P0441 & P0455
Discussion in '1st Gen Tundras (2000-2006)' started by theplanesaidso, Oct 17, 2020.
  1. Oct 17, 2020 at 12:53 PM
    theplanesaidso
    theplanesaidso [OP] New Member
    Hey friends,
    2005 Sequoia, SR5, 4x4, 182k, meticulously maintained.
    while wife was driving the CEL, VSC OFF, and VSC TRAC came on. Hooked up my OBDII and pulled codes P0441 & P0455. I did do some digging and see that the gas cap had been an issue, it was filled recently, but had been driven probably 3 or 4 times and sitting at 3/4 tank, cap seemed fine when I checked it. Anyways, the scanner let me clear the codes and I started it back up and idled it to temp 3 times now with no recurring codes. Have you seem this before? Is it likely it just caught something for a split second, or am I likely going to start seeing it come back and if so where should I start on that rabbit trail??
    Also, if it matters I live in a cold/dry environment and the season has just started changing rapidly, getting below freezing now and very dry, the vehicle is kept in a 60* garage.
    Thanks!
  2. Oct 17, 2020 at 1:16 PM
    Professional Hand Model
    Hand Protectors
    Buy a new Toyota Gas Cap ($20) and put it on. They do wear out over time and throw codes. Happened to me a while back and a new cap fix the problem. Its suggested to install new caps 5-10 years.
    N84434 likes this.
  3. Oct 17, 2020 at 1:18 PM
    theplanesaidso
    Awesome, if it comes back I’ll try that first, thanks!!
  4. Oct 17, 2020 at 4:36 PM
    bassman417
    bassman417 "Tundra Time". My favorite time of day...
    Paul
    Las Vegas
    2004 DC 2wd Imperial Jade
  5. Oct 17, 2020 at 7:05 PM
    artsr2002
    artsr2002 2005 Tundra DC SR5
    'Yonder
    Get locking cap :)
