Outside temp reading
Discussion in '2.5 Gen Tundras (2014-2021)' started by havasuTRD, Jul 8, 2020.
  1. Jul 8, 2020 at 12:50 PM
    havasuTRD
    havasuTRD [OP] New Member
    Brett
    2017 Tundra crewmax TRD 4X4
    I tried searching with no luck. My outside temp reading is way off. Stuck at 79 when it’s 110 in AZ right now. Where is this sensor located and what have you guys done to fix it? Thx
  2. Jul 8, 2020 at 12:59 PM
    sillydadztrksR4momz
    sillydadztrksR4momz New Member
    I just recently noticed the same problem ever since parking the truck in the garage. So I figured it just needs time to adjust once it’s outside but I’d drive it for a good 20/30
    Minutes and don’t see it change temp
  3. Jul 8, 2020 at 3:02 PM
    JohnLakeman
    Outside of Weird, TX
    2017 MGM DC TSS 4.6L
    Behind the grille low on the driver side (see illustration). At 104* F, the resistance across terminals should be 0.80 to 1.00 kohms. If resistance doesn't meet spec, you replace the sensor.
