Peeeheeuuu's Journal Entry
Discussion in '2nd Gen Builds (2007-2013)' started by Peeeheeuuu, Dec 1, 2021.
  1. Dec 1, 2021 at 6:46 PM
    Peeeheeuuu
    Peeeheeuuu [OP] New Member
    Peter
    Elk Grove, CA
    08 Silver CM 4x4
    Hello all, I guess this build thread has been a long time comming. I purchased my 08 sky silver crewmax 4x4 Limited about 10 or so years ago. I added some AMP research running boards, a 2.5 inch spacer lift, 35/1250/20 MTs on stock wheels with 1.5 wheel spacers. She's been this way for along time.
    1rooster, D4x4TRD and juice77 like this.
  2. Dec 1, 2021 at 6:55 PM
    Peeeheeuuu
    Peter
    Elk Grove, CA
    08 Silver CM 4x4
    35/1250/20s with a spacer 2.5 level up front
  3. Dec 1, 2021 at 6:55 PM
    NCTundra18
    NCTundra18 New Member
    Jeff
    Candler, NC
    2018 White Limited Crewmax
    TRD dual exhaust, Rough Country lift kit and too much money spent.
    Welcome from Western NC. How do you like those Amp steps? I've been looking at them and wondering if they would go low enough. My wife has to use a 12" step stool to get in.
    Peeeheeuuu[OP] likes this.
  4. Dec 1, 2021 at 6:57 PM
    Peeeheeuuu
    Peter
    Elk Grove, CA
    08 Silver CM 4x4
    Installed a set of alpharex lights
    Mountun Goat and juice77 like this.
  5. Dec 1, 2021 at 6:58 PM
    Peeeheeuuu
    Peter
    Elk Grove, CA
    08 Silver CM 4x4
    I love them, they have been on the truck for about 8 years or so. I just replaced both motors at the beginning of this year.
    NCTundra18[QUOTED] likes this.
  6. Dec 1, 2021 at 7:01 PM
    Peeeheeuuu
    Peter
    Elk Grove, CA
    08 Silver CM 4x4
    Stoptech front and rear rotors and street pads. The passenger caliper had seized and I ended up replaced the passenger caliper, OEM of course.
    juice77 likes this.
  7. Dec 1, 2021 at 7:03 PM
    Peeeheeuuu
    Peter
    Elk Grove, CA
    08 Silver CM 4x4
    So at 155k-ish, my radiator started leaking at the plastic end cap. I decided to address it and take care of a few other things as preventative maintenance and also just because. Trd intake, koyo aluminum radiator and cap, oem waterpump, oem thermostat, oem radiator fan clutch, oem upper and lower radiator hoses and clamps, oem valve cover gaskets and spark plug tube seals, oem spark plugs, oem pcv valve. Even had my helper holding my flash light.
  8. Dec 1, 2021 at 7:10 PM
    Peeeheeuuu
    Peter
    Elk Grove, CA
    08 Silver CM 4x4
    Trd front and rear sway bars, TRD shift knob. Fiveteen52 turbomac wheels in a 20x9 +18 offset on 35/1150/20 nitto ridge grapplers. Also running 1 1/2 inch wheel spacers. Did a BMC, folded the fender pinch weld and trimmed the front bumper and fender liners and painted my tow hooks and installed paint match mirror caps and door handles.
  9. Dec 1, 2021 at 7:17 PM
    Peeeheeuuu
    Peter
    Elk Grove, CA
    08 Silver CM 4x4
    So at about the one year mark on the alpharex lights, they started to get condensation real bad and the led strip on both lights went out. At this point I started looking at morimoto's but ultimately went with the 18+ OEM Sequoia headlights with @xrunnerdude67 harness. I absolutely love it and wish I would have done this to begin with
  10. Dec 1, 2021 at 7:36 PM
    Peeeheeuuu
    Peter
    Elk Grove, CA
    08 Silver CM 4x4
    So she's been this way for just a bit and then covid hit. Got real busy with work and then the bug hit me real bad. I've been wanting to refresh the suspension because it's been on the original shocks and pretty much everything else. I've been following most of the LT guys and reading up on what I can and I've finally decided it's time to LT the truck. I've started ordering a bunch of stuff at the beginning of this year and I've been stashing parts. The parts list consists of
    Total Chaos +2.5 upper and lower control arms with SS extended brake lines, limit straps.
    TC cam tab gussets
    TC secondary shock hoops
    TC heim sway bar links
    TC diff drop kit
    King (TC spec) 2.5 coilovers with remote resi w/adjusters (small 3 inch daimeter coil, 700lb spring)
    King 3.0 secondary bypass
    King 3.0 16 inch rear shocks
    King 2.0 ×4 bumps
    Camburg bedcage
    Camburg Spindles
    Camburg SUA kit
    Camburg shackles
    Deaver I96 leafs
    RCV performance axles
    ADV glass
    Camburg rear SS extended brake lines
    Solidoffroad mounts
    Coachbuilder tie rods
  11. Dec 1, 2021 at 7:40 PM
    Peeeheeuuu
    Peter
    Elk Grove, CA
    08 Silver CM 4x4
    Finally replaced the old grill with a 10-13 grill. Just waiting for a few clips ( the small rod clips on the hood latch) and I'll replace the grill insert.
