Please help tundra problem
Discussion in 'General Tundra Discussion' started by Jimnus, Sep 8, 2020.
  1. Sep 8, 2020 at 9:29 AM
    Jimnus
    Jimnus [OP] New Member
    07 tundra four-door four-wheel-drive 5.7 L engine
    Aftermarket air filter
    Hey this is my first time I hope someone can help me. I am on a whole seven tundra four-door four-wheel-drive 5.7 L engine I have three codes come up mass airflow sensor right to bank fuel injectors and O2 sensor right bank. After changing the mass airflow sensor and the O2 sensor I’m still coming up with the second bank of fuel injectors are bad. The trouble is if I am hooked a battery let it sit for a short amount of time maybe 15 minutes put the battery back up in the thing runs like new it shows no code violations and As I said runs like new for about 15 minutes maybe 20 miles and then goes back to the code violations. My thinking is if the fuel injectors are bad they wouldn’t work at all so before I go spend $2600 for a new fuel injectors is what the garage wants I thought I might ask you thank you
  2. Sep 8, 2020 at 12:49 PM
    Ruggybuggy
    Ruggybuggy Seasoned Veteran
    Dave
    NW ON, CANADA
    2016 Tundra OR
    After you clear your codes what is the first code number that pops up?
    NewImprovedRon likes this.
  3. Sep 8, 2020 at 5:11 PM
    Rlawshe1
    Rlawshe1 New Member
    Rob
    2020 MGM
    What are the codes that you are getting from it?
