Overheated - Fixed :)
Discussion in '1st Gen Tundras (2000-2006)' started by Shellback, Sep 5, 2019.
  1. Sep 5, 2019 at 1:00 PM
    Shellback
    Shellback [OP] New Member
    Pink/Silver 2001 Tundra TRD
    Peeling door window trim.
    Luckily I broke down in front of a towing company.:(
    Started the day like any other and noticed the temp needle creeping past the 1/2 point which it never does. I shut her down, checked reservoir, and noticed a light plume of steam but hard to tell due to wind.
    Finessed her to a gas station and filled the reservoir. Took off again and the faster I drove the higher the temp. It almost peaked to the red when I decided enough is enough.
    No geyser or weird noises but was afraid of warping hear or blowing HG. So I decided to call the tow.
    So, now that I'm home and checking for parts online @ toyotaofcoolsprings, what do you all think?
    I'm betting on H2O pump.
    Might as well re-do the entire cooling system while I'm in there. She has 220K and the sticker says timing was changed at 110K.
    Thanks for allowing me to rant.
  2. Sep 5, 2019 at 1:04 PM
    15whtrd
    15whtrd Mr. Blonde
    Do the timing belt at the same time. New t stat, hoses ect. Take out the rad and have it tested at least. Also check the fan. From what I hear it should have some resistance.
    Tierhog and Pinay like this.
  3. Sep 5, 2019 at 1:07 PM
    Shellback
    Should I go ALL OEM on parts? Time constraints and $ are a factor.
    I'd like to get one of those timing belt kits that has all parts but not sure where to buy. Amazon?
  4. Sep 5, 2019 at 1:40 PM
    15whtrd
    15whtrd Mr. Blonde
    Go with Aisin. They manufacture the parts for Toyota. And you can get them much cheaper.
    Tierhog, Sunnier and Pinay like this.
  5. Sep 5, 2019 at 1:44 PM
    15whtrd
    15whtrd Mr. Blonde
  6. Sep 5, 2019 at 1:44 PM
    15whtrd
    15whtrd Mr. Blonde
    Pinay likes this.
  7. Sep 5, 2019 at 1:45 PM
    remington351
    remington351 New Member
    2006 SR5 DoubleCab
    The good news is that since you're due for a timing kit you can replace all the coolant components as well. Not sure I agree that it's "the H2O pump". Pumps rarely fail catastrophically, they leak at the seals and weep hole, and if ignored long enough, coolant will wash out the bearings and you could get a failed impeller. I advise determining the cause of your overheating first, a head gasket leak is rare, but not unheard of in this motor. Could be corrosion in the cooling pipes or blockage in the radiator. You don't want to start up and drive down the road after a timing belt only to overheat again.
    HappyGilmore and 15whtrd like this.
  8. Sep 5, 2019 at 2:10 PM
    Aerindel
    Aerindel New Member
    Montana
    Yeah, before you do all that work have your coolant tested for hydrocarbons. You could easily have a headgasket leak.
    Filthyphil likes this.
  9. Sep 5, 2019 at 4:30 PM
    FirstGenVol
    FirstGenVol Brake Czar
    East TN
    2002 AC
    If you're at 220k it's time to replace the radiator. I would do the serpentine belt too since it's easier with the radiator out.
    HappyGilmore and Filthyphil like this.
  10. Sep 5, 2019 at 5:59 PM
    Shellback
    So far I've taken the rad out and I need to replace it. The plastic collar is brittle and broke inside the rad hose. Luckily no plastic went inside and was able to retrieve all debris.
    So adding to my parts basket:
    1) RADIATOR:
    Denso @ NAPA $216
    Mishimoto @ Amazon $180
    2) HOSES:
    Already had upper and lower in my garage, $0
    3) Aisin timing belt kit @ Amazon $169
    4) Bottle of coolant $20
    5) Serpentine belt, oil filters @ toyotacoolsprings $80
    Sunnier likes this.
  11. Sep 5, 2019 at 6:25 PM
    FirstGenVol
    East TN
    2002 AC
    I would bleed all the coolant. I think it took 2 gallons when I did mine. There are 2 drain ports on the bottom of the engine block. You'll be surprised how much coolant comes out.
    I believe it's a 10mm and you can attach a hose so you don't make a mess. Make sure you either Zerex Asian blend, or Toyota coolant.
    Pics:
    Sunnier likes this.
  12. Sep 5, 2019 at 6:58 PM
    Shellback
    Thanks for the Zerex asian coolant tip.
