Parking/emergency brake not engaging
Discussion in '2.5 Gen Tundras (2014-2021)' started by shhernandez74, Mar 3, 2019.
  1. Mar 3, 2019 at 2:37 PM
    shhernandez74
    shhernandez74 [OP] New Member
    Samuel
    2017 Barcelona Red Tundra 4x4 SR5
    FRAC Driver side handle TRD Sway Bar Pop Lock Led Lights Seat Warmers Katzkin Bumper Step
    I was in Austin yesterday and had to park at on an incline. When I pressed on the parking brake it clicked on but the truck rolled and wouldn’t stop.
    Has anyone had any issues with their parking brake not engaging? Also, is there a fix?
    I looked it up and someone made a video for a second gen where they took the whole rear rotor off in order to adjust it. Is this my solution or is there an easier fix?
    I have a certified 17’ with 27k miles and doubt this will be under warranty.
  2. Mar 3, 2019 at 2:38 PM
    040Tundra
    040Tundra Teddy 2013-2019
    Aaron
    Las Vegas, NV
    040 '16 CM LTD 4x4
    Why wouldn't it be under warranty? 3 year 36k miles...
  3. Mar 3, 2019 at 2:52 PM
    shhernandez74
    Samuel
    I thought that only applies to new vehicles not certified. I will call and ask though thanks
  4. Mar 3, 2019 at 2:58 PM
    n2deep
    n2deep Pavement Princess
  5. Mar 3, 2019 at 3:59 PM
    Mal Reynolds
    Mal Reynolds New Member
    Mal
    2018 Tundra SR
    Mine is 6 months old and the parking brake sucks when I park on an incline it wanted to rolls backwards. I had them adjust it under warranty and its better.
    Update 6/5/19 Parking Brake is sucky again. Going to have to do this myself :-(
    shhernandez74[OP] likes this.
  6. Mar 3, 2019 at 4:32 PM
    Mr Swervlin
    Mr Swervlin "Yes....In Dee Face"
    O H I O
    2017 Silver Sky limited TRD Crewmax
    Line X bed liner Window tint AVS in channel vent visors Paint protection wrap Husky front & rear floor liner ESP Crewmax rear storage Console organizer and tray TRD shift knob TRD rear sway bar Thule exporter pro 500 Color matched door handles, side mirrors, and grill surround VLEDs interior/reverse/cargo Driver side grab handle 10" BAmuffler Trd pro headlights
    Had the same problem when my truck was brand new. The tech adjusted it pretty quickly. Worked great but, after 25000 miles I can tell its starting to slip again
    shhernandez74[OP] and Black Wolf like this.
  7. Mar 3, 2019 at 4:36 PM
    snarkscarbine
    snarkscarbine New Member
    Alex
    Dallas
    2014 Silver Sky CM Ltd 4x4
    Bilstein 5100s Footwell LEDs Fold-A-Cover g4 elite TRD 18s
    It’s actuslly pretty easy to adjust the drum yourself. Just takes some time. Did mine and it locks up WAY tighter now.
  8. Mar 3, 2019 at 7:37 PM
    johnvan
    johnvan OG
    john
    Rensselaer,New York
    2016 inferno SR5 DC
    I attached a pdf file for a 2015, should be the same for a '17.
    good luck,john
    Mr Swervlin likes this.
  9. Mar 3, 2019 at 7:54 PM
    shhernandez74
    Samuel
    Is the process you did the same as the one in the video?
  10. Mar 3, 2019 at 7:57 PM
    snarkscarbine
    Alex
    Dallas
    Actually used that exact video to do it.
  11. Mar 3, 2019 at 7:58 PM
    shhernandez74
    Samuel
    Thanks man I might just do this
  12. Mar 3, 2019 at 7:58 PM
    shhernandez74
    Samuel
    Got it, if the dealership doesn’t fix it I will just follow those instructions. Thanks man
    snarkscarbine[QUOTED] likes this.
