OTT Tune for stock NA Tundra
Discussion in 'Performance and Tuning' started by nasher75, Nov 1, 2023.
  1. Dec 3, 2025 at 11:24 AM
    #151
    ChesterTundra
    ChesterTundra New Member
    Central FL
    2020 Tundra SR5
    RCI Alum skids w/cat guards Leveled and AT Cooled SPD Performance exhaust Amsoil everywhere…
    My tuner mentioned this as well. He told me the OTT would make the 2.5 Gen throttle feel similar to the 2nd Gen. I have the Med/Spicy and like it.
  2. Dec 3, 2025 at 11:27 AM
    #152
    WhiteTundra0013
    WhiteTundra0013 New Member
    2013 white tundra
    Trd rear sway bar, Rims, Goodyear wrangler tires,Topper, Nerf bars
    Do you make a tune for the 4.6 engine?
    Boneskull420 likes this.
  3. Dec 3, 2025 at 2:09 PM
    #153
    JustDSM
    JustDSM New Member
    Justin
    We sure do!
  4. Apr 4, 2026 at 6:02 AM
    #154
    Stig
    Stig New Member
    Question without starting a whole new thread:
    How does the OTT tune adjust to larger diameter tires in regards to shifting/efficiency?
    I'm due for new tires, currently running stock P size. Before this set I went from the stock P metric to 295/70 18 and wasn't too bothered by the performance hit but I also didn't run them for more than about 1000 miles before I got rid of them (one tire never balanced and I gave up with the tire shop).
    I'm considering 295 again (michelin defender) and wondering how the OTT tune adjusts to tire size as far as driveability and gear hunting? Even with the stock P size, I have to leave it in S-6 on the highway and downshift to 5 for the rolling uphills.
    Never did like the sluggish shifting on this truck. I've had it for almost 10 years and think I'll finally get the transmission tuned with OTT. Just wondering if OTT also shifts better when running larger tires.
    Boneskull420 and HondaDad like this.
  5. Apr 4, 2026 at 6:52 AM
    #155
    blenton
    blenton New Member
    It does. But to get the most out of it, you will want to have the tune updated to reflect the tire change. It won’t change/recalibrate your speedometer, but the tune is reconfigured to let the computer know that load and rpm will be different than it was previously so shift points can be optimized.
    Some folks don’t notice a difference without the tune update, some notice a big difference.
    Mdl, JustDSM, rruff and 1 other person like this.
  6. Apr 4, 2026 at 7:14 AM
    #156
    IsaiahCanada
    IsaiahCanada New Member
    Isaiah
    Calgary, Alberta
    2021 Tundra SR5 Crewmax 4x4
    2.5 inch lift, TRD front and rear sway bars, 33 inch Open Country AT3 305/55R20 and dual TRD exhaust.
    I am running 305/55r20 and I notice that the after the tune, my truck doesn't hunt for gears any more. The truck has no hesitation anymore when I step on it. I love it.
    JustDSM and rruff like this.
  7. Apr 4, 2026 at 7:36 AM
    #157
    Boneskull420
    Boneskull420 God loving,Tundra driving,rednek custom joker!
    Mark
    Tn
    2018 tundra crewmax magnetic gray trd offroad
    Ironman 4x4 foamcell pro 3.5in lift Complete custom stereo with 2 12's under rear seat S&B/stillen Frankenstein cold air intake True dual exhaust with Carven Tr mufflers Rough country hood bulge led strip Running board led's
    I can't explain the details but I can say when I put the Falken wildpeak at4w 295/70/18s on I noticed a little drop in drivability, not horrible but did notice a difference.
    Got the ott medium/ spicy and drivability was better than before on flat roads and climbing hills.
    Thats my 2 cents, take it how ever you want. :thumbsup:
    HondaDad and IsaiahCanada like this.
  8. Apr 4, 2026 at 9:08 AM
    #158
    rruff
    rruff New Member
    2016 Tundra SR DC Long
    Have you tried using tow-haul? That accomplishes most of what a tune would do, only the tune is more customizable and can give a slight power boost. TH gets rid of the sluggish shifting and hunting, and it holds low gears longer instead of being so "eager" to shift to the highest gear. It also improves the throttle response, which will feel touchy at first.
