Oil Change Question
Discussion in '2.5 Gen Tundras (2014-2021)' started by 53flattie, Oct 10, 2016.
  1. Oct 10, 2016 at 8:38 AM
    53flattie
    53flattie [OP] New Member
    Upstate SC
    2015 SR5 CM 4WD
    2.5" / 1.5" leveling kit ; 275/70/18 BFG AT/KO's
    I'm finished with the "free" Toyota Care oil changes, so the next one will be the first time I've changed it myself. I have two questions:
    I've seen reference to the 5.7 holding 9.8qts and I've seen reference to 7qts. Which is correct?
    I saw a thread the other day where someone bought a nifty-looking tool and replacement "cap" for the oil filter. I can't seem to locate that thread now... Anyone remember where that was?
    Thanks!
    Sgt.Argueta likes this.
  2. Oct 10, 2016 at 8:54 AM
    Fumoto valve is what you're referring to.
    53flattie[OP] likes this.
  3. Oct 10, 2016 at 10:00 AM
    53flattie
    Upstate SC
    2015 SR5 CM 4WD
    I've seen those before, and they are cool, but that's not what I saw in the other thread.
    I *think* it was a u-shaped tool for removing the filter housing (instead of using a flute wrench). And it might have been a replacement housing too... (scratching head)
  4. Oct 10, 2016 at 10:21 AM
    BRNG ITT
    BRNG ITT New Member
    San Antonio, Texas
    2016 CrewMax TRD PRO
    Here's the link I was going to post up prior to RowdyRon's. Not sure if it the same thing he posted, but it is based off of the Venza's adapter.
    NewImprovedRon and 53flattie[OP] like this.
  5. Oct 10, 2016 at 10:40 AM
    53flattie
    Upstate SC
    2015 SR5 CM 4WD
    Thanks so much guys!!!
    NewImprovedRon likes this.
  6. Oct 10, 2016 at 11:04 AM
    ChucklesToy
    ChucklesToy Retired
    Chuck
    Georgetown , TX
    2024 Honda Ridgeline Black Edition
    From the Owner's Manual:
    Oil capacity -
    With filter 7.9 qt. (7.5 L, 6.6 Imp.qt.)
    Without filter 7.5 qt. (7.1 L, 6.2 Imp.qt.)
  7. Oct 10, 2016 at 4:10 PM
    Nodlenor
    Nodlenor New Member
    Ronald
    2010 Black Tundra TRD SR5
    I recently bought a 2010 tundra and checked with my local dealer about changing oil. I was told they would change oil (oil & filter included) for $59.95. I don't think I can change it myself and save much. I'm going to give them a try and see how it goes.
  8. Oct 13, 2016 at 6:15 AM
    53flattie
    Upstate SC
    2015 SR5 CM 4WD
    Okay - who was the crackhead engineer that designed the oil filter such that you have to remove the skid plate in order to access it??? Good grief. A total of 8 bolts that are 3 different sizes? Really?
    Has anyone given any thought to using a 4" hole saw to create an opening below the filter housing so you don't have to remove the skid plate to change the oil?
  9. Oct 13, 2016 at 6:37 AM
    BlueFalconActual
    Kevin
    29 Palms, CA
    Tundra-less
    Im using it as an excuse to buy an RCI or TRD Pro skid plate because they have access doors to the oil filter. It's a total "coincidence" that I will need to change my oil right around January/February (tax return time).:bananadance:
  10. Oct 13, 2016 at 7:02 AM
    ChucklesToy
    ChucklesToy Retired
    Chuck
    Georgetown , TX
    I did see a thread on one of the forums where a member modified his OEM (not TRD) skid plate to have an oil change flap like the TRD skid plate does, but I can't find the thread. If I find it, I'll post it here. Most are just migrating to the TRD or RCI as Kevin (BlueFalconActual) mentioned.
    UPDATE: The one RowdyRon posted below is the one I was thinking of. Thanks!
    Bigmoo and BlueFalconActual like this.
  11. Oct 13, 2016 at 7:24 AM
    BlueFalconActual
    Kevin
    29 Palms, CA
    Tundra-less
    It's an elaborate ruse by Toyota in order for us to spend money on TRD Pro parts. Silly Toyota, I don't need more reasons to spend my money on mods.
  12. Oct 13, 2016 at 7:54 AM
    BlueFalconActual
    Kevin
    29 Palms, CA
    Tundra-less
  13. Oct 13, 2016 at 9:23 AM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    You say redneck as if it's a bad thing.
    :anonymous:
  14. Oct 13, 2016 at 10:55 AM
    53flattie
    Upstate SC
    2015 SR5 CM 4WD
    Thanks Ron! That looks like a better solution to me!!
  15. Oct 13, 2016 at 10:58 AM
    BlueFalconActual
    Kevin
    29 Palms, CA
    Tundra-less
    Lol. Wasn't meant as a bad thing. I grew up in the woods of north Idaho. Never discount the value of redneck inginuity.
  16. Oct 13, 2016 at 11:07 AM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    Nice!
    It's what this country's founded on baby!!
    NewImprovedRon and ChucklesToy like this.
  17. Oct 13, 2016 at 11:12 AM
    Yes. That mod I believe is has been addressed here already. I don't change my own oil anymore so I don't worry about it, I let Grease Monkey worry about that. Not worth the expense/hassle DIY oil change anymore IMO.
    Law323 and NewImprovedRon like this.
