Oil Filter Drain Plug stuck
Discussion in '2nd Gen Tundras (2007-2013)' started by Underdogg, May 31, 2023.
  1. May 31, 2023 at 5:57 PM
    Underdogg
    Underdogg [OP] New Member
    07 Crewmax 5.7L
    Finished an oil change myself a month ago and noticed I overfilled; dipstick reads high. The shop I took the car to last time before I started doing maintenance myself tightened the drain plug like it owed them money. I cannot remove it. I definitely could try more force or leverage but I feel like the filter housing or something will break.
    Anyone have any tricks for getting this unstuck? Or anyone know anyway to remove a small amount of oil without getting it all over the filter/housing by unscrewing the whole thing and getting oil everywhere? I have read that overfilling oil can cause aeration or something but idk much about anything.
  2. May 31, 2023 at 6:10 PM
    TILLY
    TILLY Gently Used Member
    Massachusetts
    2019 MGM TRD Sport D/C
    Have you tried loosening up the oil pan bolt halfway till it starts to dribble out? That's what I would try first. Good luck.
    Underdogg[OP] likes this.
  3. May 31, 2023 at 6:17 PM
    I would drain some from the pan, not the filter. A Fumoto would be you best friend in this case. As far as the filter drain plug, you can use a 3/8 breaker bar. If you do it right, you should be able to break it loose without loosening the whole filter assembly.
  4. May 31, 2023 at 6:25 PM
    Silver17
    Eastern PA
    2017 TRD 4x4 Harrop SC
    Eibach pro 2.0s, toytec progressive mini AAL, ARE CX cap, Airlift bags, Harrop Supercharger, 650cc injectors, 77.5mm pulley, TRD Dual exhaust, J&L catchcan, Powertrax LSD, RRW RR7-H, 305/70r17 Toyo AT3s
    Contrary to what you would think, I’ve had better luck breaking stuff like that free with a powerful impact gun with less damage to the fasteners, less struggle, and more success. Tightening use a regular wrench or course, but for loosening I’ve found nothing works better than an impact. Just had that today with some Phillips screws on a pressure control at work. I was stripping the heads with a regular Phillips screwdriver. The 1/4” impact made quick painless work of it.
    Underdogg[OP] and Tundra234 like this.
  5. May 31, 2023 at 6:35 PM
    PhotoNerd
    PhotoNerd New Member
    Tony
    Waterford, CT
    2008 Salsa Red Tundra DC SR5 4x4
    Chrome delete, Sequioa grill, bed lights, LED + head, fog & tail lights, Dynamat throughout, front & rear cameras, Pheonix PX6 13" head unit, 8" subwoofer, JBL speaker upgrades, tonneau cover, custom shifter, steering wheel cover
  6. May 31, 2023 at 6:36 PM
    Windsor
    Windsor New Member
    Oregon
    2008 Tundra Crewmax 5.7L
    Seat covers, SnugTop.
    I have found the best method of loosing it when tight is to run an extension up to it with a breaker bar low enough to be clear of hitting anything. Then, put a little bit of pressure on it and smack the breaker bar with a mallet. It causes a shock to it that is quick enough to loosen it without transferring the torque to the filter housing.
  7. May 31, 2023 at 6:42 PM
    +1......this explains what I meant when I said "if you do it right". :thumbsup:
    Windsor[QUOTED] likes this.
  8. Jun 2, 2023 at 9:46 PM
    Underdogg
    07 Crewmax 5.7L
    I will try this out! Thanks
  9. Jun 2, 2023 at 9:46 PM
    Underdogg
    07 Crewmax 5.7L
    I didn't even think of the oil pan, good idea
  10. Jun 2, 2023 at 11:12 PM
    Windsor
    Windsor New Member
    Oregon
    And as @Tundra234 said, Fumoto valve. I love mine. Makes oil changes easy and CLEAN. No more splashing oil in the passenger side tire.