  13. Sep 5, 2019 at 7:08 PM
    Vince
    Vince New Member
    Vincent
    Terre du lac, Missouri
    2011 White DBL cab 5.7
    K&N intake, Air bags
    Rockauto might have everything you want
    02goes likes this.
  14. Sep 5, 2019 at 7:29 PM
    02goes
    02goes New Member
    2002 Tundra Limited 4X4
  15. Sep 5, 2019 at 8:40 PM
    TX-TRD1stGEN
    TX-TRD1stGEN Privileged
    Seth
    South East Texas
    2000 Tundra 4x4
    You're going to need some Toyota gasket maker when you do your timing belt as well. And you should replace your thermostats as well.
    Sunnier likes this.
  16. Sep 6, 2019 at 9:36 AM
    Shellback
    Where can I purchase the "timing belt replaced at ______ mileage on _________ date " sticker?
  17. Sep 6, 2019 at 9:44 AM
    FirstGenVol
    East TN
    2002 AC
    Probably just easier to find a blank sticker at dollar tree and write it down.
  18. Sep 6, 2019 at 5:50 PM
    TX-TRD1stGEN
    Seth
    South East Texas
    2000 Tundra 4x4
    Sticker came with my kit from Amazon
  19. Sep 7, 2019 at 2:39 PM
    Shellback
    Well, orders have been made and now waiting for the delivery.
    In the meantime, can someone point me towards the factory Toyota repair manual/shop manual link? I had it saved pdf on old pc but lost it. It's for a 2001.
    Thanks.
  20. Sep 7, 2019 at 2:51 PM
    Sunnier
    Sunny
    San Diego, CA
  21. Sep 7, 2019 at 3:45 PM
    weadjust
    weadjust New Member
    Tupelo, MS
    2006 Tundra Limited DC
    deke1691 and TX-TRD1stGEN like this.
  22. Sep 11, 2019 at 5:33 PM
    Shellback
    Update.
    Didn't do full timing belt and H2O pump and just tackled the easy stuff first:
    - New Denso rad installed
    - New OEM t-stat & gasket
    - New OEM upper & lower hoses
    - OEM pink bubble gum coolant
    Still over heats.
    Also noted heater doesn't work. Just blows cool air.
    Going to wait till it cools down to then add more fluid and bleed as posted by FirstGenVol posted above.
    FirstGenVol likes this.
  23. Sep 11, 2019 at 7:59 PM
    bmf4069
    bmf4069 Yup, that's car parts in a dishwasher
    TX
    02 AC sr5 4wd v8
    If your heater doesn't work, is your coolant flowing?
  24. Sep 11, 2019 at 8:08 PM
    Shellback
    BMF,
    I don't know :help:
    Also, upper hose is hot, lower hose is cold. I suppose this means the fluid is going through the radiator inlet (top), cycles through radiator, and then returning back to engine with cooler fluid via lower hose, correct?
  25. Sep 11, 2019 at 8:27 PM
    bmf4069
    TX
    02 AC sr5 4wd v8
    Does your fan come on?
  26. Sep 11, 2019 at 8:32 PM
    SoCalPaul
    SoCalPaul New Member
    Paul
    San Fernando Valley, CA
    2006 Tundra Access Cab Limited 4wd.
    Front Bilstein 6112 shocks & Bilstein springs. Rear Bilstein 5160 remote Reservoir shocks, Wheeler’s Off-road add-a-leafs. LED lighting. Pioneer Avic 7200NEX Nav Head unit. Borla cat back exhaust.
    Sounds like either the thermostat is in wrong or the water pump isn’t pumping.
    Tundyfundy, speedtre and 15whtrd like this.
  27. Sep 11, 2019 at 8:37 PM
    SoCalPaul
    Paul
    Is the serpentine belt on correctly?
  28. Sep 11, 2019 at 9:22 PM
    Shellback
    Belt is on correctly.
    Fan clutch has good resistance and fan is always spinning. It's an '01. Were later years electric?
    T-stat installed correctly as per diagram.
    Going to perform the bleed tomorrow and check in again.
    Thanks for the responses.
  29. Sep 11, 2019 at 9:50 PM
    SoCalPaul
    Paul
    My 2006 fan is belt driven
  30. Sep 12, 2019 at 9:17 AM
    deke1691
    deke1691 New Member
    NorCal
    2000 AC V8 2wd
    Correct. Having just changed my coolant, I noted the same thing with hose temps and had the same issue with heater not hot. Lower hose doesn’t get hot from just idling. I forgot to check it after extended drive but it is “supposed” to be coolish if the rad is doing its job, right? Heater started blowing hot after a short drive. I assume it just needed time to burp. Make sure there’s enough coolant in the overflow canister.
