Opinions on Differential Oil Froth
Discussion in '2nd Gen Tundras (2007-2013)' started by Dalandshark, Apr 3, 2020.
  1. Apr 3, 2020 at 3:41 PM
    Dalandshark
    Dalandshark [OP] Infected with 5G
    Northwest
    2007 Tundra SR5 5.7 Longbed
    Eibach Level LIft
    Hey,
    I just changed the rear diff oil in both my Tundra and 4runner. I drove each of them a few miles before draining. The 4runner was pretty dark but looked like oil. The Tundra looked all frothy and goo like. See pic. General consensus of the internet is that the froth is normal. I'm not too concerned, just curious if the tundra fluid may have had an additive or maybe they were different oil types. Considering there's not much else going on, what do you think?IMG_20200403_141234608.jpg
  2. Apr 3, 2020 at 3:44 PM
    Jeffro22
    Jeffro22 New Member
    2013 platinum crewmax 4x4
    never seen that before. Mine was pretty clean. Normally water makes thAt milky color ? I would guess water?
    YardBird and Dalandshark[OP] like this.
  3. Apr 3, 2020 at 3:46 PM
    Coupe
    Coupe New Member
    James
    Houston, Texas
    2008 Toyota X-Runner
    TRD S/C, headers, APR X1, T56 Magnum 6 spd, NST pullies, Stptech Big Brake Kit, dropped, leather
    Me too.
  4. Apr 3, 2020 at 3:50 PM
    Dalandshark
    Northwest
    Eibach Level LIft
    I should clarify that what I read on the whole entire internet is that bubbly fluid is fine. This seems more Frothy to me. How would water get in the differential? Condensation?
  5. Apr 3, 2020 at 4:00 PM
    paultundratx
    paultundratx New Member
    2016 Toyota Tundra Limited Crewmax Silver Sky Metallic
    TRD cold air intake, TRD rear sway bar, TRD dual exhaust system, Toyota brushed stainless running boards, full RCI skid plates, Bilstein 5100 rear shocks
    Mine was pretty clean when I changed mine. I agree, that this looks like water. Maybe rear axle seals. Not sure.
  6. Apr 3, 2020 at 4:21 PM
    thearborbarber
    thearborbarber New Member
    SoDak
    2018 Tundra SR5
    That's emulsified oil. Condensation would be a cause if your truck sits a lot and when it does get driven it is for short trips. Other than that water has entered via the vent some how.
    You would have an oil leak if the axle seals are shot.
  7. Apr 3, 2020 at 4:28 PM
    Trooper2
    JR
    Houston, TX (Suburban South)
    2007 Tundra 5.7 L Double Cab TRD 2WD
    TSS 20's with Cooper ATP ll's, N Fab 3 Step Nerf Bars,, Pioneer AVIC-8100NEX, Masters Tailgate Replacement Latch with Camera, 1" Maxtrac Shackles, LED Interiors/Brake/Reverse/Cargo/Fog Bulbs, Fumoto Drain Valve, Toyota Aluminium Oil Filter Housing, TRD Shift Knob, Courtesy Door Projector LEDs with Toyota Emblem, Console Tray and Lower Divider.
    This^^^
    Water emulsified in the oil.
    My 07 looked nothing like that just used gear oil.
    JLS in WA and Dalandshark[OP] like this.
  8. Apr 3, 2020 at 4:30 PM
    Dalandshark
    Northwest
    Eibach Level LIft
    @thearborbarber I'm not sure how the truck was used prior to my purchase of it about 2000 miles ago. I drive it daily 32 miles. I did read elsewhere now that a clogged breather could prevent condensation from escaping. I think this fluid had been changed before, but likely not on the runner. Seems like I need to change the Tundra' again in a few thousand miles just to be sure the old stuff is all out.
    YardBird likes this.
  9. Apr 3, 2020 at 5:02 PM
    JLS in WA
    JLS in WA New Member
    2008 White DC Limited 4x4
    Drahthaar Transport Unit
    Personally, I'd replace the breather (relocate it while you're at it) and change the fluid in a week or two. I wouldn't feel comfortable leaving it for several thousand miles. That's just me. Three bottles of gear oil are far cheaper than a differential.
  10. Apr 3, 2020 at 6:09 PM
    thearborbarber
    SoDak
    2018 Tundra SR5
    Excellent idea. Replacing the breather is cheap too.
  11. Apr 4, 2020 at 11:18 AM
    Dr_Al
    Dr_Al New Member
    Al
    If the breather sticks it will blow out a seal. My guess is that the previous owner drove through water. If it was me (if it's 4wd) I would change the transfer case and front diff oil as well. Also grease all of the u-joints. Most likely is the rear diff was warm and then got wet. That will cause the warm air in the diff to contract. If underwater the diff can pull in a small amount of water each time. It's not just flooded roads or playing in the mud. If the previous owner had a boat each time he pulled the boat to the launch he would of heated up the rear diff more than normal (since he was towing) and then backed into the water (in which case the front diff and t-case should be fine). Good you caught it now. I would also use cheap gear oil and change it again in a couple hundred miles with good stuff to make sure to get as much out as possible.
  12. Apr 7, 2020 at 2:37 PM
    el_taco
    el_taco New Member
    Whoa, definitely relocate the rear breather
