Old man new to the group
Discussion in 'New Member Introductions' started by Grandaddy, Apr 8, 2018.
  1. Apr 8, 2018 at 6:38 PM
    Grandaddy
    Grandaddy [OP] New Member
    Roanoke Rapids NC
    2018 Tundra Limited CrewMax 4x4
    none
    Just wanted to say "Thanks for letting me join".
    Black Wolf, JoshuaA, TheBeast and 7 others like this.
  2. Apr 8, 2018 at 6:39 PM
    Y0TA PR0
    Y0TA PR0 Oil & Gas
    Rafael
    2017 TRD PRO
    WELCOME!
    Grandaddy[OP] likes this.
  3. Apr 8, 2018 at 6:40 PM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    Welcome from NorCal.
  4. Apr 8, 2018 at 6:41 PM
    seniramsu
    seniramsu Pro Runnin
    Nate
    VA
    2017 TRD Pro Tundra Wht
    Welcome from NC!!!
  5. Apr 8, 2018 at 6:42 PM
    Grumpy Uncle
    Pat
    CO
    Welcome from CO.
  6. Apr 8, 2018 at 6:42 PM
    Welcome from CO.
  7. Apr 8, 2018 at 6:51 PM
    TXMiamiFan
    Jose
    2016 White Crew Max TRD
    Welcome from Colorado
  8. Apr 8, 2018 at 6:53 PM
    BTBAKER
    BTBAKER .
    Brad
    Castle Rock
    2022 Ram TRX Level 2
    Welcome from CO!
  9. Apr 8, 2018 at 6:54 PM
    Welcome from Texas, Thank you for your service
  10. Apr 8, 2018 at 6:56 PM
    Grandaddy
    Roanoke Rapids NC
    none
    thank you for your service aramirez73.
    TXRailRoadBandit73 likes this.
  11. Apr 8, 2018 at 6:58 PM
    boostedtrdpro
    boostedtrdpro voided warranty
    Jeremy
    2024 GMC Sierra 2500HD AT4X 2020 Sequoia TRD Pro 040
    Welcome from CO!
  12. Apr 8, 2018 at 7:10 PM
    blue16
    blue16 New Member
    steve
    Mesa AZ
    2016 tundra
    Welcome from AZ
  13. Apr 8, 2018 at 7:21 PM
    Welcome from Ohio!
  14. Apr 8, 2018 at 7:40 PM
    rsrhmoore
    rsrhmoore New Member
    Ronald
    2018 Tundra Limited Parker Extreme
    Lockers front and rear, lift kit, 35 tires...so far
    Responding to California Kid on preference between Auburn Ltd. Slip and ARB locker. The biggest diference is price and set up needs. The second biggest difference is personal needs. I’ve been building and using many types of axles for more than 30 years and specialize in axle overhaul and modification. As to what will suit your needs is strictly personal. What do you want to do with it? For me, if money and time are no consideration I would go with the ARB units in front and rear diff. When not in use the truck drives like normal. When needed, hit the switch, or switches dependant on what’s needed to traverse the current terrain you’re in and Voila! You have axles locked. This gives you even distributed traction to all wheels.
    Many first timers ask the questions; how strong is one? Which is better? All valid and all easy to answer. Both companies have extensive research into their products and are both proven as excellent! If you spend regular time off highway and are rarely in difficult terrain the Auburn is more cost effective, but you will sacrifice fuel economy when driving on regular streets due to it always being, for lack of better words, on. The Ltd. Slip is always working no matter what. But, it works excellent for what it was designed for and that’s enhanced traction aid under normal to moderate circumstances. It is not designed to have one wheel off the ground and place power to the other. For that you would need something a bit more brutal like the Detroit Locker, Power Lock etc. These were designed for aggressive wheel traction on extreme terrain.
    If you want something that is designed for all conditions, almost, you would purchase the ARB locker, have it professionally installed and done right so there are no major issues. Here is where the ARB does the best job; when not needed the diff’s are open and function as designed by the factory. When needed, engage the switch and the diff will lock solid. ARB lockers have been significantly tested and are extremely strong. It would take a lot of horsepower, more than the Tundra can produce even supercharged to break one of theirs!
    There is a significant cost difference between the two. For about $750.00 you can purchase the Auburn with install bearings, seals, gaskets and new stud crush rings for the cover bolts. I did that for my 2010 Tundra and after 50k it was still working. The only downside is they don’t like synthetic gear oil, which as you know comes factory in Toyota’s front and rear diffs. I used synthetic in mine with no discernable differences. I also ensured to use synthetic cluth additive to match the oil.
