Overwhelmed looking for an OBD2 tool
Discussion in 'Electrical' started by reconrick1, Aug 15, 2021.
  1. Aug 15, 2021 at 10:50 AM
    reconrick1
    reconrick1 [OP] New Member
    North MS
    2020 Tundra SR5 4x4
    Really wanting to get my own OBD2 reader/programmer. But usually after looking at the 100s out there from $20 to $4000, I just get overwhelmed and stop looking.
    I’m a shade tree mechanic and seeing this as a necessity in the tool box moving forward. Up to this point been taking vehicles to auto zone for a free read.
    So asking for suggestions from someone that have experience, especially with the 3rd generation tundra. Not so much brand as functions you can’t be without. Budget about $400, but not in stone.
    Also looking for compatibility to my wife’s Toyota CH-R and our 2015 Honda.
    French Avocado likes this.
  2. Aug 15, 2021 at 10:53 AM
    TucsonTundra1794
    Anthony
    Tucson, AZ
    2023 1794 Edition TRD Package
    What functions are you looking for? I currently have 3 that I swap between depending on what I need. Scan gauge 2 is usually a favorite and very simple to use.
  3. Aug 15, 2021 at 10:56 AM
    reconrick1
    North MS
    2020 Tundra SR5 4x4
    That’s the problem I have, not really sure what functions I need, never having used one. I’ve considered just getting the basic and upgrade if it doesn’t do what I need.
  4. Aug 15, 2021 at 11:07 AM
    reconrick1
    North MS
    2020 Tundra SR5 4x4
    Just wanting to use for troubleshooting, not necessarily connected all the time. I okay with something that even connects to a laptop if it has more uses.
    When I try to research, I find things like ABS bleeding and TPMS recalibration, becomes too much
  5. Aug 15, 2021 at 11:08 AM
    TucsonTundra1794
    Anthony
    Tucson, AZ
    Scan gauge 2 sounds like what you want. Bunch of cool features like monitoring Temps and sensors and the ability to read and clear check engine codes. It's small and most people attach them to the top of the steering wheel column. Plugs directly into the OBD for power. You'll be happy with it.
    reconrick1[OP] likes this.
  6. Aug 15, 2021 at 11:09 AM
    TucsonTundra1794
    Anthony
    Tucson, AZ
  7. Aug 15, 2021 at 11:12 AM
    Black
    Black Raised Hands Surround Us. 3 Nails To Protect Us
    2014 Tundra Limited CrewMax
    Falcon Leveling System, Coachbuilder +1s, RCI Skid Plates
    If you don’t mind using a laptop, phone or tablet I suggest the OBDLink MX+
    I have had good success with it while the device is a touch expensive but it is a one time purchase.
    No need to buy upgrades for each make and new model years.
    https://www.obdlink.com/products/obdlink-mxp/
  8. Aug 15, 2021 at 12:22 PM
    TucsonTundra1794
    Anthony
    Tucson, AZ
  9. Aug 15, 2021 at 12:23 PM
    TucsonTundra1794
    Anthony
    Tucson, AZ
    Ha! Didn't see you just posted it! Got it through the Kickstarter and I love it.
  10. Aug 15, 2021 at 12:33 PM
    TucsonTundra1794
    Anthony
    Tucson, AZ
  11. Aug 15, 2021 at 12:40 PM
    TucsonTundra1794
    Anthony
    Tucson, AZ
    That's the bullydog gt...
    Tundratoofun likes this.
  12. Aug 15, 2021 at 1:16 PM
    Leo's first
    Leo's first TRUCK GANG
    Groton ma
    Picked this up last year on a close out deal $30
    Not sure if it’s a good one but I used it to pull/clear codes before the aip bypass
  13. Aug 15, 2021 at 1:28 PM
    IgotSR5onit
    IgotSR5onit New Member
    I bought the Autel Maxidiag 808 and Its been really nice. Has a bunch of service functions for newer vehicles and imports and I can check fuel trims live.
  14. Aug 15, 2021 at 1:39 PM
    equin
    equin Texarican Tundra
    Ed
    DFW, TX
  15. Aug 15, 2021 at 1:46 PM
    IgotSR5onit
    If youre going to be using it for mechanic work Id look into investing in a higher quality scanner. Some newer vehicles require them for brake changes, batteries, ect.
  16. Aug 15, 2021 at 2:14 PM
    thearborbarber
    thearborbarber New Member
    SoDak
    2018 Tundra SR5
    With a 20% off coupon this is what I use on my wife's civic and kona and my tundra and jeep grand cherokee.
  17. Aug 15, 2021 at 2:22 PM
    French Avocado
    French Avocado Double Entundra
    Utah / Wyo
  18. Aug 15, 2021 at 4:05 PM
    TucsonTundra1794
    Anthony
    Tucson, AZ
    The techstream and obdlink would be 2 separate devices with 2 separate functions. The techstream would reprogram functions that already exist in your toyota computer, like door unlock, lights on with key fob, seat memory functions. The obd would read most of your sensors already installed like Trans temp, fuel pressure, air to fuel ratio, as well as pull codes that pop up and help diagnose problems. If you get both you'll essentially have every option avaliable for the Tundra besides tuning. Tuning changes shift point, throttle control, traction control, fuel ratio.
    It all depends on what you want to do
  19. Aug 15, 2021 at 8:34 PM
    Black
    Think the question was answered above but I can’t speak for tech stream because I have not started to look into it much. I know what it is but not sure how it is fully implemented.
    Though when I had my Expedition I used ForScan which reprograms many different things similar to Techstream.
    One could use the OBDLink MX+ paired wirelessly to a laptop to implement the programming changes.
    I personally was not comfortable with a wireless option considering I was reprogramming modules and wanted as few possibilities for error as possible.
    So I had a specific wired OBD device that my laptop was always directly connected when I was making changes.
    If I ever get into Techstream even if the OBDLink is capable of doing it I will not use it and use specific wired device for reprogramming.
  20. Aug 15, 2021 at 9:06 PM
    TucsonTundra1794
    Anthony
    Tucson, AZ
    I don't know of a device that does wireless Techstream because of how evasive it is to the programming. The only Techstream capable device I have is the bullydog gt which not only requires being plugged into the OBD it also will not let you start unless your battery is over 13 volts and stays there. It will actually pause if battery falls below that so it's recommended to connect your battery to a charger while doing any programming.
  21. Aug 16, 2021 at 5:50 PM
    reconrick1
    North MS
    2020 Tundra SR5 4x4
    I appreciate everybody’s input, definitely helps narrow it down, there are so many options out there. Just trying to avoid spending a couple hundred bucks on something only to find out it doesn’t do what I need it to do.
  22. Aug 16, 2021 at 5:52 PM
    French Avocado
    Utah / Wyo
    And thanks for letting me hijack your thread.
  23. Aug 16, 2021 at 6:53 PM
    reconrick1
    North MS
    2020 Tundra SR5 4x4
    No problem, that’s what forums are for, hijacking, flaming, and my favorite the first reply is usually “I don’t have that, but this is what I think” lol
    Still a wealth of info online! How did we manage without it?
