Power steering fluid flush?
Discussion in 'General Tundra Discussion' started by Deuxlatch, Sep 11, 2019.
  1. Sep 11, 2019 at 7:44 AM
    Deuxlatch
    Deuxlatch [OP] AirBus
    Chris (Latch)
    Tomball, Tx./Lafayette, La.
    2010 Super White Tundra CM
    TRD Supercharger, TRD Big Brake kit, MotoMetal wheels, Undercover Tonneau with dual swing out saddle bag tool boxes.
    Wife took her 2008 4Runner in to have it inspected at a local Auto-Lab service facility. Service tech did a complimentary inspection, said everything checked out but said PS fluid needed to be flushed. Said Toyotas are known to have power steering failures if you don't flush the fluid . Really? Still looked pretty clean to me. Anyone on here ever flush your PS fluid?
    kparrow likes this.
  2. Sep 11, 2019 at 8:14 AM
    kparrow
    kparrow New Member
    Kevin
    Great Falls, MT
    2008 Tundra DC 4x4 5.7l V8 Blue 128k miles
    Goodyear UltraTerrain AT 275/70/r18, Access Toolbox Bed cover, Stoptech Cryo Slotted Rotors/Hawk LTS Pads, Stubby Antenna, Paracord Grab Handles, more planned!
    Flushed it when I bought it. Per my Schaeffer rep’s recommendation I went with a hydraulic oil instead of trans fluid. Much more consistent viscosity and stable at low and high temp. Gets thinner in the low winter temps and thicker in the hot temps. I just used the method of sucking all the old from the tank, filling it up, driving to work and back, rinse and repeat till the color changed to the new fluid, about 2 quarts. Stupid easy
  3. Sep 11, 2019 at 8:20 AM
    Deuxlatch
    Chris (Latch)
    Good to know, thanks
  4. Sep 11, 2019 at 8:28 AM
    kparrow
    kparrow New Member
    Kevin
    Great Falls, MT
    Also I don’t know exactly what weight it was of fluid. I just told him my truck calls for trans fluid and he said “use this instead, run the same thing in my truck that called for trans fluid and it’s better in winter” filled up 2 quart bottles for me and off I went
    Deuxlatch [OP] likes this.
  5. Sep 11, 2019 at 8:33 AM
    Tierhog
    Tierhog SIG-AHOLIC
    California
    2016 Tundra Crewmax Limited 4WD
    Mostly stock/TRD accessories
    Change mine every 5-6 years. On cars I've kept forever that interval has allowed me to keep the same rack, pump, and hoses.
    Dirty fluid gets abrasive but 2 years IMHO is overkill. It's cheap though... So who cares. Use a turkey baster and pull and replace from the reservoir about 5 times driving between each change.
    Its becoming a lost art/requirement as the majority are electric now.
    kparrow and Deuxlatch [OP] like this.
  6. Sep 14, 2019 at 10:05 AM
    cmb46
    cmb46 New Member
    2008 Tundra
    After reading this I just suck some fluid out with my mitey vac thing and added dexron atf to it. I will do this several times then it should be good. Did the same to my wife’s Subaru and it was filthy.
  7. Sep 14, 2019 at 10:10 AM
    15whtrd
    15whtrd Mr. Blonde
    TRD Pro suspension, +2 Coachbuilder shackles, 2015 TRD Pro headlights, 20% ceramic tinted windows, charcoal filter delete, aFe drop in pro s dry air filter, TRD airflow accelerator, TRD oil fill cap, TRD 18 psi radiator cap, BDX Bullydog tuner, Weathertech floor mats front and rear, rear seat fold down mod, Tyger soft tonneau cover, Linex with uv protection, TRD swaybar, TRD center caps, TRD Pro grille insert, aluminum oil filter canister, Real truck tailgate seal, Pop-n-lock tailgate lock actuator, rear diff breather relocate, RCI front skid plate.
    I use a turkey baster and just suck out the reservoir at every oil change. I replaced with royal purple PS fluid.
  8. Sep 14, 2019 at 10:18 AM
    15whtrd
    15whtrd Mr. Blonde
    I have a couple of quarts dextron VI. Is that the right stuff?
  9. Sep 16, 2019 at 5:20 AM
    Deuxlatch
    Chris (Latch)
    I purchased a battery acid sucker outer thingy at O'Reilly and used that to remove as much fluid as I could and replaced with Lucas Power Steering fluid. Gonna do that a few more times but it seems to not make noise anymore. That's a good thing.
