Paint difference debadging 5 year old Tundra?
Discussion in 'Detailing' started by Bigdog, Jan 11, 2019.
  1. Jan 11, 2019 at 4:16 AM
    Bigdog
    Bigdog [OP] New Member
    2014 sr5 tundra 4x4
    7 inch pro comp lift 37 12.5 nitro ridge grapplers 639 k&n cai hyperforce interceptor tuner
    I want to debadge but my BigRed is a 14 I'm worried it will show the paint difference!any recommendations?
    Rica25 and Mnorris1206 like this.
  2. Jan 11, 2019 at 4:27 AM
    Mnorris1206
    08 tundra
    My truck is an 08 just debadged it this last summer .The only thing I can tell you is the remainder of the residue may be harder to get clean make sure to have a good eraser wheel handy. I also had to buff the areas a little but my truck is much older .I say do it.
    ColoradoTJ and Black Wolf like this.
  3. Jan 11, 2019 at 5:24 AM
    Sas
    Sas Humor is everywhere
    OKC, OK
    '17 SR5 CM TSS 4WD MGM 5.7 FF
    Lost track after #1.
    Well, if there is a difference at least you'll have an outline where they go if you want to stick them back on.
    Krezz, ColoradoTJ, Black Wolf and 5 others like this.
  4. Jan 11, 2019 at 5:51 AM
    JoshuaA
    JoshuaA Canuck Member
    Southern Ontario
    Blaaack 2.5G
    After you clay, polish, and wax the entire truck, it'll blend but you'll have to keep it up because it's had 4y+ of UV exposure on the exposed clearcoat/paint. You can do polish/wax touchups just on the where the badges were in-between full jobs if you start to see badge shadows.
    At worse, put on black badges.
  5. Jan 11, 2019 at 8:24 AM
    Crunch527
    Iowa
    TRD Supercharger/BAM
    Use Goo Gone to get the glue off the paint...you shouldn't need any buffing wheels or any erasers...the paint and clear are real thin as it is.
    Mnorris1206 likes this.
  6. Jan 11, 2019 at 8:34 AM
    Mnorris1206
    08 tundra
    Did this work for you ? I couldn't get that stuff off for nothing .Their was alot on it because I was told to keep the fishing line close to the badge
  7. Jan 11, 2019 at 8:37 AM
    AZTundra
    Paul
    Phoenix, AZ
    I used WD40. It cleans up the goo and won't mess with the paint.
    Mnorris1206[QUOTED] likes this.
  8. Jan 11, 2019 at 4:13 PM
    Boudin
    Boudin New Member
    Louisiana
    Tundra#4
    I debadged my 2011 MGM recently and there's a difference in paint color. Not really noticeable unless up close though...
  9. Jan 11, 2019 at 4:55 PM
    Bigdog
    2014 sr5 tundra 4x4
    Thanks for the feed back once weather gets warmer like out of teens I'll get it done
  10. Jan 18, 2019 at 4:29 AM
    Mnorris1206
    08 tundra
    If you are getting a new badge set they will have new tape already on them if your reinstalling I used 3m tape. Its what most brand use on the trim. But you will have to mark where they go I suggest like painters tape all the way around the badge even before you start to remove it.
  11. Jan 18, 2019 at 4:51 AM
    15whtrd
    15whtrd Mr. Blonde
    Make a template and or take measurements before you remove.
  12. Jan 18, 2019 at 8:48 AM
    dmiller
    dmiller New Member
    Dusty
    Guntersville, AL
    '18 MGM CM SR5 XSP
    BD Squadron Sport Amber WC Fogs
    I'm good with my emblem badges, they're blacked out already... But, I'd love to remove the bedside stickers. The red X in the XSP decal is a little Z71ish for me. How do I remove those without messing up the paint? My truck is a year old, so hopefully it won't show a difference.
