Papasmurf's 07 4x4 LT Build Thread and now with more other stuff too!
Discussion in '2nd Gen Builds (2007-2013)' started by papasmurf, Jan 11, 2017.
  1. Feb 12, 2020 at 12:47 PM
    #631
    papasmurf
    papasmurf [OP] Savage Fabrication
    Bruce
    San Diego
    2007 4x4 Tundra
    07 Silver Sky 4x4 | Total Chaos LT | 2.5 King Coil overs & Bypasses | Camburg Bed Cage | 3.0 King Bypasses | 2.0 King Bumps | Custom Deavers | Nitro 4.88's | ARB Locker | Demello Sliders | 17" Double Standards | BFGKO2 37's |
    Yes it will! Thats why i got it :)
    Rica25 likes this.
  2. Mar 16, 2020 at 9:47 AM
    #632
    papasmurf
    Bruce
    San Diego
    2007 4x4 Tundra
    So I'm up to my normal shenanigans again... some updates going down on the truck prior to Sedona
    Things that are getting done:
    New custom power steering setup to include the following
    • New Toyota Rack w upgrade ES bushings
    • New Toyota pump
    • custom PS Hayden cooler
    • 1qt finned aluminum ps resi with filter
    • customer AN lines and fittings
    Custom hard-mounted lower control arms
    new TC lower control arm bushings
    rear shock boots
    AIP delete kit
    Wrapped headers
    SolidOffroad Engine mounts @Bonzen
    Pro Eagle 3 ton with mount
    New hubs and bearings for front knuckles
    New TC LCA uniballs
    Custom Energy suspension front body mounts with larger grade 8 hardware
    new bumper grade 8 mounting hardware
    CDZ steering wheel
    PRP race seats
    custom seat mounts
    PRP harnesses
    Custom Harness bar
    Custom SS Brake lines with banjo fittings for both front and rear (replaces the TC lines, and the little hard line next to the caliper, and the rear small rubber section)
    Some has been done some is still in the process
    See pics below
  3. Mar 16, 2020 at 12:09 PM
    #633
    ca562
    ca562 New Member
    ryan
    Looking forward to seeing how that steering wheel install goes!
    Especially for us 2Gen guys. Do you just transfer over the OEM center section/airbag from your original steering wheel?
    I was hoping we could somehow upgrade to the 3rd gen wheel at the same time.
    Rica25 and papasmurf[QUOTED][OP] like this.
  4. Mar 16, 2020 at 2:25 PM
    #634
    papasmurf
    Bruce
    San Diego
    2007 4x4 Tundra
    yes center section transfers over, im sure you could do a 3rd gen swap but im not sure for the control buttons etc how that would work.
  5. Mar 16, 2020 at 2:32 PM
    #635
    TheBeast The Beach
    nice ! post pics when you get the steering wheel installed.
    papasmurf[OP] likes this.
  6. Mar 16, 2020 at 6:39 PM
    #636
    papasmurf
    Bruce
    San Diego
    2007 4x4 Tundra
    Made some progress on the truck
    All my lines are done! Just have to mount the cooler, but it’s plumbed
    The shiny lines are 2000psi burst AN lines for return and pump feed, the dull line and the silver fittings (steel) are high pressure 9000psi burst AN
    Uses an XRP 491615 M16 x 1.5 6AN to oring fitting on the rack side and an AN 6 bung welded to the high-pressure feed tube on the pump side
  7. Aug 30, 2020 at 1:40 PM
    #637
    papasmurf
    Bruce
    San Diego
    2007 4x4 Tundra
    Updates.. not my truck but ive been busy building some other trucks... here are two time lapse vids of some trucks I've build in the last 4 weeks.
    Enjoy!
