Offset with stock size tires
Discussion in 'Wheels & Tires' started by MadMaxCanon, Sep 28, 2021.
  1. Sep 28, 2021 at 8:41 AM
    MadMaxCanon
    MadMaxCanon [OP] New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    So i am seriously considering getting a set of Method 317's in titanium with the discount code that i just got from a member on this forum. I am pretty sure i wont have issues but i wanted to double check.
    If i get 18"x9" methods with a +18 offset on stock suspension SR5 4x4 using stock size BFG 275/65/18 KO2s, I shouldnt have any rubbing issues due to the offset correct? would the increase in rim width from 18x8 stock size to 18x9 method size cause any issues with the tires?
    I will eventually replace the suspension and get bigger wheels but i only have about 5k on the BFGs and want to wear them out a bit more.
  2. Sep 28, 2021 at 10:54 AM
    JonS
    JonS New Member
    Jon
    2020 tundra trd sport
    You will be fine.
    MadMaxCanon[OP] likes this.
