OEM Tow Mirrors on a 2017 (issues?)
Discussion in '2.5 Gen Tundras (2014-2021)' started by PNW-Tundra, Jun 27, 2017.
  1. Jun 27, 2017 at 9:13 AM
    PNW-Tundra
    PNW-Tundra [OP] New Member
    Brent
    Washington
    2017 Crew Max SR5 TRD
    My local dealer just told me that it would be a crap shoot to add the OEM tow mirrors to my 2017 after the fact. They told me that there are like 25 different possible wiring harnesses that are used in the Tundras, so the OEM tow mirrors may or may not work depending on which wiring harness is in the truck. He said the harness is about $3k, and they can't take returns on the tow mirrors if they end up not working. He said if it didn't come from the factory with tow mirrors, then aftermarket mirrors will be my best option. :mad:
    I read on another thread of one other guy being told the same by his dealer. Anybody else hear this, or know if there is a way to identify if the truck has the correct wiring harness?
    KrazieZ likes this.
  2. Jun 27, 2017 at 9:51 AM
    PNW-Tundra
    Brent
    Washington
    I also just got off the phone with K Source, and she said their mirrors will work, but I will only retain the factory options, even though the mirrors will have the turn signals.
  3. Jun 27, 2017 at 9:53 AM
    chphilo
    chphilo Tundra addict
    Western PA
    Your dealer is full of $hit. Tow mirrors are plug-and-play. For SR5, you will gain turn signal function as well as marker light. For some reason, higher trim Tundras don't play nice with tow mirrors (they lose marker lights and BSM doesn't work), but for an SR5 Tundras, it's one of the easiest mods.
  4. Jun 27, 2017 at 10:02 AM
    chphilo
    Western PA
    I am not familiar with K Source mirrors. If what they tell you is true, I would stay away from their products. (But even after-market tow mirrors are plug-and-play)
  5. Jun 27, 2017 at 10:49 AM
    Grege
    Grege New Member
    Greg
    2017 SR5 Crewmax White
    Spray in box liner, Running boards and tow mirrors soon Tonneau cover
    I just purchased a 2017 Crewmax and dealer is adding tow mirrors prior to me picking it up in 2 days (Thursday). They don't say anything about an problems. Did you call another dealer. Doesn't seam reasonable for a company to use so many variations of wiring on one vehicle . Second if they change wiring harness mid year its usually to add more connections for additional features such as side camera's, lane change warning sensors so its all same wiring for all models. Just my opinion
  6. Jun 27, 2017 at 10:50 AM
    KrazieZ
    KrazieZ New Member
    Zachary
    2017 Toyota Tundra sr5
    K&n filter, leather seats, stubby antenna
    So if you upgrade tundra sr5 you will gain turn signal as well as a marker light ?
  7. Jun 27, 2017 at 11:02 AM
    PNW-Tundra
    Brent
    Washington
    I haven't called another dealer yet, but I am going to.
    I have read on here this is true for the older Tundras, but I haven't been able to find a post confirming it's true on the 2017's.
    KrazieZ[QUOTED] likes this.
  8. Jun 27, 2017 at 11:23 AM
    texasflyer
    texasflyer New Member
    2016 MGM Crewmax
    Magnuson S/C, BD Tuner, TRD Exhaust, TRD Rear Sway Bar, TRD Pro Grill, TRD Wheels, TRD Shift Knob, Escort Passport 9500ci Radar/Laser Detector, Retrofit Headlights (RX350 Projectors), Morimoto XB LED Fog Lights, Retrax Pro MX, Ceramic Tint, ESP Full Length Storage Box, Console Vault, Driver Side Grab Handle, WeatherTech Floor Liners, Diff Breather Mod, Color Matched Front End Bumpers, Color Matched Door Handles and Mirror Caps, Black TRD "Tundra" and "iForce" Badges, Removed chrome badges
    Here is my experience from installing OEM Tow Mirrors on a 2016 Limited:
    OEM Tow Mirrors are plug and play. (30 minute install for both sides.) You will keep power adjustment and heat. You will gain turn signal (even if you didn't have it on your original mirrors). You will lose BSM (even if you did have it on your original mirrors.)
