Payload Capacity
Discussion in 'Towing & Hauling' started by T Rex, Nov 13, 2020.
  1. Nov 13, 2020 at 6:39 AM
    T Rex
    T Rex [OP] New Member
    2019 Crewman Platinum
    Hello, the door sticker on my 2019 Tundra Platinum Crewmax 4x4 says maximum payload is 1172 pounds, then another sticker says that amount was reduced by 91 pounds for the step rails. I thought the Tundra in this configuration had closer to 1500 pounds before modifications. Any thoughts?
    YardBird likes this.
  2. Nov 13, 2020 at 6:49 AM
    YardBird
    YardBird Native San Diegan
    Jonesy
    2005 RCLB
  3. Nov 13, 2020 at 6:51 AM
    T Rex
    Thank you!! Glad to be here!!
  4. Nov 13, 2020 at 7:11 AM
    Sunnier
    Sunny
    San Diego, CA
    No, the DC can had more payload than the Crewmax.
  5. Nov 13, 2020 at 7:14 AM
    Shuffler
    Shuffler New Member
    NW Montana
    2011 CrewMax 4WD
    Hell, I exceed the rating every time I load up to go do things ... with a Decked unit full of stuff, and a ~375lb shell, and then more gear, I'm always over their 'limit', even with air bags. The rating is silly ... I wouldn't worry about it too much unless you're wheeling it hard with a heavy load.
  6. Nov 13, 2020 at 7:15 AM
    cnoyes72
    cnoyes72 New Member
    CT
    2018 Tundra SR5 DoubleCab 4x4
    Driver-side assist handle, extang trifect 2.0 tonneau cover
    Just do what most owners do and ignore the sticker.
  7. Nov 13, 2020 at 7:17 AM
    mountainpete
    mountainpete Explore more
    2018 Cement Crewmax TRD
    Function before sparkle.
    It's a harsh reality to think that a 2010 Dodge Caravan has more payload than the majority of half ton trucks manufactured in the last 10 years.
    snivilous and Shuffler like this.
  8. Nov 13, 2020 at 7:38 AM
    9am53
    9am53 New Member
    adam
    2015 Black RCLB 4x4
    2020 PRO headlights and grill
    if you guys got a REAL truck with a regular cab you wouldnt have this problem :D
    Half Assed likes this.
  9. Nov 13, 2020 at 7:40 AM
    Welcome from NY.
  10. Nov 13, 2020 at 10:12 AM
    Cpl_Punishment
    Cpl_Punishment Young men never die.
    Rosy
    2020 MGM SR5 CM 4X4
  11. Nov 13, 2020 at 10:18 AM
    mountainpete
  12. Nov 23, 2020 at 11:20 PM
    RyeHog
    RyeHog New Member
    2014 MGM Sr5 Tundra
    The higher trim levels will have less payload because of all the accessories and add one. My 2014 crew max Sr5 door sticker says 1360 for payload.
    9am53 and Cpl_Punishment like this.
  13. Nov 24, 2020 at 5:21 AM
    9am53
    9am53 New Member
    adam
    2015 Black RCLB 4x4
    The nicer and more SUV-like your truck is, the less truck-like the payload specs will be, pretty simple. I like to chime in and chirp because I have almost 2000 pounds of payload, but I dont have a backseat, I have a shitty stereo, I have a hard plastic armrest in the middle, non-adjustable seats etc. Its all a trade off...TANSTAAFL
    Cpl_Punishment likes this.
  14. Nov 29, 2020 at 7:29 PM
    tundraterrence
    tundraterrence New Member
    Terrence
    Winchester, TN
    2021 Tundra SR5 DC- SOLD
    I just purchased a 2021 SR DC. I wanted the reliability the Toyota affords with as much payload as I could get and still have 4x4 and a rudimentary back seat. The SR is by any account somewhat spartan but, it does everything we need it to do with a payload of 1435lbs (99 lbs subtracted for aluminum step bars and spray in bed liner). It has more than enough towing capacity for our 21' TT at 3775 empty weight and 420 hitch weight. $39k OTD price... Couldn't be happier.
    Meanjoe, Bammer and 9am53 like this.
  15. Nov 29, 2020 at 7:33 PM
    lonedrake
    lonedrake New Member
    Minnesota
    2020 TRD sport
    What are you hauling? For example....if you don't plan to haul anything over 1,200 pounds...does it even matter?
  16. Nov 30, 2020 at 4:37 AM
    Cpl_Punishment
    Rosy
    2020 MGM SR5 CM 4X4
    Which trailer?
  17. Nov 30, 2020 at 8:44 AM
    tundraterrence
    Terrence
    Winchester, TN
  18. Nov 30, 2020 at 10:06 AM
    mountainpete
  19. Nov 30, 2020 at 11:15 AM
    tundraterrence
    Terrence
    Winchester, TN
    Yes. The way it’s done it’s lite and efficient... Very easy to setup and no heavy articulating metal mechanisms
    mountainpete likes this.
  20. Dec 2, 2020 at 8:38 AM
    T Rex
    Thank you all very much for the comments and feedback. I found the payload data on page 597 of my Owners Manual. The payload capacity is organized by body type, model code, engine, drive system and bed type. So for my 2019 Crewmax, Model Code USK56L-PSTSKA, 5.7L 3UR-FE, 4x4, short bed the payload capacity a range of 1400 to 1185 pounds. My truck has a 36 gallon fuel tank and sunroof so my payload is 1185 pounds.
  21. Dec 2, 2020 at 8:39 AM
    T Rex
  22. Dec 2, 2020 at 8:41 AM
    T Rex
    I was planning on adding a truck camper or camper top. My payload is too low to add a manufactured truck camper; I would have to build it myself as light as possible.
    tundraterrence likes this.