  13. Aug 10, 2019 at 11:58 AM
    tahoeforrest
    tahoeforrest New Member
    For some reason my 2015 caliber does not have a shoe/star wheel adjusting hole or plug in it. I went to two different auto parts stores and looked at several calibers and none of them had any hole where I need it. Has anyone else ran into this problem? How do you adjust without the hole?
  14. Aug 10, 2019 at 12:11 PM
    Getmeacoors
    Getmeacoors From the far Norcal
    California
    2019 sport 4x4 MGM
    Alot
    Speaking of parking brakes I found my parking brake line was rubbing on my leaf springs and it had a decent groove warn into it so everyone might want to check theres I fixed mine by moving bracket and adding plastic tubing
    Long shot but could be your issue?
  15. Aug 11, 2019 at 4:10 AM
    Mal Reynolds
    Mal
    2018 Tundra SR
    Tahoe it's all in the disk. The disk has a little drum brake in the hub.
  16. Jul 12, 2021 at 2:48 PM
    IndianaGeologist
    IndianaGeologist New Member
    Too prove to this forum I actually use the search feature (on occasion) I'm posting to this older thread ;).
    My new '21 SR5 has 5k miles on it and the e-brake won't hold my truck on my slightly inclined driveway. I'm taking it to the dealer for adjustment this week, but wanted to let you fellow new owners to be on the lookout for this. Could be a safety issue if you live in states with topography.
    Tundrastruck91 likes this.
  17. Jul 12, 2021 at 7:57 PM
    PA452
    PA452 New Member
    2021 Tundra SR5 CM TRD O/R
    Back when I had my Tacomas, I feel like I had always read that the e-brake auto-adjusted simply by using it. I would have thought they'd have used something similar on the Tundra.
    Mine has certainly slipped, but I do find if I just push it down more it will hold.
    On another semi-related note, I hate the toggle-style pedal for working the e-brake. It's a stupid system. Ever bumped that pedal getting out of the truck and had the brake come off? I have. I really liked the e-brake on my 2nd gen manual transmission Tacoma, the pull style to the lower right of the steering wheel. But if they're going to use a pedal for the e-brake, they should've used a release latch or something, instead of having it so if you bump the pedal on the way out the e-brake disengages.
    IndianaGeologist likes this.
  18. Jul 12, 2021 at 8:04 PM
    OnespeedTRD
    OnespeedTRD New Member
    Don
    San Diego
    2020 Tundra Limited TRD Off-Road
    275/70r18 Cooper AT3 XLT on SCS Ray 10s, Eibach Coilovers, DD 12" Exhaust, AJT Blackout Kit, Truxedo Pro X15, paint match/chrome delete.
    Mine has sucked since day one. I had the dealership adjust it and they claimed they fixed it (they didn't). I bet all they did was turn the adjuster underneath where the driver's seat is. That really does nothing but tighten the cable. I think the only way to truly fix it is to do the method from the video mentioned earlier. I'll do it one day when I'm super bored.
  19. Jul 14, 2021 at 11:47 AM
    IndianaGeologist
    Took the truck to the dealer and was told the e-brake doesn't need to stop the truck on an incline while in neutral and that I should just put it in park....yeah then what the hell is the e-brake for if it can't stop the truck?! Then he told me that they wouldn't be able to adjust it and it's all digital. :rofl:
    I made him write my observation down on the ticket for the technician. Got the truck back today and on the ticket it shows they adjusted the rear brake shoes and parking break cable. Truck now holds full stop on my driveway in neutral.
    :thumbsup:
  20. Jul 14, 2021 at 12:05 PM
    PA452
    PA452 New Member
    Nice.