    I discovered on a recent trip that using TH and S mode will still hunt on uphills, which sucks. TH and D never does, even with the camper at high altitude. Try that and see how you like it; a tune will only be better... plus you won't have to push the button. They can surely make it so it works properly in S mode as well. It's nice to be able to control the gear.
  9. Apr 4, 2026 at 2:07 PM
    #159
    Tundra1D6
    Anyone with an 08 have this tune? I’ve read mixed reviews on the 07-09 tundras with lackluster results.
    I had a bulldog “canned tuner” on my truck and wasn’t impressed at all.
    rruff and Boneskull420 like this.
  10. Apr 6, 2026 at 9:16 AM
    #160
    Cake Anderton
    Cake Anderton New Member
    2017 Tundra SR5
    Ive been considering the OTT for a while now, and the reviews are obviously overwhelmingly good, but one thing I don't think Ive seen mentioned is a comparison of which tuned "flavor" is closest to the stock tow/haul mode throttle sensitivity?
  11. Apr 6, 2026 at 10:17 AM
    #161
    JustDSM
    JustDSM New Member
    Justin
    Our Medium setting is similar to the factory tow-haul setting.
    IsaiahCanada, rruff and Boneskull420 like this.
  12. Apr 6, 2026 at 10:49 AM
    #162
    Cake Anderton
    2017 Tundra SR5
    Thank you! I guess I may be more of a Mild/Medium kind of guy then :turtleride:
    Boneskull420 and JustDSM[QUOTED] like this.
  13. Apr 6, 2026 at 10:54 AM
    #163
    JustDSM
    JustDSM New Member
    Justin
    That’s probably our most used combination.
    I’m a Lite guy with stock tow-haul throttle myself.
    HondaDad and Boneskull420 like this.
  14. Apr 6, 2026 at 2:27 PM
    #164
    rruff
    rruff New Member
    @JustDSM , does your tune work the same for throttle response and gear shifting in both S and D mode, or can they be made different? I discovered recently that mine will hunt pretty bad in some situations in S + TH, but never does in D + TH. I thought they'd work the same, but Toyota must map them differently.
  15. Apr 6, 2026 at 3:34 PM
    #165
    JustDSM
    JustDSM New Member
    Justin
    It does provide throttle adjustment for S-Mode in both "Normal" and "Tow-Haul". However, they are not independently mapped (between S-Mode and Drive). That's a Toyota operating system limitation.
    rruff[QUOTED] likes this.
  16. Apr 6, 2026 at 3:46 PM
    #166
    rruff
    rruff New Member
    Shifting as well? So S and D will perform the same in both normal and TH?
  17. Apr 6, 2026 at 4:02 PM
    #167
    JustDSM
    JustDSM New Member
    Justin
    Normal and Tow-Haul have independent shift scheduling. But S-Mode will use the Normal or Tow-Haul shift schedule (for upshifts not limited by the S-Mode selection, and downshifting). There are separate S-Mode TCC settings from the Normal and Tow-Haul settings used in Drive.
  18. Apr 11, 2026 at 12:42 AM
    #168
    raketemensch
    raketemensch New Member
    NEVADA
    2019 Super White Limited CM, prev 2015 MGM CM
    TRD CAI, BAM 8", OTT Tune
    @JustDSM
    Really impressed with the shifting on this tune! I’m running Medium/Spicy right now and it feels a bit tame, so I’ll probably step up to Spicy/Extra Spicy soon. But man, the shifting is amazing. Power too. I feel like there was a lot to be unleashed in there.
    Switching from my 2015 to the 2019, the difference in shift quality (especially climbing mountain passes) is night and day. Both trucks run 35x12.5s, but my 2019’s stock shift patterns were horrible. Spent the evening ripping up and down Tahoe — huge improvement!
  19. Apr 11, 2026 at 12:24 PM
    #169
    rruff
    rruff New Member
  20. Apr 11, 2026 at 2:50 PM
    #170
    raketemensch
    NEVADA
    My 2015 was not tuned. Shift mapping stock was much better vs 2019 stock. Pretty sure they changed something in 2018/2019. Both have tow package, 5.7 non-flex, etc. Only real difference were my previous wheels on the 2015 were 20x10 with Falkens AT3W, and I had a fiberglass topper – 2019 setup is 18x9 with those heavy Mickey Thompsons, and currently sitting without topper since I'm slowly still moving between houses.