    Mountun Goat, TG705, D4x4TRD and 2 others like this.
  12. Dec 3, 2021 at 1:18 PM
    ryanallaire
    ryanallaire New Member
    Ryan
    2010 CM 5.7
    drop in K&N filter, removed resonator.
    I'm loving those headlights, where did you get the body pieces to go underneath?
  13. Dec 3, 2021 at 1:24 PM
    Black@Blue19
    Black@Blue19 Old Salt
    Ken
    SE Texas
    21 SR5 TSS Onroad, 24 Camaro 2SS 6.2 L
    To much to list:)
    NICE!!!!:)
  14. Dec 3, 2021 at 8:05 PM
    Peeeheeuuu
    Peter
    Elk Grove, CA
    08 Silver CM 4x4
    Thanks. I got them off ebay along with the headlights
  15. Dec 3, 2021 at 8:06 PM
    Peeeheeuuu
    Peter
    Elk Grove, CA
    08 Silver CM 4x4
    Thanks
  16. Dec 3, 2021 at 8:52 PM
    juice77
    juice77 New Member
    Sacramento, Ca
    2019 SR5 CM TRD 4x4
    Yeee!! Can’t wait for the finished product!!
  17. Dec 4, 2021 at 9:44 AM
    ryanallaire
    Ryan
    2010 CM 5.7
    Nice, I looked them up and wow they're expensive!
  18. Dec 4, 2021 at 6:26 PM
    Peeeheeuuu
    Peter
    Elk Grove, CA
    08 Silver CM 4x4
    You and me both buddy
  19. Dec 4, 2021 at 6:28 PM
    Peeeheeuuu
    Peter
    Elk Grove, CA
    08 Silver CM 4x4
    Yeah are a bit pricey but they are worth every penny. Can't beat oem.
  20. Dec 8, 2021 at 4:18 PM
    Peeeheeuuu
    Peter
    Elk Grove, CA
    08 Silver CM 4x4
    These showed up on my door step today. Another piece of the puzzle
    Mountun Goat and TG705 like this.
  21. Dec 8, 2021 at 4:34 PM
    D4x4TRD
    D4x4TRD New Member
    Định
    Norfolk, Va
    2012 Sr5 DC TRD 4x4 Blaaaaaack baby 4.6liter
    Blacked out front grill badge Bigger tires 305/60r18 Tonneau cover
    Nice, really really nice build you got going. Beautiful. I’m so jelly. Can’t wait to see the LT setup. Good luck and have fun.
  22. Dec 8, 2021 at 7:59 PM
    Peeeheeuuu
    Peter
    Elk Grove, CA
    08 Silver CM 4x4
    Thanks. I can't wait to get everything put on.
  23. Dec 8, 2021 at 7:59 PM
    Peeeheeuuu
    Peter
    Elk Grove, CA
    08 Silver CM 4x4
    Installed my grill
  24. Dec 13, 2021 at 3:59 PM
    Peeeheeuuu
    Peter
    Elk Grove, CA
    08 Silver CM 4x4
    Both money pits and the daily
  25. Dec 13, 2021 at 4:01 PM
    worktruckwhite
    worktruckwhite bryceCtravels.com
    Charleston, SC
    2010 White Crewmax
    Great truck but definitely the best name on the forum
  26. Dec 14, 2021 at 6:19 PM
    vq35721
    vq35721 New Member
    2011 040 SR5
    Too much to list
    You missing something on that list of parts :rolleyes:
  27. Dec 14, 2021 at 7:00 PM
    Peeeheeuuu
    Peter
    Elk Grove, CA
    08 Silver CM 4x4
    I'm missing a whole bunch of things on that list of parts haha. Hopfully soon enough
  28. Dec 14, 2021 at 8:53 PM
    vq35721
    vq35721 New Member
    2011 040 SR5
    Too much to list
    oh I know that lol . I’m talking about something else :rofl:
  29. Dec 14, 2021 at 9:41 PM
    Peeeheeuuu
    Peter
    Elk Grove, CA
    08 Silver CM 4x4
    I know your talking about somthing else . I'm poor already my guy. Seriously though, I just ordered SS built front and rear bumpers and a 12k warn winch. That was the money I had planned for the supercharger. Guess I'll have to wait until next year for the supercharger
    vq35721 likes this.
  30. Dec 15, 2021 at 5:58 AM
    vq35721
    vq35721 New Member
    2011 040 SR5
    Too much to list
    That’s why it’s never a good idea to have 2 project rides hahaha. Oh yah, you joined the SSBuilt Army, you won’t be disappointed :thumbsup: That’s pretty much what I did, did the LT last year and SC this year.
