Pop and Lock
Discussion in 'General Tundra Discussion' started by joonbug, Aug 25, 2016.
  1. Aug 25, 2016 at 3:55 PM
    joonbug
    joonbug [OP] WarEagleSteve Fan Club New Member
    Joon
    NorCal
    2015 Tundra DC 5.7 TRD off-road
    Just received my Pop and Lock for the tailgate. Has anyone installed on a 2015? I saw a youtube video for a 2013 and another one for a 2014 and the guy on the '14 said the wires to splice into, in the cab, were different from the '13? Any advice or tips appreciated.
  2. Aug 25, 2016 at 4:00 PM
    eledobleu
    eledobleu HEADLIGHT RETROFITS Vendor
    Atlanta, GA
    Koito Bi-LED Retrofit
    I installed mine right before 4th of July. The wiring is slightly different. I watched the video of the guy explaining that about the 14. Overall it's the same install, just the wires in the passenger kick panel is slightly different. I will check which wires you need to splice into once I get a chance.
    RowdyRon likes this.
  3. Aug 26, 2016 at 5:16 AM
    15whtrd
    15whtrd Member
    2015 Tundra DC SR5 TRD 4x4 5.7L Gas
    20% ceramic tinted windows, charcoal filter delete, weather tech floor mats, rear seat fold down mod, Tyger soft tonneau cover, Linex with uv protection, TRD swaybar, TRD center caps, TRD Pro grille insert, Real truck tailgate seal, Pop-n-lock tailgate actuator. Lots of love.
    The instructions I got with mine were up-to-date and it wired perfectly. Passenger side kick panel. Just make your connections, and before you put everything back to make sure that it is locking and unlocking in the correct order with the key fob. I had heard everything was correct except for what wires were connected to which color. I have basically heard that they had it backwards. But that was not the case with my instructions it worked fine. Good luck good!
  4. Aug 26, 2016 at 9:26 AM
    joonbug
    Joon
    NorCal
    Thanks guys, I'm going to try this weekend. Oh, and did you guys route the wire under the truck and into the engine bay? The video didn't really show how he got to the engine bay.
  5. Aug 26, 2016 at 10:29 AM
    FumundaTundra
    FumundaTundra Director of civil unrest
    Wayne
    Central WA.
    2009 5.7 Tundra Double cab
    Many to come.
    I like that. I may have to install one on my DC.
  6. Sep 16, 2016 at 6:52 PM
    ChucklesToy
    ChucklesToy New Member
    Chuck
    Round Rock, TX
    2016 Tundra Platinum Edition, SIlver Sky Metallic
    Did mine Labor Day weekend. Routed it under the driver side and into a grommet near the rear passenger door. This takes the wire into the door plate channel on the passenger side. Ran it to the kick panel and wired it up. All done. Works great.
  7. Sep 16, 2016 at 7:53 PM
    IslandHui
    IslandHui New Member
    Del
    Hawaii
    2016 White DC TRD
    LRO leveling kit, TC A-arms, trd pro grille
    I just did mine yesterday on a '16 DC. I routed the wire along the passenger side into the engine bay to the passenger side kick panel. I wired the green wire to blue/silver stripe. Then blue wire to white/silver stripe. It works fine.
    ChucklesToy likes this.
  8. Sep 17, 2016 at 4:45 AM
    joem1cha3l
    joem1cha3l Professional Spender
    Joe
    Albany, NY
    2016 Double Cab SR5 Blazing Blue Pearl
    BOSS Suspension, DB Customz Grill, 35's, Spyder, Tint, Color matched corners
    Anyone have a link to this kit? Looking at doing this ASAP
  9. Sep 17, 2016 at 6:26 AM
    iHacker
    iHacker New Member
  10. Sep 17, 2016 at 7:08 AM
    ChucklesToy
    Chuck
    Round Rock, TX
  11. Sep 17, 2016 at 8:24 PM
    joonbug
    Joon
    NorCal
    I can't believe I manually locked and unlocked the tailgate for an entire year. Should have done this way sooner. If Toyota made this a standard feature and put it on every Tundra, they could probably do it for under $20 a truck.
    15whtrd and ChucklesToy like this.