  21. Apr 11, 2026 at 4:12 PM
    #171
    rruff
    rruff New Member
    Throttle mapping has always been bad on my 2016, but gear hunting on climbs only showed up with the camper on, and using tow-haul fixed that. I use a throttle controller and TH all the time now. Seems weird that they'd change the ECU outside of the generation changes. It's steadily gotten worse!
  22. Apr 11, 2026 at 4:45 PM
    #172
    ColoradoTJ AMSOIL Snob Staff Member
    Ford F-350, Roush Mustang, Jeep Crawler
    Pretty good thread.
    600.00? That's a pretty good deal if that also includes transmission tuning. Hell, even if it doesn't...see below.
    This would be for my 2025 power stroke. Not sure why I would need more than 500 hp/1200 tq, but whatever. So for just under 2000.00. Now this system has more features and the shift on the fly is something OTT should really look into...maybe they have and there's a reason why it's not an offering.
    I personally think you can get a lot more drivability from customizing the ECM/TCM suited for your driving style/needs. Engine tuning without transmission tuning is asking for trouble (imo), but most of the tuning I've dealt with is SC, TC, or T diesels that can add substantial torque.
    I used the same company for tuning my Duramax and that 10 year old truck would smoke my new one with similar horsepower but less torque. Would it smoke my current truck towing? Not a chance, but there is a lot of room to improve the overall feel. The shift schedule would be a major improvement.
    Boneskull420 and rruff like this.
  23. Apr 12, 2026 at 4:38 PM
    #173
    Stig
    Stig New Member
    Tried tow/haul in D today. Drive was down the interstate 75mph rolling hills and about 800 pounds in the bed. This worked really well on cruise control. I'll still get the tune if I go to larger tires.
    Boneskull420 and rruff[QUOTED] like this.
  24. Apr 27, 2026 at 3:56 AM
    #174
    xx3xil3xx
    xx3xil3xx New Member
    Aj
    2018 tundra sr5
    Stock
    Just got the tune done today...got the med/spicy tune. Im on 37s with stock gearing for now on my 2018. It feels alot better driving on regular mode. Only thing i noticed is when I put it in tow/haul mode, the truck doesnt feel as jumpy off the line or from a stop anymore. Is this normal?
    rruff, HondaDad and Corndog123 like this.
  25. Apr 27, 2026 at 4:15 AM
    #175
    Corndog123
    Corndog123 Knife creator.
    Sam
    Tennessee
    2014 SR5 Tundra Crewmax 4wheel drive 5.7
    Rough Country suspension, 305s, ARB bumper, light bar, Smittybuilt 10k winch. XD Buck 25 rims
    So it's been a few years, how is that tune doing?
    HondaDad likes this.
  26. Apr 27, 2026 at 8:56 AM
    #176
    rruff
    rruff New Member
    It's my understanding that you have the ability to map both D and D+TH to taste. But maybe I dreamt that...
    Anyway, are you saying it feels the same in D+TH as it does in D? Is D+TH less sensitive than it was before the tune?
    Corndog123 likes this.
  27. Apr 27, 2026 at 9:03 AM
    #177
    Corndog123
    Sam
    Tennessee
    So my Tundra is NA and I'm interested in getting this tune. Realistically, what can I expect?
    IsaiahCanada and Boneskull420 like this.
  28. Apr 27, 2026 at 10:00 AM
    #178
    xx3xil3xx
    Aj
    2018 tundra sr5
    Stock
    Yea pretty much...just talked to my tuner and we'll try a custom map for tow haul mode and we'll go from there
    rruff[QUOTED] and Corndog123 like this.
  29. Apr 27, 2026 at 10:13 AM
    #179
    Chad D.
    Chad D. New Member
    Western Oregon
    2018 CrewMax Platinum
    In my opinion, you’ll gain drivability. My tune really lowered my peak torque RPM. While my peak gain was small, the RPM for my new peak is just under 3,000 instead of closer to 3,800. Big improvement for hauling my travel trailer up hills, as 4th gear at 60 mph is right at 3,000 RPM.
    The transmission shift schedules and TCC behavior improvements are also much nicer, if your tuner works on those.
    Worth noting, my tune was done on a dyno and the trans adjustments were made over several revisions based on driving performance.
  30. Apr 27, 2026 at 10:16 AM
    #180
    Corndog123
    Sam
    Tennessee
    Oh gotchya. That's about what I thought. I didn't expect huge hp or torque numbers. Thank you very much!! :thumbsup:
