P0156 & P0158 codes and O2 sensors...
Discussion in '1st Gen Tundras (2000-2006)' started by jnevill, Nov 9, 2018.
  1. Nov 9, 2018 at 9:45 AM
    jnevill
    jnevill [OP] New Member
    2005 Tundra SR5 TRD 2wd
    Stereo, steps, more stereo
    Hey guys, yep, I got the dreaded "Bank 2 Sensor 2" error code, replaced the sensor, within 100 miles it threw the code again. Bought a second 2/2 sensor, put that in, again, within 100 miles, I get P0156 & P0158 codes. I am going to change Bank 2 Sensor 1 tomorrow, and since I am under there and have a spare anyway, will do bank 1 sensor 2. I will drive it to work all week and report back if that fixes it, I also plan on cleaning the throttle body and MAF (and probably the K&N drop in too) while I am at it.
    Like I said, I will report back if that cures it, so we have a solid reference on the forum for future searches, mine didn't turn up much.
    Any pointers while I am doing all this wrenching?
    Thanks in advance!
  2. Nov 9, 2018 at 3:36 PM
    Professional Hand Model
    Professional Hand Model Fred Brookes
    2002 Tundra SR5 4WD
    Aluminum sideboxes
    Maybe your K&N filter is causing the problems? Try running a paper filter.
  3. Nov 10, 2018 at 5:05 PM
    jnevill
    Ok, the #1 sensor was a b1tch, but it is replaced. So, both bank 2 sensors are new, cleane the MAF, the throttle body (it was BLACK, I used the forum method of spraying the cleaner on a rag and wiping), new PCV just because, wiper blades (THAT should fix the cel!!), a full tank of fresh gas, reset the codes, now to drive it to work all week. That’ll be 250 miles, if it is going to go off again it should this week.
  4. Nov 10, 2018 at 5:09 PM
    2002 Tundra SR5 4WD
    Aluminum sideboxes
    Did you change your blinker fluid?
    Good on ya for the PCV Valve change out. How’d it look? Gunky?
    Mine was when I did my valve gasket changes.
    That K&N filter still on? Never had one, but heard bad things in long term.
  5. Nov 10, 2018 at 6:54 PM
    Grey Wolf
    Grey Wolf Howling Grey Wolf Cub
    Aurora CO
    2007 Slate Metallic 5.7L Tundra DC SR5 4X4
    18"X9" FN BFD's rims, 295/70R/18E Cooper Discoverer STT Pro's, and S/T Maxx's, Old Man EMU coil-overs/shocks. Toytec shackles. Exhaust Pro, Body Armor Rock Steps, Smittybilt X20 winch, DV8 winch bumper, RCI skids.
    Been using K&N 's since the mid 70's with zero issues. My current K&N has been in my Tundra for almost 4 years now. MAF clean as a whistle. Lot's of bad info out there concerning K&N's.
  6. Nov 11, 2018 at 7:32 AM
    2002 Tundra SR5 4WD
    Aluminum sideboxes
    Good info. Thanks for the feedback.
    Grey Wolf likes this.
  7. Nov 11, 2018 at 7:49 AM
    Grey Wolf
    Aurora CO
    Over oiling can potentially cause MAF issues but following directions and carefully applying a thin layer of oil there will be nothing to be concerned about. :thumbsup: O2 sensors don't last forever and will fail eventually. If one of mine ever fails I'll replace all of them at the same.
  8. Nov 11, 2018 at 8:06 AM
    2002 Tundra SR5 4WD
    Aluminum sideboxes
    I’ve had 2 go bad on the 02’. Drove a year without replacing them as my mechanic said its not a big deal and the only drawback is losing 1-2mpg.
    I didn’t realize the cat converters could be effected negatively (possibly).
    Anyways, you right about replacing them all simultaneously.
  9. Nov 11, 2018 at 12:11 PM
    jnevill
    I’ve been using K&N’s since my 5.0 in 95, I’ve never had a problem with them. Cars, trucks and bikes, FI and carb’d. Having driven a little yesterday, it does feel like cleaning the TB may have helped, but it could be wishful thinking too. Going to put a few miles on it today, fingers crossed.
  10. Nov 13, 2018 at 8:11 AM
    jnevill
    All right, I have 120 miles on the new O2 sensor, previously the CEL would come on in 50-60 miles, so far so good.
    For future reference, at 130k miles my 2005 4.7 CEL came on, error code was P0158 (bank 2 sensor 2), I replaced the sensor and cleared the code, 50 miles later it came back on. Replaced the sensor again, cleared the code, came on again. Replaced the bank 2 sensor 1 O2 sensor, 120 miles later, still good.
    I will update if there are any changes, but as of right now, my fingers are crossed!