    Krezz, Black Wolf, Y0TA PR0 and 2 others like this.
  9. Jun 27, 2017 at 11:33 AM
    Whata your model? limited.. Platinum sr5?...sr5 plug n play heated parking light n turn signal work believe u loose parking light only on limited n platinum n gain bsm
    GNTundra likes this.
  10. Jun 27, 2017 at 11:34 AM
    Check out 1A-Auto.com half the price of oem
  11. Jun 27, 2017 at 12:06 PM
    PNW-Tundra
    Brent
    Washington
    Thank you for this info. I think I may just order them and find out. There is a guy at work with an older Tundra who is also looking to buy tow mirrors, so I'm sure I could get him to take them off my hands if they don't work on my truck for some reason.
  12. Jun 27, 2017 at 12:07 PM
    PNW-Tundra
    Brent
    Washington
    Thanks. I had some aftermarket ones on my Chevy, and the glass vibration drove me nuts. Wanting to stick with OEM this time provided they will work.
    Tundra805 likes this.
  13. Jun 27, 2017 at 12:23 PM
    PNW-Tundra
    Brent
    Washington
    Other dealer just told me they will work, I would just lose power fold and memory if my truck had those options from factory. They wanted $289 per mirror though. Time to order from one of the vendors here then.
    Y0TA PR0 likes this.
  14. Jun 27, 2017 at 1:17 PM
    Y0TA PR0
    Y0TA PR0 Oil & Gas ⛽️
    Rafael
    2017 TRD PRO
    ^this
    darkknight2014 likes this.
  15. Jun 27, 2017 at 1:19 PM
    Y0TA PR0
    Rafael
    2017 TRD PRO
    Welcome. You should start a thread on
    NEW MEMBER INTRODUCTION. :thumbsup:
  16. Jun 27, 2017 at 2:17 PM
    PNW-Tundra
    Brent
    Washington
    Well, my tow mirrors will be here tomorrow, so I'll let everyone know how it goes.
    KrazieZ and Y0TA PR0 like this.
  17. Jun 27, 2017 at 6:07 PM
    bobeast
    bobeast really old member
    Bob
    Hollister, CA
    2008 DC
    When you ask a dealer "can you do something", what they hear is "do you want to do something". They almost never answer the question that was asked unless they see a profit in the answer. Your SR5 doesn't have many of the "features" of the higher trim levels, so best case it would be plug and play. Worse case you may have to run an additional wire or two for your marker lights or heating elements. Your basic functions like motorized adjustment and turn signals should work fine.
    PNW-Tundra[OP] likes this.
  18. Jun 27, 2017 at 6:48 PM
    PNW-Tundra
    Brent
    Washington
    Possibly true in a lot of cases, but I didn't even want them to Instal them for me. I just wanted them to order them for me. :)
  19. Jun 27, 2017 at 7:39 PM
    chphilo
    Western PA
    For SR5, you will retain heat function and power adjust. You will gain marker light and signal light.
    If your truck came with BSM, you will lose that function. For some odd reason, upper trim Tundras will also lose the marker light. Power fold function is available but that requires buying a set of tow mirror with that function (typically twice as expensive).
    I am not sure what the latest updates of some after-markets tow mirrors are. When I was shopping for mine, I read some people reporting vibration with non-Toyota brand. That's why I went with Toyota brand.
    My local dealer asked for $150 for just for installation so I did it myself. I am not a mechanic, but even I found installation pretty easy. The most difficult part for me was to making sure to not let the screws that holds the mirrors fall into the door panel (some people have done that). Other than that, it was pretty easy.
