Oil leak! Need some advice please.
Discussion in '1st Gen Tundras (2000-2006)' started by revtune, Jan 24, 2020.
  1. Jan 24, 2020 at 5:39 AM
    revtune
    revtune [OP] New Member
    Dane
    Houston Texas
    2006 Tundra 4.7 AC 2wd
    2006 Tundra: Stock air intake 3 inch catback Magnaflow 13742 2.5 inch front lift 1.5 inch rear blocks 2014 sr5 4Runner wheels (17x7) 1.5 inch hub centric wheel spacers p285/70/17 Nitto Terra Grappler G2 Weathertech floor liners
    2/4/20 UPDATE! = Valve covers/gaskets. Bolts tightened and keeping an eye out.
    Hey guys and gals. Me and my buddy were looking under his truck yesterday. I told him let’s take the skid plate off so we inspect some shit from underneath. the skid plate had some oil on it:confused: So we’re looking around with a flashlight and noticed a leak that looks like it’s coming from the base of the dip stick tube and traveling around part of the oil pan. Here are some pics I took of the area in question. His truck is a 2006 4.7 2wd (112,000). We plan on taking it to a shop for diagnosis. I appreciate any advice y’all have.
  2. Jan 24, 2020 at 5:51 AM
    Professional Hand Model
    Hand Protectors
    Oil overflowing from upper dipstick entry hole?
    Is that whats happening?
    revtune[OP] and speedtre like this.
  3. Jan 24, 2020 at 6:05 AM
    revtune
    Dane
    Houston Texas
    Damn! Could be, how or why would that be happening?
  4. Jan 24, 2020 at 6:06 AM
    SprinterAE86
    SprinterAE86 New Member
    Ian
    Charlottetown, PE, Canada
    2012 Toyota Sequoia Platinum
    You can get a replacement o ring for the dip stick tube. But it's been years since I decades soccer I bought one. They might just sell you whole think.
    Also it might be coming from a higher source. Valve cover gasket do harden overtime sometime even cracks. Tighten the valve cover bolts and see.
    Does he drain his oil through dip stick tube? I do! I have a tool for that.
    revtune[OP] likes this.
  5. Jan 24, 2020 at 6:07 AM
    Rex Kramer
    Rex Kramer Vinyl Spinner
    Georgia
    Clean all of the oil off, drive a bit, then reinspect to find the source.
    bmf4069 and revtune[OP] like this.
  6. Jan 24, 2020 at 6:13 AM
    Hand Protectors
    Not sure as I’m not there in person. Picture is incomplete. Feel around the valve cover gasket seams. Might be leaking. Take a 10mm socket and tighten/check all of the vcg bolts tightness.
    112k miles might be time.
    revtune[QUOTED][OP] likes this.
  7. Jan 24, 2020 at 6:27 AM
    revtune
    Dane
    Houston Texas
    He has his oil changed somewhere:oops:
  8. Jan 24, 2020 at 6:32 AM
    revtune
    Dane
    Houston Texas
    I was brain storming yesterday and I mentioned valve cover gaskets too. It would be a relief if they just need the old 2 grunts and fart:D
  9. Jan 24, 2020 at 6:38 AM
    Hand Protectors
    Just did some service on a vehicle (which was serviced by others monkey lubes prior) that was spec’d at 4.2 quarts engine oil. I drained out 5.5 quarts!
    I think back at all the stupid work done on my truck by other (professionals) and scratch my head.
  10. Jan 24, 2020 at 6:46 AM
    SprinterAE86
    Ian
    Sucking the oil from the dip stick tube is starting to be more common now in shops. So I would not be surprised that there's some spillover while pulling the tubes out. It happen to me a few times. I usually have a rag ready. But sometimes I don't.
    Constant drip could only be valve cover gasket.
  11. Jan 24, 2020 at 6:49 AM
    Hand Protectors
    Yeah. The drip on the A/C compressor suggests a leak at the front vc corner.
    Could be the oil monkeys were messy during their service, too.
  12. Jan 24, 2020 at 10:54 AM
    bmf4069
    bmf4069 Yup, that's car parts in a dishwasher
    TX
    02 AC sr5 4wd v8
    Y'all sure? When my VCs were leaking it went straight onto the exh manifolds.
    BubbaW likes this.
  13. Jan 24, 2020 at 12:30 PM
    Hand Protectors
    I am not sure of anything about this thread. Need eyeballs on.
    bmf4069[QUOTED] likes this.
  14. Jan 24, 2020 at 6:33 PM
    revtune
    Dane
    Houston Texas
    Well, at least I’ve convinced my friend to change his own oil:)
  15. Jan 24, 2020 at 6:45 PM
    SprinterAE86
    Ian
  16. Feb 4, 2020 at 1:59 PM
    revtune
    Dane
    Houston Texas
    Thank you to the guys that posted here. My friend ended up needing an alternator. It was starting to make a whirring sound and finally took a dump. The mechanics we took it to installed a higher amp unit. The oil leak was as some of you suspected... The valve covers! The shop tightened the bolts down and said keep your eyes peeled. Thanks again for the reply’s.
