Overheated - Fixed :)
Discussion in '1st Gen Tundras (2000-2006)' started by Shellback, Sep 5, 2019.
  1. Sep 12, 2019 at 9:20 AM
    FirstGenVol
    FirstGenVol Brake Czar
    East TN
    2002 AC
    Remember when installing the thermostat the circled part goes on top. Is that what you did? Maybe you got a faulty "new" thermostat? Stranger things have happened.
  2. Sep 12, 2019 at 1:56 PM
    Shellback
    Shellback [OP] New Member
    Pink/Silver 2001 Tundra TRD
    Peeling door window trim.
    Yep. Double checked the little nipple thingy was on the top. I also used a Toyota t-stat. I had also purchased a duralast or whatever brand Autozone sold me and it did not have the little nipple. And the OEM was only a few $ more via Amazon.
  3. Sep 13, 2019 at 9:40 AM
    TX-TRD1stGEN
    TX-TRD1stGEN Privileged
    Seth
    South East Texas
    2000 Tundra 4x4
    Did you idle the truck with the rad cap off to get the air out? Should see the coolant start flowing when up to Temp as thermostats open.
  4. Sep 13, 2019 at 10:52 AM
    PCJ
    PCJ New Member
    State of Jefferson
    2004 DC Limited 4X4
    Lift, Rims, Bigger Tires, Nerf Bars, Black Out Emblems
    If your heater is blowing cold it means you have an air pocket. The radiator needs to be the highest part of the cooling system. If you have an angled driveway park with the front of the vehicle facing up it. Or put some blocks under the front tires or you could buy a special funnel set up that fits inplace of the radiator cap to raise the effective level of the radiator. This information I learned from my son who is a Toyota technician.
    bmf4069 likes this.
  5. Sep 13, 2019 at 10:54 AM
    15whtrd
    15whtrd Mr. Blonde
    If it ends up not being an air bubble in your system. It’s probably the water pump
  6. Sep 13, 2019 at 11:00 AM
    PCJ
    PCJ New Member
    State of Jefferson
    2004 DC Limited 4X4
    Water pumps will leak water when a seal fails but they won't stop circulating water.
    Aerindel likes this.
  7. Sep 13, 2019 at 11:13 AM
    15whtrd
    15whtrd Mr. Blonde
    He’s already replaced everything else. What else could it be if it’s not an air pocket. Possibly a bad thermostat staying closed?
    That lower hose should be getting warm. I noticed quite a few people said the lower hose should be cool. But it should not, it should be warm at least if the engine is up to temperature. The returning water will never be cold LOL. I would do as you said and try the bleeding process again on a slope. Squeezing the upper radiator hose, you should feel a rush of water if the pump is working properly when you release the hose.
  8. Sep 13, 2019 at 3:51 PM
    Aerindel
    Aerindel New Member
    Montana
    Headgasket. Which is why I strongly recommended testing for that before doing any work.
    15whtrd[QUOTED] likes this.
  9. Sep 13, 2019 at 4:27 PM
    remington351
    remington351 New Member
    2006 SR5 DoubleCab
    Squeeze your hose...lol. Has anyone mentioned coolant temperature sensor yet? I'd remove thermostat and run the engine. Get a $20 IR thermometer from Home depot and tell us the temperature of the upper hose and lower hose. The heater temp is a red herring, heater core can be clogged, heater feed or return lines clogged, heater control valve could be kaput also which is why you have cool heater sensation. I know green antifreeze plus dex-cool in GM created a nasty mush that overheated many a GM in the late 90's early 2000's. Anyone know if Toyota pink plus green creates a similar abomination?
  10. Sep 14, 2019 at 3:53 PM
    Shellback
    I'm embarrassed to say, but I cant find the block bleeder :rolleyes:
    Is it blocked by the transfer case?
  11. Sep 15, 2019 at 5:27 AM
    FirstGenVol
    East TN
    2002 AC
    Are you talking about the drain plugs I referenced in my picture? If so, there are two. One on each side of the engine, towards the back. Look closer at the picture and you'll notice they are above the oil pan. That should help you narrow it down. The driver side was harder to reach for some reason.
    Here is a zoomed out picture that might help for the passenger side.
    TX-TRD1stGEN likes this.
  12. Sep 17, 2019 at 3:08 PM
    Shellback
    Thank you to everyone who pointed me in the right direction and gave me tips.
    Must've been air-bound. I jacked up the front, plus it was already on an incline, and it she took 1 and 1/3 more of the pink stuff. I also suspect the T-stat was the culprit.
    I will tackle the water pump and timing belt later this year. Just wanted to get her back on her feet.
    Thanks again!
    TX-TRD1stGEN and bmf4069 like this.