  20. Jun 28, 2017 at 12:27 AM
    TTund16
    TTund16 New Member
    wondering if any factory tow mirror comes with BSM? maybe that functionality is considered useless when towing!
    what about the expensive platinum or 1974 models with tow mirror, they must not have BSM either!
    compared to competition, Tundra is always behind in gadgety stuff ... but we buy it for mechanical reasons! :D
  21. Jun 28, 2017 at 6:06 AM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    Check out A1 auto. They have several mirrors. I was looking a few months back. I have the platinum and u don't think they had tow mirrors with all the same capabilities of my oem mirrors. I think they do have BSM but I don't think they came with power fold and visa versa
    TTund16[QUOTED] likes this.
  22. Jun 28, 2017 at 6:36 AM
    Alloutdrs1
    Alloutdrs1 New Member
    Andrew
    Virginia Beach, VA
    Anyone on here have the 1A mirrors? I am about to pull the trigger on a set of tow mirrors as well and the price of the 1a looks great if they don't vibrate at highway speeds.
  23. Jun 28, 2017 at 6:40 AM
    Pudge
    CT
    I have one of their non towing mirrors. It's fine, seems as solid as oem except the glass is clearer, not autodimming but after a week I didn't notice. I have heard mostly good things about their tow mirrors
  24. Jun 28, 2017 at 7:01 AM
    KrazieZ
    KrazieZ New Member
    Zachary
    Sorry but what is bsm?
  25. Jun 28, 2017 at 7:18 AM
    Pudge
    CT
    Blind spot monitoring
  26. Jun 28, 2017 at 7:18 AM
    PNW-Tundra
    Brent
    Washington
    Blind spot monitoring. Vehicles that have it, a light comes on, on your side mirror, indicating a car is in your blind spot.
  27. Jun 28, 2017 at 7:20 AM
    PNW-Tundra
    Brent
    Washington
    I watched the video I saw on here, and it looks way easier than it was to swap the mirrors on my Chevy. $420 (darn sales tax) seemed pretty fair for the OEM's, so I went that way vs aftermarket.
  28. Jun 28, 2017 at 7:41 AM
    Bulldog_tundra
    Bulldog_tundra New Member
    USA
    2006 Double Cab
    Bilstein 5100 (Top Notch Front) 1” Rear Block Flowmaster 40 w/ 3” Tip Bumperplugs Front Plate Delete
    I ordered mine yesterday. I can't speak from experience (yet), but I dug through every Tundra site I could find, YouTube videos and google and read nothing but good things about the 1A Auto tow mirrors as well as constantly seeing they're as good as OEM.
    I'm one of those guys that goes OEM everything when it's available, but for some reason here I just couldn't justify the extra $200 when every review was positive and a couple side by side comparisons showed it was identical to OEM.
    There's a good video somewhere on the interwebs of 1A Auto comparing their tow mirrors vs. other aftermarket versions and it's pretty clear it's a top notch aftermarket part.
    Oh and 1A Auto commented on most posts backing their products and asking anyone with questions/issues to contact them back to 2013. The other aftermarket mirrors I saw had complaints of buyers not being able to contact the sellers with issues so take that for what it's worth.
    Hope this helps and saves you the couple of hours I spent researching
    PMG likes this.
  29. Jun 28, 2017 at 1:20 PM
    alalmcgrath
    alalmcgrath Old Fart at Large!
    Al
    Boulder Creek Ca
    2016 SEQUOIA SR5
    Th
    That 's funny. My 2011 only has 3 wires going to the mirrors. Power adjust AND THAT IS IT! I have been told and read many times that all I need to do to upgrade is add the full feature mirrors. No additional wiring needed. That is a bunch of bullcrap. The dealer is right.
  30. Jun 28, 2017 at 1:25 PM
    PNW-Tundra
    Brent
    Washington
    Here's my plug on my 2017. I only have power adjust and heat in my stock mirrors. Just picked up my tow mirrors, but don't have the right tools with me at work. If all goes well, I will get them on tonight and find out.
