Please help with a tire question.
Discussion in 'Wheels & Tires' started by dav89d, Nov 21, 2016.
  1. Nov 21, 2016 at 9:22 PM
    dav89d
    dav89d [OP] New Member
    I have 2007 2wd. Running 275 65 r18. I desperately need new tires all around and wanted to upgrade to something bigger. Truck is stock height. I also want to keep stock wheels.My question is what size tire can I run on stock 18s without any issues? Thank you in advance.
  2. Nov 21, 2016 at 9:36 PM
    TXMiamiFan
    Jose
    2016 White Crew Max TRD
    Search for this thread see if it helps. Great info. Sorry, I haven't learned how to post a link to a specific thread.
    Official Tundra Wheel and Tire Setups - Pics and Info
    ColoradoTJ likes this.
  3. Nov 21, 2016 at 9:42 PM
    LML 3500HD
    Lol. Copy and paste. :D
    rons23 and Black Wolf like this.
  4. Nov 22, 2016 at 12:00 AM
    TundraGuy80
    TundraGuy80 New Member
    WA
    2013 TRD Rock Warrior
    18x9 Fuel Gripper Wheels 33x12.5 Atturo Trail Blade MT Tires Bilstein 5100 Front & Rear Flowmaster Outlaw Exhaust Super 10 Muffler 2 in 2 out 20% Window Tint Color Match Door Handles
    Screen shot from another post....
    Black Wolf likes this.
  5. Nov 22, 2016 at 7:16 PM
    dav89d
    "Trimming may be necessary" trimming of what?
  6. Nov 22, 2016 at 7:26 PM
    TXMiamiFan
    Jose
    CMC. Cab Mount Chop. Right where the body ends in the wheel well.
  7. Nov 22, 2016 at 9:41 PM
    dav89d
    That doesn't sound too good
  8. Nov 23, 2016 at 8:00 AM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 Long Travel DC
    I would think if you only go up one size, either 285 or 70, you'll probably be okay. If you rub, it'll probably be minor, like a mudflap. And the CMC isn't as bad as it sounds. It's just cutting back a little part in the wheel well and welding on a piece to give you a little more room.
  9. Nov 23, 2016 at 10:20 AM
    Why not?
  10. Nov 23, 2016 at 10:51 AM
    rons23
    rons23 Get The Led Out!!!
    Ron
    Kill Devil Hills
    2008 Nautical Blue TRD
    P275/70/18, anything bigger will require some sort of lift. Spacers, coilovers, or suspension.
  11. Nov 23, 2016 at 4:05 PM
    dav89d
    Idk how I feel about cutting into both mounts
  12. Nov 23, 2016 at 4:39 PM
    CM-LENNY
    CM-LENNY No Complaints
    San Diego, CA
    2015 4x4 CrewMax SR5
    PRO shocks, 37's Nitto G2's 4:88 diffs, few other mods
    I did a Bilstein 5100 shock on the front and leveled it out. About a 2-1/4" lift up front. Rides better than stock. Shocks are $90.00 ea plus alignment $ 300.00 tops. $ 400-450 installed at a shop. I am running 285/75R-18 on stock wheels and no body mount chop. That is close to 35" tall tire. Lots of guys run 295/70R-18 as a little more common. Mudflap mods or removal but nothing crazy. Good luck with everything
    TundraGuy80 likes this.
  13. Nov 24, 2016 at 12:10 AM
    TundraGuy80
    WA
    Are you running wheel spacers on your stock rims? I have the Rock Warrior with the stock 17's and they're kinda growing on me and I like the idea of 5100's up front with 1.25" spacers to give a more aggressive stance.
  14. Nov 24, 2016 at 7:32 AM
    CM-LENNY
    San Diego, CA
    I am not running wheel spacers. When running wheel spacers, you are moving the tire out for a more aggressive stance, but that's when you get in trouble with body mount clearance. It sounds almost backwards, but crank your wheels all the way to one side and go out and look at the clearance to your body mount. Now picture that wheel moved on that same plane and you'll see how close it gets. Good luck with everything !
    TundraGuy80[QUOTED] likes this.
