OFFICIAL: MY22+ Toyota Tundra Technical Service Bulletin Thread - Updated May 23, 2024
Discussion in '3rd Gen Tundras (2022+)' started by ryanwgregg, Feb 2, 2024.
  1. Feb 2, 2024 at 8:00 AM
    ryanwgregg
    ryanwgregg [OP] 47,000 miles & counting...
    DFW, TX
    VXKA75L-PSUZZA
    .....OEM+ Mods..... ..I DO NOT WORK.. ....FOR TOYOTA....
    EDITED:
    May 23, 2024
    CURRENT AS OF MAY 23, 2024
    I figured that I would help the community with an "OFFICIAL" thread of all the TSBs that are known to date.
    Due to past circumstances, I will not be posting any Toyota Copyrighted information...so that means no PDFs, no Screenshots of PDFs, nada, nothing, nil...and please do not ask me here or in DM/PM/Conversation.
    For those in Canada, the T-TCI-****-** is your equivalent to a US T-SB-****-**.
    ABBREVIATIONS
    MIL - Malfunction Indicator Light - Your "check engine light" may illuminate but it does not mean it has to do with the engine.
    CEL - Check Engine Light - Similar to the MIL, but the associated issue is related to the engine
    DTC - Diagnostic Trouble Code - With the introduction of OBDII, there are generic SAE codes and then manufacturer specific codes related to system(s) within the vehicle
    • T-SB-0006-22: MY22 Tundra SR: LTA Malfunction Warning Message with DTC U013787
      • T-TCI-5506
    • T-SB-0011-22: MY22 Tundra: MIL (Malfunction Indicator Light) ON with DTC P059A71
      • T-TCI-5510
    • T-SB-0023-22: MY22 Tundra: Head Unit Software Update (Panasonic) - Rev1
      • T-TCI-5507
    • T-SB-0057-22: MY22 Tundra, Tundra HV (Platinum, 1794, TRD Pro, or LTD w/ Power Package): SRS MIL ON - Qi Charger Interference
      • T-TCI-5542
    • T-SB-0068-22: MY22 Tundra: Howl Noise from Front Lower Control Arms
      • T-TCI-5552
    • T-SB-0069-22 Rev. 1: MY22 Tundra, Tundra HV: Electronic Power Steering (EPS) Light ON with DTC(s) C05D604 and/or C15D704
      • This has been updated to Rev. 1
      • T-TCI-5556
    • T-SB-0070-22 Rev. 1: MY22+ Tundra, Tundra HV: Rear Air Suspension Feels Rough Over Bumps
      • T-TCI-5553
    • T-SB-0110-22: MY22+ Tundra: Pop/Clunk Noise on Initial Engine Start (Cold)
      • T-TCI-5586
    • T-SB-0111-22: MY22+ Tundra: Hesitation From Stop and Surge Concerns
      • T-TCI-5585
    • T-SB-0114-22: MY22+ Tundra, Tundra HV: Loose Side-seal Retainer Under the Tonneau Cover Weather Strip/Side-seal
      • T-TCI-5579
    • T-SB-0718-22: MY22 Tundra, Tundra HV: MIL ON w DTC(s) P017400 and/or P043000 - Debris In Bank 2 Fuel Delivery Pipe
      • No Canadian equivalent
    • T-SB-0004-23: MY22 Tundra HV: Coil Spring With Bowed Appearance - TRD Pro Specific
    • T-SB-0010-23: MY23 Tundra, Tundra HV: Head Unit Software Update (Panasonic)
      • T-TCI-5590
    • T-SB-0023-22 Rev. 2: MY22 Tundra, Tundra HV: Head Unit Software Update (Panasonic)
      • This has been updated to Rev. 2
      • T-TCI-5507 Rev. 2
    • T-SB-0021-23: MY22 Tundra: HVAC Drain Hose Disconnected From HVAC Case and/or Oil/Grease Odor From Vents
      • T-TCI-5600
    • T-SB-0022-23: MY22 Tundra, Tundra: Abnormal Fuel Gauge Operation and/or Low Oil Pressure Gauge Reading
      • T-TCI-5608
    • T-SB-0030-23 Rev. 2: MY22-24 Tundra, Tundra HV; MY23-23 Sequoia HV: Poor Acceleration and/or MIL ON With DTC(s) P017400, P117B00, and/or P043000
      • Originally Released June 1, 2023
      • August 11, 2023 - Rev. 1
      • May 23, 2024 - Rev. 2
    • T-SB-0046-23 Rev. 1: MY22-23 Tundra HV, MY23 Sequoia HV: MIL On With DTC(s) P060649 and/or P060647
    • T-SB-0007-24: MY22-23 Tundra, Tundra HV: Front Seat Cushion Shield Loose/Broken
      • Released Feb 14, 2024
    • T-SB-0012-24: MY22-24 Tundra, Tundra HV: Head Unit Software Update (Panasonic) - All Head Units to Version 2050
      • Released March 4, 2024
    • T-SB-0018-24 Rev. 1: MY22-24 Tundra HV, MY23-24 Sequoia HV: Vehicle Starts in Second Gear, Unable to Shift Into First Gear
      • Released April 1, 2024
      • Updated to Rev. 1 on April 15, 2024
    • T-SB-0019-24: MY22-24 Tundra, Tundra HV: Difficulty Starting Engine in Below Freezing Temperatures
      • Released April 2, 2024
    • T-SB-0026-24: MY22-24 Tundra, Tundra HV; MY23-24 Sequoia HV: Subwoofer Rattle or Buzz Noise
      • Released April 11, 2024
    • T-SB-0043-24: MY22-24 Tundra: Front Brake Squeal
      • Released May 6, 2024
      • **TUNDRA HV does not appear to be included in this TSB**
    • T-SB-0050-24: MY22-24 Tundra: MIL ON with DTC P162B87 and/or DTC P15AD87
      • Released May 20, 2024
    If a TSB has "MY22 Tundra" listed, it is only for the 2022 Tundra.
