Post first oil change question
Discussion in '2.5 Gen Tundras (2014-2021)' started by Durania, Mar 30, 2019.
  1. Mar 30, 2019 at 9:18 AM
    Durania
    Durania [OP] New Member
    Crossville, TN
    2019 Cavalry Blue CM Ltd
    Did my first oil change today at 5600 miles since I am towing a travel trailer. Put the required amount of oil in, started it, checked for leaks. Waited about 30 minutes and checked it with the dipstick. I honestly cannot see the oil registering on it. I don't want to put any more in it because I already put close to the required 8 quarts in.
    Thoughts?
  2. Mar 30, 2019 at 9:25 AM
    JohnLakeman
    Outside of Weird, TX
    2017 MGM DC TSS 4.6L
    We get that the oil is new, but the dipstick IS wet, right? :confused:
  3. Mar 30, 2019 at 10:03 AM
    Sas
    Sas Humor is everywhere
    OKC, OK
    '17 SR5 CM TSS 4WD MGM 5.7 FF
    Lost track after #1.
    Probably shouldn't have put the oil in the gas tank...
    Just kidding, but the dipstick should definitely have at least some noticeable oil on it. Take the dipstick out, wipe it clean and stick it back in. Try putting some more in 1/2 quart at a time to at least get it to register.
  4. Mar 30, 2019 at 10:04 AM
    UTTundra
    UTTundra New Member
    Lou
    Utah
    Usually takes me 8.5 qts. If I'm at 8 or just under, it barely shows on the dipstick.
    mojojo and 15whtrd like this.
  5. Mar 30, 2019 at 10:20 AM
    15whtrd
    15whtrd Mr. Blonde
    Seems that the 18-19s require 8.5 quarts. Instead of 8 like my 15. To my knowledge nothing changed. I doubt they changed the oil pan so I assume the dipstick changed. Add a 1/2 quart and I bet it puts you right in the middle. The oil is super thin and practically transparent, which doesn’t help.
    Trooper2 likes this.
  6. Mar 30, 2019 at 10:29 AM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Shine a flashlight on it.
    If you put in 8 quarts. It is safe to run. Go drive around the block then try. Maybe there is a few drops of old oil in the block that will mix and color it a little
    15whtrd likes this.
  7. Mar 30, 2019 at 10:40 AM
    Trooper2
    JR
    Houston, TX (Suburban South)
    Make sure the engine is warm as well.
    15whtrd likes this.
  8. Mar 30, 2019 at 10:50 AM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Just to check oil? Doesn’t seem to change fluid level much warm vs cold
    Ajkkane likes this.
  9. Mar 30, 2019 at 11:04 AM
    Durania
    Crossville, TN
    You're correct. I put 8.5 quarts in little by little and then it started to register on the dipstick. Odd. I'm good to go now. Thanks fellas!
    Sas, JohnLakeman and 15whtrd[QUOTED] like this.
  10. Mar 30, 2019 at 11:06 AM
    15whtrd
    15whtrd Mr. Blonde
    I think my manual says warm engine and let sit for 5 min then check.
  11. Mar 30, 2019 at 11:16 AM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    2015 MGM Limited 2x4 Sequoia
    Brand new 0W20 oil is EXTREMELY hard to see on the stick with the naked eye. Pull the oil level stick. Wipe it dry. Put it back in....all the way. Pull it out. Look at it. Then sniff it. Thennnnnnnnnnnnnnnnnnnnn.............touch it with your dry finger in between the dots. Finger wet with fresh oil?
    I have a 2017, 5.7 liter. It likes oil closer to 8.5 quarts then it does 7.9/8.
  12. Mar 30, 2019 at 11:17 AM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    Yup. Warm up engine. Go inside. Check your wife's/GF's "oil level." Then go back outside and check your Tundra's oil level.
    It really is a perfect world. :broccoli:
    Migraine and 15whtrd[QUOTED] like this.
