OK 21' MGM Pro
Discussion in '2.5 Gen Builds (2014-2021)' started by JStrabler1, Aug 2, 2021.
  1. Aug 2, 2021 at 10:04 AM
    JStrabler1
    JStrabler1 [OP] New Member
    '21 MGM TRD Pro
    Westcott TRD Pro lift, 285/75 Nitto RG's, RRW Sliders, Bakflip MX4
    Hello, everyone. New member here from Oklahoma.
    Recently purchased my 2021 TRD Pro in Magnetic Gray Metallic after my Avalon DD got totaled by baseball sized hail. I had been planning to get a Tundra, but it got moved up after the storm. I also have a 2013 4Runner Limited that I bought new that I've been using to tow a travel trailer, but it struggles up hills and I have plans to take it to the mountains soon. The Tundra was in order for towing purposes, but will also be my daily driver.
    Here are pictures from when I brought it home last month:
  2. Aug 2, 2021 at 10:10 AM
    JStrabler1
    '21 MGM TRD Pro
    After bringing it home, that evening I had the BakFlip MX4 installed... :D
    And moved the Scangauge II over to the Tundra from the 4Runner. If you guys have suggestions on the best placement of this, I'd like to hear them.
    bulldog93, batman900 and Metro14536 like this.
  3. Aug 2, 2021 at 10:15 AM
    JStrabler1
    '21 MGM TRD Pro
    Picked up my tires a few days later. Nitto Ridge Grapplers in 285/75R18. I had ordered the TRD Pro lift from Westcott Industries and was just waiting for the tires to proceed with the install. Mocked it up to see what kind of difference it was going to make. I have to be honest and say I was a little concerned that they weren't going to fit. :confused:
  4. Aug 2, 2021 at 10:24 AM
    JStrabler1
    '21 MGM TRD Pro
    I had a local shop do the install just to save some time. It was worth just over $500 to reduce the time I was without the truck. What an improvement!
    They fit fine with the only modification being to remove the flap on the air dam in front of the front tires. There is about 3/4" clearance from the UCA's with these tires. They are 35.08" diameter and 11.26" wide.
  5. Aug 2, 2021 at 10:30 AM
    Taco-Spike
    Two Trucks
  6. Aug 2, 2021 at 10:32 AM
    JStrabler1
    '21 MGM TRD Pro
    The shop tried to tell me that the spare wouldn't fit in the factory location. I told them it would, but didn't feel like arguing with them, so I just took it home in the bed. The next day I took the angle grinder to the forward bracket/braces the cut a notch in them. Then I could smack them out of the way with a sledgehammer. The spare fit with no room to "spare" (pun intended).
    bulldog93, Patch999 and RobertD like this.
  7. Aug 2, 2021 at 10:43 AM
    JStrabler1
    '21 MGM TRD Pro
    I had ordered some rock sliders from Relation Race Wheels right before getting the truck. They arrived last Thursday and I installed them right away. I really like how they turned out. No drilling required. They use factory holes in the frame. These RRW's are a great product that are built super tough, are great quality, and come with excellent quality hardware.
  8. Aug 2, 2021 at 10:46 AM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    Good luck towing anything with them mods…
  9. Aug 2, 2021 at 10:52 AM
    JStrabler1
    '21 MGM TRD Pro
    What the heck are you talking about? I've already towed with it and it was perfect. No sag, plenty of power, no gear searching. It's all good.
    IsaiahCanada, Rodtheviking and MTRock like this.
  10. Aug 2, 2021 at 10:56 AM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    Oh ok nice truck
  11. Aug 2, 2021 at 11:59 AM
    RusPro21
    RusPro21 Pro is gone! But I’m still here.
    Don
    Pa.
    2021 Pro!! Nitto’s Tyger blades, Arc audio!
    Very nice. Looks good. Did you do alignment yet? Also I assume you used the westcott for the rear also.
    JStrabler1[OP] likes this.
  12. Aug 2, 2021 at 12:19 PM
    JStrabler1
    '21 MGM TRD Pro
    Yes, I had to have the alignment done twice because I could tell the camber was off. And, yes I used the Westcott kit on the rear also. It sits perfectly level. It ended up being around 3.5" of total height from stock.
    IsaiahCanada likes this.
  13. Aug 2, 2021 at 12:26 PM
    RusPro21
    Don
    Pa.
    Thanks dude!! This is the way I’m leaning if I decide to raise my Pro.
    IsaiahCanada and JStrabler1[OP] like this.
  14. Aug 2, 2021 at 2:04 PM
    Californate
    Californate New Member
    2019 Cement Limited Crewmax
    Nice, I have same size tires but was talked out of getting a spare, seeing yourself be able to fit a spare underneath just convinced me to go ahead and get one.:cheers:
  15. Aug 2, 2021 at 2:26 PM
    JStrabler1
    '21 MGM TRD Pro
    Right on, man! Glad I could help someone out!
  16. Sep 25, 2021 at 11:58 AM
    JStrabler1
    '21 MGM TRD Pro
    AJT Designs products installed. Blacked out with the exception of the knobs. I like the factory silver ones.
    DE7A09D6-5812-42ED-A89A-8F5E15127511.jpg 7778AE44-3E31-4AC0-9B5C-1A31CA667A7A.jpg
  17. Sep 25, 2021 at 12:02 PM
    JStrabler1
    '21 MGM TRD Pro
    Also named him “Riggins”, put it on a license plate frame and installed a TRD hitch cover with a locking pin from Rhino USA.
    bulldog93 likes this.
  18. Sep 25, 2021 at 12:34 PM
    JStrabler1
    '21 MGM TRD Pro
    Jerry can mounted! Wavian with the matching mount. Used the two extra brackets from the BakFlip MX4 cargo rail relocation. Works great.
    bulldog93, BravoDeltaRomeo and RRR1C0 like this.
  19. Sep 25, 2021 at 12:36 PM
    memario1214
    Colton
    Missoula, MT
    '21 Limited MGM CrewMax
    She's a beaut!
    Subbed!
  20. Sep 30, 2021 at 5:54 PM
    3jet3
    3jet3 New Member
    FL
    2021 Tundra TRD
    ----Suspension---- 6112 Bilstein Front 5160 Bilstein Back 3 CB .5" Shims(2 driver side, 1 passenger) CB 3+ Shackles Differential Drop kit Carrier Drop kit ----Wheels---- Tires - Falken WildPeak A/T- 295 70 18 Wheels - Raceline Gauge 18" ----Accessories---- GoRhino RB20 Running Boards
    Sick set up!
  21. Sep 30, 2021 at 6:57 PM
    JStrabler1
    '21 MGM TRD Pro
    Thanks, man. I’m really happy with the way it turned out.
  22. Aug 5, 2022 at 2:17 PM
    cholt85
    cholt85 New Member
    Casey
    2020 Tundra TRD Pro
    That looks soooo good!! I too am located in OK and must know which shop you had used for your lift install. I ordered Coachbuilder on Monday and waiting to get so I can have installed. Have been debating on wheel and tire setup and your thread helped out a bunch!