    If a TSB has "MY22+ Tundra" listed, it is for the 2022 and 2023 Tundra.
    If a TSB has "MY23 Tundra" listed, it is only for the 2023 Tundra.
    If a TSB has "MY24 Tundra" listed, it is only for the 2024 Tundra.
    Tundra = Non-Hybrid Tundra
    Tundra HV = Hybrid Tundra
    Changelog
    February 2, 2024 - Initial Post
    February 15, 2024 - Added T-SB-0007-24
    March 5, 2024 - Added T-SB-0012-24
    April 2, 2024 - Added T-SB-0018-24 & T-SB-0019-24
    April 11, 2024 - Added T-SB-0026-24
    April 16, 2024 - Updated T-SB-0018-24
    May 7, 2024 - Added T-SB-0043-24
    May 21, 2024 - Added T-SB-0050-24
    May 23, 2024 - Updated T-SB-0030-23 to Rev.2
    SKMat7, pwpblue, kirkb and 13 others like this.
  2. Feb 2, 2024 at 10:29 AM
    BoomBoomGanoom
    BoomBoomGanoom New Member
    Corey
    2023 Tundra Limited off-road
    Hopefully they will add 2023 models to the abnormal fuel gauge reading when parked on an incline. And hopefully a TSB for the wind noise coming from the window seals.
  3. Feb 8, 2024 at 8:47 AM
    Jay18
    Jay18 New Member
    Western New York
    2014 Black Tundra
    Are the 2024 models covered under MY22+ or are the 2024 separate from that and no TSB's apply to the 2024 yet? It seems to me that I am experiencing the T-SB-0111-22
  4. Feb 8, 2024 at 9:00 AM
    Kap1
    Kap1 New Member
    San Francisco, CA
    THANK YOU!
    if possible please add dates of release so we know which ones are the newest and make sure we don't miss it.
  5. Feb 8, 2024 at 9:01 AM
    ryanwgregg
    DFW, TX
    VXKA75L-PSUZZA
    You have a completely different Calibration suffix to the 2022 & 2023 model years…
  6. Feb 8, 2024 at 10:16 AM
    rlc177
    rlc177 Data Logger
    Northeast PA
    I suspect the 2024 have newer calibrations because they changed the actual ECU hardware but are actually running the exact same programming as the previous trucks.
    ryanwgregg[OP] likes this.
  7. Feb 8, 2024 at 10:31 AM
    nodak67
    nodak67 New Member
    JR
    do they still add a yellow sticker under the hood with the changes to the firmware/software?
  8. Feb 8, 2024 at 11:38 AM
    ryanwgregg
    DFW, TX
    VXKA75L-PSUZZA
    Not on a new build…and I don’t have any stickers for the TSBs that have been performed on my truck…
  9. Feb 9, 2024 at 4:41 AM
    dashmer
    dashmer New Member
    Why is this thread not a sticky?
    Thanks for putting it together.
    KClav, az 3rdGen and Mattedfred like this.
  10. Feb 15, 2024 at 11:26 AM
    ryanwgregg
    DFW, TX
    VXKA75L-PSUZZA
    Updated OP...added T-SB-0007-24
    Kap1 and chaztizer like this.
  11. Feb 15, 2024 at 12:01 PM
    RallySauce
    RallySauce New Member
    Middle TN
    ‘23 MGM SR // ‘20 T4R ORP
    Official TSB for the seat panel? About time lol
    chaztizer likes this.
  12. Feb 17, 2024 at 7:00 PM
    Cassidy1866
    Cassidy1866 New Member
    2023 Tundra Limited TRD Off-Road
    I’ll second the motion.