  13. Mar 30, 2019 at 11:18 AM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Unless the truck is cold by the time thats done :thumbsup::benchpress:
  14. Mar 30, 2019 at 11:20 AM
    Greg Marmalard
    Greg Marmalard New Member
    2019 Tundra TRD Off Road Double Cab
    RangerBP and Durania[OP] like this.
  15. Mar 30, 2019 at 11:22 AM
    markg
    markg New Member
    Mark
    NC
    2007 TRD
    Check the oil after the engine has been turned off for about 5 minutes.
    Some oil will remain in the upper (heads) area of the engine until they have time to drain back into the oil pan.
  16. Mar 30, 2019 at 11:23 AM
    Durania
    Crossville, TN
    Oh yeah! I went ahead and installed one today. When I had one on my STi, I could have the oil changed on that thing in no time.
  17. Mar 30, 2019 at 11:26 AM
    Trooper2
    JR
    Most fluids expand when heated; oils are no exception. Your oil level should show slightly different when engine is cold vs. warm.
    15whtrd likes this.
  18. Mar 30, 2019 at 11:31 AM
    Greg Marmalard
  19. Mar 30, 2019 at 11:33 AM
    Durania
    Crossville, TN
  20. Mar 30, 2019 at 12:23 PM
    hagrid
    hagrid debris-ridden gaijin
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
    This sounds like my prom night.
  21. Mar 30, 2019 at 12:26 PM
    Durania
    Crossville, TN
    This is getting hot.
    hagrid[QUOTED] likes this.
  22. Mar 30, 2019 at 12:29 PM
    Tundra_361
    Tundra_361 New Member
    Victor
    2019 Black 1794 4x4
    I had to put almost 9 quarts for it to mark full. Kinda still has me scratching my head.
  23. Mar 30, 2019 at 12:51 PM
    JohnLakeman
    Makes you wonder...Is it more accurate to put in the amount of oil Toyota says is correct, and mark the dipstick?...Or, to put in however much the dipstick says is right? Hmmm...Inquiring minds should be wondering. :tinfoilhat:
    I am surprised that the oil level on the dipstick goes from no trace to midway between the dots in half a quart. Used to be the "two dots" represented one quart.
  24. Mar 30, 2019 at 1:40 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    I’ll have to check when i get home. Oil is so dense i assumed it’s rate of expansion would be less than less dense fluids like atf and coolant. Thanks for tip
    Trooper2[QUOTED] and JohnLakeman like this.
  25. Mar 30, 2019 at 2:14 PM
    Stig
    Stig New Member
    You need to have the truck parked on level ground. Don't check your oil level while parked on your hilly driveway.
    Sas likes this.
  26. Mar 30, 2019 at 4:12 PM
    jawjatek
    jawjatek New Member
    N GA
    2019 Tundra DC TRD
    If you scuff the dipstick with a file or coarse abrasive in a cross-hatch pattern between the dots, you can see the oil on it easier. Make sure to wipe it clean of any abrasive before re-inserting into your nice engine.
    plumber802, Trooper2 and 15whtrd like this.
  27. Mar 30, 2019 at 6:21 PM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    i can't emphasize how important this ^^^ is on the Tundra 5.7 liter. Especially side-to-side.
    In fact, to be safe, have your big breasted girl get out of the truck before checking the oil.
    Trooper2, Durania[OP] and flying dave like this.
  28. Mar 30, 2019 at 7:56 PM
    Durania
    Crossville, TN
    This is the step I forgot. She never got out of the truck, bless her heart.
    Pudge, 15whtrd and Trooper2 like this.
  29. Mar 30, 2019 at 8:22 PM
    Sas
    OKC, OK
    Blow up dolls don't count.
    Durania[QUOTED][OP] and Trooper2 like this.
  30. Mar 30, 2019 at 8:39 PM
    1engineer
    1engineer New Member
    Appalachians
    2019 Tundra Limited TRD Off Road.
    Rough up the stick with steel wool.