    I like to apply the e-brake on my vehicles while in neutral, let off the brake until the vehicle settles, then put it in park. That way, especially if I'm on an incline, the weight of the vehicle is principally being held by the brake, not the pawl or whatever is used when the transmission is put in park. I figure that has to be better for the transmission parking pawl, as when I go to leave the truck will shift out of park pretty effortlessly rather than pulling it out of that position against a bunch of pressure.
  21. Jul 14, 2021 at 12:10 PM
    Cpl_Punishment
    Cpl_Punishment Young men never die.
    Rosy
    2020 MGM SR5 CM 4X4
    I do the same thing. Much cheaper and easier to replace brakes than a transmission.
    Msquare and IndianaGeologist like this.
  22. Feb 9, 2023 at 12:12 PM
    olshaggy
    olshaggy New Member
    Andrew
    USA
    2016 regular cab long bed 4WD SR
    The parking brake doesn't hold on my 2016 on even a slight incline when I've got the transmission in neutral, so based on guidance from this forum, the other day I jacked up the rear wheels, opened up the left under-dash panel, and adjusted the nuts on the parking brake cable so the wheels locked when the pedal was depressed to 6-9 clicks. Easy enough, but the brake still wouldn't hold the truck, so I took it into a shop yesterday. They said they adjusted the star wheel to expand the brake shoes as much as they could (as this oft-shared video shows), but there was no improvement at all. Now they're claiming that I shouldn't actually expect the parking brake to hold the truck on an incline in neutral. I've never had a vehicle that couldn't do that.
    Are they full of it? How many of ya'll have been able to adjust yours to hold solidly on a substantial incline in neutral? How 'bout when you're carrying a heavy payload?
  23. Feb 9, 2023 at 1:13 PM
    Cpl_Punishment
    Rosy
    2020 MGM SR5 CM 4X4
    I believe they're one of the requirements of the SAE towing capacity calculation. The parking brake has to be able to hold the truck and trailer on a certain grade.
    olshaggy[QUOTED] likes this.
  24. Feb 9, 2023 at 1:17 PM
    olshaggy
    olshaggy New Member
    Andrew
    USA
    Would love to see that documented if anyone knows where to find it.
  25. Feb 9, 2023 at 1:26 PM
    olshaggy
    olshaggy New Member
    Andrew
    USA
    Couldn't get the actual SEA document because it's behind a paywall, but you're right. SAE J2807 standards say the parking brake needs to be able to hold the truck at max towing capacity pointing both up and down on a 12% grade. Unfortunately, there doesn't appear to be an equivalent standard for max payload.
    Cpl_Punishment likes this.
  26. Feb 9, 2023 at 2:20 PM
    Cpl_Punishment
    Rosy
    2020 MGM SR5 CM 4X4
    Could you assume 10% of the max towing capacity for a "typical" tongue weight?
  27. Feb 9, 2023 at 2:32 PM
    olshaggy
    olshaggy New Member
    Andrew
    USA
    Yeah, looks like 10-15% is the typical tongue weight. My truck is rated to tow 10,200 lbs, but the max payload is 1,985 (nearly 20%) and I expect to have it loaded to within a few hundred pounds of that limit. Would be nice to feel confident in the brakes' ability to hold on a hill, but think I'm going to plan to carry wheel chocks too...
  28. Feb 9, 2023 at 3:17 PM
    Cpl_Punishment
    Rosy
    2020 MGM SR5 CM 4X4
    What year is your truck?
  29. Feb 9, 2023 at 3:21 PM
    Wheresmytranscooler
    Wheresmytranscooler New Member
    Brad
    2019 Tundra SR5 TRD
    Another thing to try after adjustment would be to seat the shoes into the drum surface of the rotor. Maybe coast down a long hill and slightly apply Ebrake.
  30. Feb 9, 2023 at 3:38 PM
    olshaggy
    olshaggy New Member
    Andrew
    USA
    2016 (just updated my profile to show that)
    Just went through the bedding process for new brakes on my bike. Will keep that in mind once I've gotten the star wheels properly adjusted.