    I’ve used the ARB and overall were much happier. It cost me $3500.00 for initial purchase with compressor to run both, switches to match and took two weekends to install all to ensure proper installation and protection of lines, compressor etc. They are still going after five years with no issue. One day I will contact the customer I sold the truck to and see if they’re still engaging them both and are working.
    The bottom line for me is cost. I know I will drive my truck on pavement most of its life and when time comes to install one in my newest Tundra that will be the deciding factor. Like a supercharger, if I had the money I would’ve done one again, but the cost and availability for the Tundra’s have changed dramatically in the last three years.
    Check into all prices to include cost of installation if you cannot do yourself and I believe that will help you decide.
  15. Apr 8, 2018 at 7:42 PM
    nk1794
    nk1794 Always torque to spec
    San Jose, CA
    Welcome from CA
  16. Apr 8, 2018 at 8:23 PM
    Thegr8punkin
    Thegr8punkin A G.D.M/Sofa King Cool/COTJ's dreamboat
    Connor
    Northern Colorado
    08 blue sr5 2wd
    2 +5 hp stickers
    Welcome from Colorado!
  17. Apr 8, 2018 at 8:55 PM
    Vendeta2k
    Jay
    Bozeman, Montana
    2018 Limited Cement CM
    Welcome!
  18. Apr 8, 2018 at 9:17 PM
    Bappa
    Bappa Off the grid
    Bo
    Arizona
    2018 Tundra CrewMax
    Coil overs (3”) and 295 tires, ESP storage, grab bar; RCI skids; tinted windows; rear air bags
    Welcome from AZ and from another Grandpa. We just had grandchild number 10 about a month ago.
  19. Apr 8, 2018 at 9:33 PM
    Areith762
    Areith762 Go Avs!!!
    39.944182, -104.760113
    2017 Blazing Blue 5.7L CM SR5 4X4
    DAP Tune, Katskin interior leather, ESP rear under seat storage, door sill protector, door edge protector, TRD Pro shift knob, heated seats, all weather Tundra floor mats, driver side a-frame handle, Tundra trucks center console emblem, clear bra protection, Bushwacker fender flares, paint match front bumper caps, paint match rear bumper caps, paint match mirror caps, ProComp 3/1 lift, 20" Fuel wheels, 33-11.50/R20 Falcon tires, black TRD Pro badge's, black Tundra tailgate badge insert, TRD Pro headlights, Recon smoked tail lights, Recon smoked 3rd brake light, Roll N Lock tonneau cover, Line-X bed liner, Tundra bed mat, Cobra led remote alarm/remote start, N-fab tube steps, factory match window tint, TRD Pro grille -paint matched, paint matched hood bulge, TRD dual exhaust, Black out exhaust tips, led interior lights, led plate lights, Spyder smoked fog lights, TRD Cold Air Intake
    Welcome from CO
  20. Apr 8, 2018 at 9:44 PM
    NCinCO
    NCinCO Is it Friday yet?
    Gary
    Thornton, CO
    2018 Smoked Mesquite Limited CM TRD
  21. Apr 9, 2018 at 5:10 AM
    Tundra Girl
    Tundra Girl New Member
    Maddy
    New York, Long Island
    2017 Tundra Limited Metallic Black
    TDR Sway Bar
    Hello and welcome!
  22. Apr 9, 2018 at 5:53 AM
    Ely010606
    Ely010606 New Member
    SPARKS, NV
    2017 QS SR5 CM TRD 4x4
    Welcome from So Cal
  23. Apr 9, 2018 at 6:18 AM
    Welcome from CO grand pap!!!
  24. Apr 9, 2018 at 6:43 AM
    Tracker
    Tracker New Member
    Shane
    Colorado, Denver Burbs
    2016 Silver Tundra SR5 Lifted
  25. Apr 9, 2018 at 8:47 AM
    TXDrifter
    TXDrifter BlueGrass Crew
    Jeff
    Louisville, KY
    2017 Tundra MGM DC
    Welcome from a grandpa from Kentucky
  26. Apr 9, 2018 at 9:11 AM
    ToyotaTundraMike
    2015 Tundra
    Lol this guy....Skip the intro post and go right into a short essay response on the wrong thread as your first post ever? Welcome to the forum man!
    Oh and to the OP: Welcome aboard, post up a pic of your ride when ya get a chance!
  27. Apr 9, 2018 at 9:44 PM
    GAknight
    GAknight New Member
    Shade of a Pine, GA
    '14 TSS 4x4
    Too many…scratch that…not done yet.
    Holy-super-first-post Batman! Welcome aboard!
    To the OP, Welcome from GA!