    First one is a full ADS / MCM / Deaver MT2 build
    Time-lapse of a full MT2 Build on a 2019 tundra (Video has no sound) Parts include: 2.5 ADS coilovers with clickers 2.5 remote resi ADS front bypasses 2.5 piggyback resi ADS Rear Bypasses ADS 2.0 hydro bumps in the rear MCM Upper Control Arms MCM Bypass Hoops Deaver U748 Leafs Extended TC Shackles
    Time-lapse of a full MT2 Build on a third-gen tundra (Video has no sound) Parts include: 3.0 Icon coilovers with clickers 2.5 remote resi Icon front bypasses 2.5 piggyback resi Icon Rear Bypasses Icon 2.0 hydro bumps in the rear Icon Upper Control Arms Icon Bypass Hoops Body Mount Chop Total Chaos Spindle Gussets Evil Manufacturing Front Bumper Mazula Rear Bumper 2018+ Tundra TRD Headlights All done in three days.
  8. Aug 30, 2020 at 2:03 PM
    #638
    Inquiringone
    Ter
    NorCal 408
    Not many yet, mostly stock.
    You always have the coolest stuff
    @papasmurf , and mods.:drool::drool:
    jc153 and papasmurf[QUOTED][OP] like this.
  9. Aug 30, 2020 at 2:25 PM
    #639
    Sunnier
    Sunny
    San Diego, CA
    Dilly got a 3rd gen?!! Cool!
  10. Aug 31, 2020 at 7:06 AM
    #640
    papasmurf
    Bruce
    San Diego
    2007 4x4 Tundra
    Sure did, and now its full MT2 with 37's it's pretty sweet!!
  11. Aug 31, 2020 at 11:10 AM
    #641
    Sunnier
    Sunny
    San Diego, CA
    Any before/after pics of these trucks you’ve done, Bruce?!! I’d love to see ‘em, transformations are always impressive!
  12. Aug 31, 2020 at 11:27 AM
    #642
    Ace402
    Ace402 New Member
    2011 Tundra 4x4 SR5
    ADS 2.5 RR front and rear. MCM UCA & Shackles
    Any pics of the installed steering wheel?
  13. Aug 31, 2020 at 11:43 AM
    #643
    papasmurf
    Bruce
    San Diego
    2007 4x4 Tundra
    best i got at the moment, i can take some more later...
    Kiddnapped Tundra, saybng and Sunnier like this.
  14. Aug 31, 2020 at 11:50 AM
    #644
    smslavin
    smslavin Behind a lens...
    Hudson Valley
    2016 Tundra CrewMax SR5
    Some stuff
    so glad i'm not the only that works on their truck in osha approved footwear... :cheers:
  15. Aug 31, 2020 at 11:53 AM
    #645
    papasmurf
    Bruce
    San Diego
    2007 4x4 Tundra
    safety flops are the only way!
  16. Aug 31, 2020 at 12:32 PM
    #646
    Ace402
    Ace402 New Member
    2011 Tundra 4x4 SR5
    Thanks
    papasmurf[QUOTED][OP] likes this.
  17. Aug 31, 2020 at 1:37 PM
    #647
    jc153
    jc153 Speed-ish Glamper
    San Diego
    2009 Tundra Ltd CM 4x4
    TC Front Long Travel, ADV Glass Fenders & Bedsides, TC Spindle Gussets & King LT Coilovers, RCV Axles, DuroBumps, CB Steering & Carrier Bearing Drop Kit, SDHQ ABS Sensor Shields, Rear 3.0 ADS Triple Bypasses w/MCM Fab Under Bed Shock Mount Relocation, SUA Deaver I96HD Springs & TC Shackles, MCM Fab Rear Hydro Bumpstop Kit, Solid Offroad Engine Mounts, 17" Method Standards, 37/12.5/17 Toyo RT's, Nitro 488 Gears w/Auburn LSD, Evil Off Road Bumpers, RCI Skid Plates, White Knuckle Sliders, Dirty Deeds Ind. BAMuffler 8" Catback, Baja Designs Lighting, SwitchPros Controller, Custom PS Cooler Relocation Kit, Custom Dual Battery Setup
    You can just look in your driveway for an after pic of one of them.;)
  18. Aug 31, 2020 at 1:44 PM
    #648
    papasmurf
    Bruce
    San Diego
    2007 4x4 Tundra
    hahaha nope only Tundra at the house right now is mine, now you may see a few jeeps in my drive way.... :anonymous:
    jc153[QUOTED] and Sunnier like this.
