused that?
    Glad you got it fixed...
  11. Feb 20, 2022 at 6:34 AM
    LTR9
    California
    Working on it.
    I just bought it, but my guess is kids. Up, down, up, down, up, down…
    1lowlife[QUOTED] likes this.