    Moderators: would you please make this fantastic resource a sticky?
    (Thanks @ryanwgregg )
  13. Feb 18, 2024 at 4:52 AM
    dekeman
    dekeman New Member
    Derek
    Ottawa, ON, CANADA
    2022 Tundra Limted TRD
    Thank you for the Canadian equivalents! :canada:
    ryanwgregg[OP] and Mattedfred like this.
  14. Feb 18, 2024 at 8:31 AM
    BossDawg24
    BossDawg24 New Member
    Mark
    Cumming, GA
    2023 Tundra Capstone Blueprint, 2017 1794 Barcelona Red
    None
    Any TSB for the creaky front seat? My dealer says they have many with same issue but have been given no solution from Toyota.
  15. Feb 18, 2024 at 8:51 AM
    OLV1071571
    OLV1071571 New Member
    2024 Silver Limited CrewMax 5.5ft
    Same here. Scrunchy front seats due to airflow from cooled seat option.
  16. Feb 18, 2024 at 10:18 AM
    ryanwgregg
    DFW, TX
    VXKA75L-PSUZZA
    The thread is current as of today. Nothing to report on the creaky seat…
    OLV1071571[QUOTED] likes this.
  17. Mar 5, 2024 at 4:33 AM
    ryanwgregg
    DFW, TX
    VXKA75L-PSUZZA
    Updated OP...
    BoomBoomGanoom likes this.
  18. Mar 5, 2024 at 6:35 AM
    mcgill93
    mcgill93 New Member
    Joseph
    2024 Toyota Sequoia
    non
    What does this new HU update do that we should be looking for?
    T-SB-0012-24:MY22-24 Tundra, Tundra HV: Head Unit Software Update (Panasonic) - All Head Units to Version 2050
  19. Mar 5, 2024 at 12:09 PM
    machd08
    machd08 New Member
    CLARENCE
    South Carolina
    2023 Tundra Platinum IForce Max
    AFE Air Intake & Go Rhino E-Boards, Dirty Deeds Exhaust & TRD Off Road Grille & Chrome Stoppers grille surround, TRD OR Lift, TRD Sway Bar, Cooper AT3 275/65/20, Locker Down Safe, MTS/Crawl mode switch, Talons Garage Skid Plate, AVS bug gaurd/window, Dirty Deeds Cat Back Exhaust
    Is this one we can do over the air or do we need to take it to the dealer? Just wondering, nothing showing up on software update. Thanks
  20. Mar 5, 2024 at 12:10 PM
    ryanwgregg
    DFW, TX
    VXKA75L-PSUZZA
    Nothing as of yet...TSB was released but that's it...
    machd08[QUOTED] likes this.
  21. Mar 5, 2024 at 12:11 PM
    machd08
    machd08 New Member
    CLARENCE
    South Carolina
    Thanks Ryan
  22. Mar 5, 2024 at 12:34 PM
    mcgill93
    mcgill93 New Member
    Joseph
    2024 Toyota Sequoia
    non
    I checked my HU version and it shows 2050 already.
  23. Mar 5, 2024 at 12:38 PM
    ryanwgregg
    DFW, TX
    VXKA75L-PSUZZA
    It will for some…
  24. Mar 5, 2024 at 12:53 PM
    mcgill93
    mcgill93 New Member
    Joseph
    2024 Toyota Sequoia
    non
    So then what did the upgrade add or change or what?
  25. Mar 5, 2024 at 1:35 PM
    ryanwgregg
    DFW, TX
    VXKA75L-PSUZZA
    Coming soon...working on a thread that has all the information for each update that has come out...
  26. Mar 5, 2024 at 1:35 PM
    Chugbug
    Chugbug New Member
    2023 Platinum, Midnight Black
    Thanks Ryan!!!
  27. Mar 5, 2024 at 1:38 PM
    mcgill93
    mcgill93 New Member
    Joseph
    2024 Toyota Sequoia
    non
    Yes. Thanks Ryan
  28. Mar 5, 2024 at 4:12 PM
    Rex
    Rex New Member
    2023 SR5 CrewMax 4x4 TSS
    I called the dealer today to check on parts / timing of my existing 2023 TSB/Recall/etc. They are still waiting on parts and said another 5-7 business days. I got the process started a few weeks ago.
  29. Mar 5, 2024 at 5:03 PM
    genchi genbutsu
    genchi genbutsu New Member
    '22 218 Tundra TRD Sport
    The infotainment update 2050 is being rolled out phases OTA. You will get notified on your unit.
    It's all basically bug fixes.
  30. Mar 5, 2024 at 6:29 PM
    OLV1071571
    Bug fixes fine but I want feature updates like split screen.
    arrampico, machd08 and sandiegosteve like this.
