Pano Roof Drain Tube
Discussion in '3rd Gen Tundras (2022+)' started by TallulahTundra, Jan 10, 2025.
  1. Jan 10, 2025 at 2:46 PM
    TallulahTundra
    TallulahTundra [OP] New Member
    Liz and Jose
    Michigan
    2023 1794 SB MGM
    Can someone direct me to the drain tube in the Pano roof? Can’t seem to locate it. Thanks.
  2. Jan 10, 2025 at 3:48 PM
    Raven67
    Raven67 It wasn't me.
    Kentucky
    24 Limited, 21 Redeye
    I believe there's one in each A pillar. Both front corners of sunroof.
    TallulahTundra[OP] and CringyDad like this.
  3. Jan 11, 2025 at 5:13 AM
    TallulahTundra
    Liz and Jose
    Michigan
    2023 1794 SB MGM
    Thanks. I've been up there peeking around the last few days and don't see it.
  4. Jan 11, 2025 at 8:38 AM
    Observer
    Observer New Member
    This is the closest I could find. Be aware from what I've searched you may have drain ports at the back corners also. This is for Tacoma. Hope this somewhat helps.
    https://www.youtube.com/watch?v=MOQWehtoGyw
    This guy goes over his leak on the 3rd gen tundra but video and audio are not the best quality and I had to watch with closed caption to understand what he was saying. . www.youtube.com/watch?v=bmk7EOwPt0c
    Korj26 likes this.
  5. Jan 12, 2025 at 8:23 AM
    TallulahTundra
    Liz and Jose
    Michigan
    2023 1794 SB MGM
    Thank you so much! I watched the videos and will try to get back up there today.
  6. Jan 12, 2025 at 7:36 PM
    Rockpig
    Rockpig You did what?
    08 Limited
    I know of one at the C pillar on the driver side, I'd think the same is on the passenger side. I've had the A pillar trim removed, don't recall seeing a tube there and haven't seen one under the dash or at the firewall in the engine bay. Bought this to clean it out, haven't used it yet.
    https://www.amazon.com/gp/product/B0DFPRVBN9?ie=UTF8&th=1
    Green tube in the pic is the drain.
    TallulahTundra[OP] likes this.
  7. Jan 12, 2025 at 7:51 PM
    gdisarray
    gdisarray Short term member
    2023 Tundra Limited HV
    Tint and wheels. Decked box in the bed. S and B Cold Air filters under the hood. Shiftpower throttle response controller.
    I'd try compressed air first if it were me.
  8. Jan 13, 2025 at 7:27 AM
    TallulahTundra
    Liz and Jose
    Michigan
    2023 1794 SB MGM
    Oh nice. I will check the C Pillar. Thank you!
