Possibly bad battery or something else?
Discussion in '2.5 Gen Tundras (2014-2021)' started by colenation, Oct 17, 2021.
  1. Oct 17, 2021 at 6:08 AM
    colenation
    colenation [OP] What’s next?
    Cole
    Alabama
    2018 Tundra TRD Sport
    Readylift 4”F/2”R SST LIFT Kit Fuel Sledge D595 (20x9 +20) Thunderer Ranger A/TR (35x12.5R20) Havoc HS2 black hoop steps
    After a long day at the ballpark yesterday, I went to leave and when I turned the key…..click, click click. Truck would not start. I initially had interior lights so assumed it was the battery. I was able to jump it and started right up. While putting the cables away the truck kinda sputtered a couple times then just shut off. We then tried to re-jump, and nothing.:mad::mad:
    The only thing displayed on the dash was the illuminated battery light (red). I then made a trip to the parts store and replaced it. Truck started right up with new battery.
    Has anyone experienced this before and should I be concerned it’s more than just the battery? I plan to visit one of the parts stores today and get them to test it to make sure the alternator is good along with anything else that they can check.
    Note: I had not noticed any battery/starting issues until yesterday when it wouldn’t start.
  2. Oct 17, 2021 at 6:12 AM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    No need to be concerned. Your battree crapped out. You replaced your battree and you're good to go.
    colenation[OP] likes this.
  3. Oct 17, 2021 at 6:13 AM
    Buckaroo
    Buckaroo New Member
    Central Ohio
    2017 Tundra 5.7L 4WD DC TRD
    2020 GD 2670MK Travel Trailer
    My 2017 DC battery died about two months ago - no previous issues just didn't start (click, click, click). Replaced and all ok. BTW, good to always check the charging system when replacing a battery as you are planning.
  4. Oct 17, 2021 at 6:45 AM
    Cock-A-Doddle-Do
    Cock-A-Doddle-Do New Member
    Brett
    Cypress, Texas
    2021 TRD Off Road CM -Super White
    Load test battery and alternator...
  5. Oct 17, 2021 at 9:38 AM
    GarTX526
    GarTX526 New Member
    2016 QuickSand TRD-Pro
    Many pending.....
    Same happened to me recently. Swapped battery and noticed the volts were still a bit low. Had alternator tested and it was out as well. Was running on straight battery power. Swapped alternator and all back to normal. Hope yours is just battery though. Alternator replacement was not cheap and unfortunately not something I could take on myself at this time.
    good luck.
  6. Oct 17, 2021 at 10:26 AM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    Make sure your battery clamps/connections are clean.
    My 2005 had the thinnest layer of corrosion you couldn't see and it gave me the same issues..
    colenation[OP] and WILLINH like this.
  7. Oct 17, 2021 at 7:02 PM
    colenation
    Cole
    Alabama
    So just to follow up on my initial post:
    I stopped by O’Reillys and had them check the new battery, alternator and starter. Everything checked out and looks like after replacing the battery I’m good to go.:thumbsup:
    Thanks for all the feedback.
  8. Oct 18, 2021 at 5:03 PM
    KingsAustin
    KingsAustin Grey Goose II
    Morgan County, AL
    2021 Limited Night Shade
    BakFlip MX4, Gator All Weather mats, Console Safe, Ceramic Tint, Roadmaster Active Suspension, Interior/exterior LED conversion, Wireless console charger, AJT designs.
    One of my vehicles usually loses a battery after a Texas summer. I didn't lose one this year because we had an off summer year, but it happens.
  9. Oct 18, 2021 at 5:59 PM
    colenation
    Cole
    Alabama
    We just had our first cold front come through here in Alabama and that must’ve been what got it.
  10. Oct 18, 2021 at 6:01 PM
    KingsAustin
    Morgan County, AL
    Where are you located in Alabama?
  11. Oct 18, 2021 at 6:06 PM
    colenation
    Cole
    Alabama
    North, just shy of the TN line (Huntsville)
  12. Oct 18, 2021 at 6:07 PM
    KingsAustin
    Morgan County, AL
    Looking at property in Athens, Madison, Hartselle and Cullman County for retirement.
    RitcheyRch likes this.
  13. Oct 18, 2021 at 6:13 PM
    colenation
    Cole
    Alabama
    Well depending on what you like, Madison is growing to quickly for my liking and is crazy congested now. We got some property just across on the TN side and as soon as we can build, I’m out. It’s currently still a little spacious.
  14. Oct 18, 2021 at 6:21 PM
    KingsAustin
    Morgan County, AL
    We were there back in July. We are looking outside of Madison south of the interstate. You are right, it was a bit busy BUT not IH35 Texas busy! We have family in Cullman, Athens and Mussel Shoals. We haven't quite decided. We definitely like the low property taxes in Alabama especially as retirees.
  15. Oct 18, 2021 at 6:25 PM
    Desert Dog
    Desert Dog Nobody rides for free
    2001 SR5 AC 2WD 4.7l
    Bilstein 5100's, SPC UCA's, ATS HD leaves
    Lots of good comments based on personal experiences and suggestions here. Batteries that have past their service can exhibit some wonky conditions and sometimes crap-out with no prior warning or issues. Always remember to check your grounds at times like this too. They are often overlooked as a possible source of issues.
    colenation[OP] and KingsAustin like this.
  16. Oct 18, 2021 at 7:02 PM
    DvilleMafia
    DvilleMafia New Member
    DFW
    2018 Tundra SR5 4x4
    exact same thing happened to my 2018 about a month ago, running fine no warning of battery going out. I stopped for like 10 mins and went to start only to hear click click click. It killed my alternator which I had replaced the next day and a week later I ended up replacing the battery as well.
  17. Oct 18, 2021 at 7:45 PM
    colenation
    Cole
    Alabama
    I was afraid my alternator was going to be shot, but it checked out ok. Thankful for that.
  18. Oct 25, 2021 at 3:50 AM
    Tigereye
    Tigereye New Member
    Eric
    2019 SSM Limited
    bed liner, diamondback se, level kit, nitto ridge grapplers,tufskinz letters, grab handle
    You may want to look at Decatur also. My wife is from Decatur and it's a nice smallish town not far from Athens, Huntsville, or Cullman.
    KingsAustin likes this.
