Please help. Front suspension issue.
Discussion in '1st Gen Tundras (2000-2006)' started by cfreder9955, Sep 23, 2022.
  1. Sep 23, 2022 at 10:02 PM
    cfreder9955
    cfreder9955 [OP] New Member
    Cursed tundra
    Hello,
    thanks for reading. Sorry if my post is wrong or breaks any rules, I’m new to the forums.
    just bought a used 2001 tundra. When changing the cv axel, I read the wrong website and over torqued one of the four bolts that attach the front lower ball joint to the knuckle arm. The bolt snapped. Then when trying to use a bolt remover, the bolt remover snapped. I’m looking for options. I will try a you pull it yard to see if I can find a replacement knuckle arm but it seems like the local you pull it only had a 2000 and 2006 tundra. I think the knuckle arm changed in 03 or 04 so it seems like there is only one option and they didn’t know if it was a 4x4. I don’t have the money for a new arm and I’m not a mechanic, I don’t have a press to push the wheel barring into the knuckle arm. My grandpa recommended using three bolts and finding a welder to tack weld the fourth corner. Is that a horrible ideal? This is not my daily driver, we just wanted a truck to occasionally move stuff around so it’s rarely driven.
    I would appreciate any advice. I don’t know much about cars or mechanics.
  2. Sep 24, 2022 at 12:31 AM
    NickB_01TRD
    Nick
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    Only suggestion I have is drilling it out completely if it is the bolt that has a hole that goes all the way through to the other side and using a bolt and nut instead. There is a thread specifically about these bolts and why you should replace OEM with new every time they are removed. May want to consider new hardware once you get that other bolt out. 59ft/lbs
    Thread on these bolts... Link
    ARP hardware (multi use) part number 663-1004
    OEM part (single use but cheaper) 90080-10066
  3. Sep 24, 2022 at 12:55 AM
    cfreder9955
    Cursed tundra
    Thanks for replying. Unfortunately it’s the outer bolt that does not go all the way through.
  4. Sep 24, 2022 at 1:43 AM
    NickB_01TRD
    Nick
    KY
    Hopefully you'll get some better suggestions in the later hours of the day. Good luck
  5. Sep 24, 2022 at 1:49 AM
    Mr.bee
    Mr.bee King Turdra
    SATX
    '02 AC TRD
    If the knuckle is cast iron, welding wont help much.
    is that a pic of the extractor? Doesnt look like a pilot hole has been drilled in it.
    I've always had luck with the straight flute extractors, but a pilot hole, some penetrating oil, and maybe heat would be your friend.
    and dont try to put the extractor in a drill, turn it with a wrench, so you can sneak up on the torque.
  6. Sep 24, 2022 at 1:56 PM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC
    So if overtorque snapped it, the threads aren't siezed/rusted.
    You could try a left hand drill bit set and/or extractor.
    If there is enough sticking out, you could unbolt the other 3 bolts and grab it with some good pliers to spin it out.
    Alternatively, if only a slight bit is sticking out, you could weld a nut onto it to spin it out. This would work if you have both a welder and the skills.
    Last option is taking the whole knuckle off and bringing it to a machine shop.
  7. Sep 24, 2022 at 9:04 PM
    cfreder9955
    Cursed tundra
    Thanks so much for the advice. I ended up taking the whole knuckle arm off, once it was off I was able to get the old parts out. Almost all back together now. Having a hell of a time getting the abs sensor to reseat completely. Been reading all the differing opinions about the axel nut torque. Seems like 173 for the first gen, but two mechanics have now told me to just “snug it up” so I’m doubting myself.
  8. Sep 24, 2022 at 9:25 PM
    TFT
    TFT New Member
    Troy
    2017 Tundra Limited
    Impact Screwdriver with a Flat Edge Screwdriver slit dremeled into the bolt? Might get it turning, if it is jammed in there.. Then the bolt removed could finish the job.
  9. Sep 24, 2022 at 10:14 PM
    assassin10000
    Andrew
    Northern CA
    '05 SR5 AC
    You may need to clean/sand the abs hole lightly to make it slide back in smoothly.
  10. Sep 25, 2022 at 6:29 AM
    cfreder9955
    Cursed tundra
    thats actually how I got them out.
    TFT[QUOTED] likes this.
