P0022 ERROR CODE HELP :(
Discussion in '1st Gen Tundras (2000-2006)' started by Meyatchy, Sep 1, 2018.
  1. Sep 1, 2018 at 7:25 PM
    Meyatchy
    Meyatchy [OP] New Member
    2006 tundra access cab
    Well I'm back for everyone's expertise once again my 2006 Tundra access cab 4.0 has an error code in my check engine light came on and it was a p0022 are there any easy checks and things I could do to try to diagnose it
  2. Sep 1, 2018 at 7:32 PM
    Meyatchy
    Oil changed a month ago, still golden, not idling rough or sound any different, no leaking anywhere either. Fuel guage right in the middle, oil wasnt low.
  3. Sep 1, 2018 at 7:38 PM
    Casper421
    In the woods
    06 DC
    I’ve read about this on tacomaworld, fjcruiserforums, and T4r since they have the same 4.0 v6. Search those sites and there are tons of threads about that p0022 code. Wish I could be more help but haven’t experienced this in my 13 4runner.
  4. Sep 1, 2018 at 7:43 PM
    Meyatchy
    Here was the exact code reading
  5. Sep 1, 2018 at 7:47 PM
    LML 3500HD
  6. Sep 1, 2018 at 7:53 PM
    Casper421
    In the woods
    06 DC
  7. Sep 1, 2018 at 8:09 PM
    LML 3500HD
  8. Sep 1, 2018 at 8:14 PM
    Meyatchy
    Yea,saw that one earlier today when i was researching. Im going to test the vvts and maybe just replace them to start...
    ColoradoTJ likes this.
  9. Sep 1, 2018 at 8:16 PM
    LML 3500HD
    Just checking, but oil level is good right? Figured so since you know the color of the oil.
  10. Sep 1, 2018 at 8:20 PM
    Meyatchy
    Yea, still golden and was changed about a month ago
  11. Sep 1, 2018 at 8:21 PM
    Meyatchy
    And idles fine, sounds fine,,,thats what had me leaning to the vvt sensor
  12. Sep 1, 2018 at 8:38 PM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
  13. Sep 1, 2018 at 9:25 PM
    Meyatchy
    Great,,TY. Sone of this is out of my league maybe tho :)
  14. Sep 1, 2018 at 11:12 PM
    LML 3500HD
  15. Sep 2, 2018 at 5:10 PM
    Meyatchy
    Well, pulled the battery terminal to reset the code, drove it a few times, started it multiple times and CEL stayed off...i did notice when i first started it it hangs around 1000rpm, then dropped to 750 when coasting at steady speed of about 35, but at one point it did dip to 500 when in drive but stopped
  16. Nov 30, 2022 at 5:34 PM
    Thisisdumb
    Thisisdumb New Member
    This happened to me about 30 miles after an oil change. 4lo flashing, check engine, and P0022 code. Sounded like engine was knocking too. Took apart oil filter and sure enough the filter had collapsed as someone had thrown out the metal support that goes inside the filter. Rechanged oil and got new support piece and she’s back to normal.
    Tundra2 likes this.
  17. Nov 30, 2022 at 5:38 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Is that an OEM filter? I'm unfamiliar with the paper "insert" filters like that. I've only changed two similar to that my entire life. Once on a dodge caravan, and once on a Pontiac G6
    shifty` likes this.
  18. Nov 30, 2022 at 6:07 PM
    shifty` Our private little trip to hell
    Maybe this is something they do with the newer Tundras, and @Thisisdumb has a newer Tundra, but doesn't realize this thread is in the 1st Gen forum which is leaving us 2000-2006 owners confused af.
    My wife had this in her 2012 Highlander. I kinda like the cartridge setup, but the OEM canned filters we use in our 1st Gens are way faster to install/uninstall with no wrench, and that's more appealing to me than the cartridges.
    Edit: I'm doubting that Korean-made filter is genuine OEM Toyota too. I'd definitely be using genuine OEM replacements if it were me, and you'd never see crap like that.
    Tundra2[QUOTED] likes this.
  19. Nov 30, 2022 at 6:42 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    I've read threads here on the 2/2.5 gen tubdras talking about the TRD oil filter or regular oil filter. I believe they were filter media like that. Cartridges as you call them just makes me think of...
    :infantry:
    I liked the oil filter thing on the dodge because it was right on top of the engine, and didn't make a mess, but the pontiac.... fuck that car. Anyways... I digress.
    I prefer the canisters like we have.
    shifty`[QUOTED] likes this.
