Plasti Dipping the limited badge
Discussion in 'General Tundra Discussion' started by smooosh, Nov 4, 2017.
  1. Nov 4, 2017 at 10:07 AM
    smooosh
    smooosh [OP] This place costs me too much $
    2018 TRD Offroad Limited Crewmax.
    Ongoing project
    Has anyone successfully plasti dipped the the limited badge? I tried it the other day and failed miserably. 7 Coats and was trying to get the excess out of the little holes in the letters and it would come off the edge of words to. Even after i started to strip the dip off the badge after it got messed up I had a hard time getting it out of the holes of the letters which makes me think that its going to be next to impossible to do to this badge.
    If anyone has done it and can give me a hint let me know. The bigger badges look easy but those i bought TRD pro versions so i only have to do the limited badge or take it off.
  2. Nov 4, 2017 at 10:13 AM
    040Tundra
    040Tundra Teddy 2013-2019
    Aaron
    Las Vegas, NV
    040 '16 CM LTD 4x4
    Did you let it dry completely between each coat and then the final coat needs 15-20 mins before you start messing with it. And that’s at 70 degrees or so.
  3. Nov 4, 2017 at 10:16 AM
    smooosh
    Ongoing project
    30 minutes between coats.
    15 minutes until i started messing with it which is what the youtube video i watched said to do. They said you wanted it not totally dry for the last coat when you messed with it.
    It was mid 70's that day.
  4. Nov 4, 2017 at 10:17 AM
    040Tundra
    Aaron
    Las Vegas, NV
    040 '16 CM LTD 4x4
    Sounds like you did it right. I assume you used a wooden toothpick to trim the excess out??
  5. Nov 4, 2017 at 10:17 AM
    smooosh
    Ongoing project
    correct
  6. Nov 4, 2017 at 10:34 AM
    040Tundra
    Aaron
    Las Vegas, NV
    040 '16 CM LTD 4x4
    I got nothing....it sounds like you did everything perfectly. :pout:
    Sunnier likes this.
  7. Nov 4, 2017 at 10:37 AM
    smooosh
    Ongoing project
    So you where able to plsti dip your limited badge without an issue?
    If so i guess i have to just try again
  8. Nov 4, 2017 at 12:02 PM
    040Tundra
    Aaron
    Las Vegas, NV
    040 '16 CM LTD 4x4
    Mine was done when I bought the truck. But, I Plastidipped a lot of other stuff on there. I need to re-do the Limited badge in the next little while as the dip is coming off a little tiny bit around a few of the letters.
  9. Nov 4, 2017 at 12:50 PM
    Berdine
    Berdine Voodoo Sport
    Binghamton, NY
    2020 VooDoo Blue Trd Sport
    Use a toothpick to get in there. Saw it on dip your car. Works great, won't, scratch the paint. Also, more coats = easier to peel
  10. Nov 4, 2017 at 3:04 PM
    U applying light coats or heavy coats? I used wooden skewers for better handling i waited 40 min tween coats
  11. Nov 4, 2017 at 3:05 PM
    Berdine
    Binghamton, NY
    Few light, then heavier
