Play in gear selector lever
Discussion in '1st Gen Tundras (2000-2006)' started by avgguy, Nov 26, 2018.
  1. Nov 26, 2018 at 11:55 AM
    avgguy
    avgguy [OP] New Member
    Craig
    2000 Tundra 274K Original
    It has gradually gotten a looser.... maybe an inch of play ?
    Transmission still goes into gears properly so no functional issue. I would just like it tighter.
    Anyone else ?
  2. Nov 26, 2018 at 11:57 AM
    15whtrd
    15whtrd Mr. Blonde
    TRD Pro suspension, +2 Coachbuilder shackles, 2015 TRD Pro headlights, 20% ceramic tinted windows, charcoal filter delete, aFe drop in pro s dry air filter, TRD airflow accelerator, TRD oil fill cap, TRD 18 psi radiator cap, BDX Bullydog tuner, Weathertech floor mats front and rear, rear seat fold down mod, Tyger soft tonneau cover, Linex with uv protection, TRD swaybar, TRD center caps, TRD Pro grille insert, aluminum oil filter canister, Real truck tailgate seal, Pop-n-lock tailgate lock actuator, rear diff breather relocate.
    Curious if it’s on the hinge point on the column. Check the selector under the truck to see if that’s where the play is.
  3. Nov 28, 2018 at 5:56 AM
    growit
    growit New Member
    2006 Dbcb SR5
    Check out the gearshift bushing, it's an easy fix. I fixed mine with a bushing from - bushingfix.com. Found it on youtube.
    It's a pricey little bushing but easy to repair.
  4. Nov 29, 2018 at 3:27 PM
    Professional Hand Model
    Professional Hand Model Fred Brookes
    2002 Tundra SR5 4WD
    Aluminum sideboxes
    I checked my play and its about the same around 1”. Not sure if thats normal or from age as the manual does not spec this measurement. Hard to tell after 16 years.
    avgguy [OP] likes this.
  5. Nov 29, 2018 at 4:15 PM
    growit
    growit New Member
    2006 Dbcb SR5
  6. Nov 29, 2018 at 4:51 PM
    2002 Tundra SR5 4WD
    Aluminum sideboxes
    You have the part number for this bushing for 2002 Tundra V8 Sr5 4WD Access Cab?
  7. Nov 29, 2018 at 5:18 PM
    growit
    growit New Member
    2006 Dbcb SR5
    Go to bushingfix.com website and check out what they have to offer.
  8. Nov 29, 2018 at 5:28 PM
    2002 Tundra SR5 4WD
    Aluminum sideboxes
    Nothing specific to Tundra. Plenty other Toy models though. I’ll wait to see someone else do theirs. Not a problem for me right now.
  9. Nov 29, 2018 at 5:32 PM
    Casper421
    Casper421 Adventure in a 1st gen
    N. Cal
    06 DC
  10. Nov 29, 2018 at 5:39 PM
    2002 Tundra SR5 4WD
    Aluminum sideboxes
  11. Nov 29, 2018 at 6:17 PM
    growit
    growit New Member
    2006 Dbcb SR5
    On bushingfix.com website click on "order now" and all the car brands appear. click on what you need and you are good to go.
  12. Nov 30, 2018 at 4:05 PM
    2002 Tundra SR5 4WD
    Aluminum sideboxes
    I ordered a bushing for the 02’. I’ll report back when installed. Steep price for a bushing at $25, but maybe avoid steering column stripping?
  13. Dec 2, 2018 at 12:51 PM
    avgguy
    Craig
    Thanks... let us know.
  14. Dec 4, 2018 at 3:30 PM
    2002 Tundra SR5 4WD
    Aluminum sideboxes
    Part came in yesterday. Will try to do this project this weekend.
    Jerry311SD likes this.
  15. Dec 4, 2018 at 4:38 PM
    Jerry311SD
    Jerry311SD New Member
    Jerry
    Ramona San Diego CA
    05 Tundra
    :popcorn::popcorn::popcorn::popcorn:
