POP! 4hi/4lo flash & malfunction error
Discussion in '2.5 Gen Tundras (2014-2021)' started by Toekneewin, Jul 27, 2021.
  1. Jul 27, 2021 at 4:24 PM
    Toekneewin
    Toekneewin [OP] New Member
    Tony
    2020 Super White TRD Sport
    Hey guys, 2020 trd sport with 13k miles. Today I put the truck in 4hi then neutral and went to 4lo. Moved forward a bit and the truck made a pretty loud popping sound. I then got a 4 wheel drive system malfunction error on the stereo display. The 4hi/low lights flashed. I turned the truck off and on. No flashing lights but the popping sound worry’s me. Did something break?
  2. Jul 27, 2021 at 5:02 PM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    Never put 4lo in pavement,
  3. Jul 27, 2021 at 5:05 PM
    Did u turn or just straight pavement? Almost sounds like binding
  4. Jul 27, 2021 at 5:18 PM
    Hambone1
    Hambone1 New Member
    Blaine
    2015 tundr limited
    Not much yet
    Need to put the tranny in neutral before you put in 4L
  5. Jul 27, 2021 at 5:46 PM
    Danman34
    Danman34 New Member
    Danny
    2018 White Tundra TRD Sport
    Was 4L fully engaged before you put it back in drive and started moving?
    Ely010606 and TILLY like this.
  6. Jul 27, 2021 at 6:04 PM
    Toekneewin
    Tony
    The truck moved probably 6 inches forward in 4lo if I remember correctly. Just straight no turning. Took a look underneath the truck nothing seems out of place but Im no mechanic. I cycled 4hi and 4lo again just letting off the brake around my property driveway (gravel) and the lights didn't flash. Moved about 50ft and parked it.
    Sounded like this tacoma binding but a bit louder from inside the cab. My understanding is that trucks with lockers normally do this?
    https://youtu.be/d4MjRMxCQUs
  7. Jul 27, 2021 at 6:26 PM
    TILLY
    TILLY Gently Used Member
    Massachusetts
    2019 MGM TRD Sport D/C
    I bet it was this also, usually takes a few seconds before its fully engaged.
    Ely010606 likes this.
  8. Jul 27, 2021 at 6:32 PM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    Bruh, u scared me…I though u were in pavement…
  9. Jul 27, 2021 at 6:36 PM
    Toekneewin
    Tony
    No sir! Real strange that happened. I'm just hoping nothing is broken.
  10. Jul 27, 2021 at 6:53 PM
    TILLY
    Massachusetts
    Tony, how often do you use the 4WD? The actuators in our trucks are a little on the loud side when they engage, and can get a little sticky if not exercised periodically to lube them.
  11. Jul 27, 2021 at 6:59 PM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    U lucky u have gravel road, I have to do 4hi on highway
  12. Jul 27, 2021 at 8:35 PM
    Toekneewin
    Tony
    Usually just in the winter when it snows but I did put it in 4Hi about a month ago going up a steep dirt road. You recommend cycling through both 4hi and lo every so often? Last time I used 4Lo was winter. Does something engage in 4Lo that doesn't in 4Hi?
    Haha I live in the "country".
  13. Jul 27, 2021 at 8:57 PM
    TILLY
    Massachusetts
    Toyota recommends 10 miles per Month in 4WD to lubricate, which seems excessive to most of us here. I put it in High on a very straight stretch whenever I can, wet if possible with no turns to just get the fluids moving around. I use 4Low very rarely, but still engage it from time to time to lube the actuator. Everyone here has there own rituals, but this seems to work for me.
    blanchard7684 and Ely010606 like this.
  14. Jul 27, 2021 at 9:20 PM
    Ely010606
    Ely010606 New Member
    SPARKS, NV
    2017 QS SR5 CM TRD 4x4
    I hardly use the 4L maybe I should engage once in a while, I normally just engage my 4H when I go shooting its like around 2.5 mile to hit the range in dirt road. But when it rains or snow it’s on 4H just to turn it on.
    Hambone1 and TILLY like this.
  15. Jul 27, 2021 at 11:05 PM
    Toekneewin
    Tony
    Ill have to put it in 4WD more often then. Most of the time I'm in 4WD it's pretty slow speeds but I'll make a note to move the fluids around. I will at least have the dealership check it out next time I'm in.
    Thank you everyone for your input and advice!
  16. Jul 28, 2021 at 3:27 AM
    blanchard7684
    blanchard7684 New Member
    You likely had a sticky actuator if you haven't used 4wd very often.
    There is a post around here awhile back with a Tundra that was 10 years old or so and never, ever put in 4wd and the actuator was seized solid....
    Toekneewin[OP] likes this.
  17. Jul 28, 2021 at 8:11 AM
    Toekneewin
    Tony
    Hopefully it was a sticky actuator. VERY dusty where I live also!
  18. Jul 28, 2021 at 10:42 PM
    Ely010606
    SPARKS, NV
    So I decided to engage the 4x4 today since I haven’t done it in a while and Damn, when engaging to 4L it sure is a loud pop, compare to 4H. Scared the shit out of me, but at least i know they are engaging.
    TILLY and Toekneewin[OP] like this.
  19. Jul 29, 2021 at 5:42 PM
    Toekneewin
    Tony
    Thanks for checking! Gives me a little peace of mind for sure man.
    Ely010606[QUOTED] likes this.
  20. Jul 29, 2021 at 5:45 PM
    Ely010606
    SPARKS, NV
    No prob.
  21. Jan 10, 2023 at 8:31 PM
    Punisher1
    Punisher1 New Member
    Dale
    2020 Tundra TRD PRO
    285/75R18 Goodyear Duratracs
    My 2020 Tundra made a loud popping sound tonight while sitting in the wash bay not even running. I had just done the 4 minute soap spray and stopped to talk to a guy and while standing there it Popped so loud and the lights flashed. I started it and it said "Turn power off" so I turned it off, looked around on the outside and then turned it back on and all was fine. Have no idea what it was but worries me somewhat.