  19. Aug 31, 2020 at 1:50 PM
    #649
    Sunnier
    Sunny
    San Diego, CA
    EVERY day!!! I’m excited for the hot weather to pass so I can DRIVE it again!!
    Uh-oh. Don’t let the heeps pile up up in the yard....
  20. Aug 31, 2020 at 2:07 PM
    #650
    papasmurf
    Bruce
    San Diego
    2007 4x4 Tundra
    too late there is two already I'm parking them far away from each other because i don't want them to mate and spawn more!
    Sunnier[QUOTED] and osidepunker like this.
  21. Aug 31, 2020 at 2:10 PM
    #651
    Sunnier
    Sunny
    San Diego, CA
    Maybe park the better of the two near your truck; if it goes just right, we could maybe see an early style land cruiser, and that would be a cool mutt. :monocle:
  22. Aug 31, 2020 at 2:15 PM
    #652
    fisherman951
    fisherman951 MT dreams
    Tony
    2017 crewmax 4x4
    Jeep and Toyota already handled their business lol
  23. Oct 18, 2020 at 7:05 AM
    #653
    Trdwillie14
    Trdwillie14 New Member
    Billy
    2014 trd off road
    2.5 fox 2.5 ads triple bypass T/C uppers Nfab front bumper Westin rear Bajas Rci skids All pro sliders Icon rxt leafs Stt pros Method 701s 37 Mickey Thompson
  24. Oct 18, 2020 at 7:28 PM
    #654
    SC_TRD
    SC_TRD Big BASTRD 4x4 Enthusiast
    Colin
    Round Rock, Tx
    2012 CrewMax & 2008 Sequoia
    @papasmurf
    Amazing build man! After getting tagged for those headlights my Sunday morning became toast, and all I did was read and lurk for far too long haha.
    I am curious, what front fiberglass fenders did you use? Are they also the advanced fiberglass fenders? I have seen too many people talk about the best fiberglass for the 3rd Gen, but have not been able to get a good consensus for the 2nd gen.
    cheers, and thank you!
    papasmurf[OP], 831Tun and Trdwillie14 like this.
  25. Oct 18, 2020 at 8:47 PM
    #655
    papasmurf
    Bruce
    San Diego
    2007 4x4 Tundra
    thanks bro!! So front fenders are mcneils and I don’t recommend figment wasn’t great... not awful but I like the body lines of the advanced better... my bedsides are advanced fiberglass, I love the body lines of them... debated on switching fronts to advanced but I’d loose my beer shelf if I did :rofl::rofl::rofl:
  26. Oct 18, 2020 at 9:24 PM
    #656
    nb_nielsen
    nb_nielsen New Member
    2012 Tundra double cab
    I love the build brother! If your serious about switching front fiberglass I would be interested in buying your front fenders!!! About to pull the trigger on a mid travel set up and ran my truck through the car wash.... the pressure washers found the bonds from when the previous owner hit a deer and under the bondo was rust. Time for an upgrade in my eyes!
  27. Oct 19, 2020 at 7:02 AM
    #657
    papasmurf
    Bruce
    San Diego
    2007 4x4 Tundra
    I'll let you know if I decide to do that, sucks bout your fenders... but yup time to upgrade! id do advanced fiberglass fenders if you are looking they have great body lines
  28. Oct 19, 2020 at 7:22 AM
    #658
    osidepunker
    osidepunker OsidePunker
    Alex
    2013 Tundra DC 4x4
    Full LT, full armor, fully self contained Speed Glamper
    You like my body Bruce??
    Sunnier and SC_TRD like this.
  29. Oct 19, 2020 at 7:31 AM
    #659
    papasmurf
    Bruce
    San Diego
    2007 4x4 Tundra
    :anonymous:
    :cheers:
  30. Apr 26, 2021 at 5:20 PM
    #660
    papasmurf
    Bruce
    San Diego
    2007 4x4 Tundra
    Everyone should stand by I have some new and exciting updates coming lots of refresh and changes to the truck coming in the next few months... also sorry I'm not on much I've been busy with life and work lately.
