OEM Switch for lightbar Help!
Discussion in 'Lighting' started by TRD15559, Mar 15, 2016.
  1. Mar 15, 2016 at 1:13 AM
    TRD15559
    TRD15559 [OP] 559yotas
    fresno california
    15' PRO CM
    Yes, still stock Pro suspension...
    So I got a 40" Rigid Radiance light bar coming in tomorrow that I'll be installing in the grill. Now I want to keep the stock look. I've looked at AOB and OTRA. But the problem is that the radiance bar requires 2 switches. One for the backlight , the other for the light bar. I don't have 2 open slots. So here's what I'm thinking. This switch is in most Toyotas that have heated seats now... If I can find one at a junkyard.. Do you think I can wire them to the 2 lights ? The L would control the backlight and the R would turn on the bar. Has anybody done this ? I know it's possible , but I have no experience in electronics so any help would be appreciated ! ImageUploadedByTapatalk1458029554.159043.jpg
  2. Mar 15, 2016 at 5:39 AM
    RowdyRon
    RowdyRon SouthBoundSteve Fan Club President
    Ron
    Bentonville, AR
    2015 Radiant Red TSS Doublecab 4X4 Off Road
    Deck rail system, Bed divider, door sill protectors, LED reverse light bars, Aries Bull Bar with 28" 180 watt LED light bar, LED step lights, LED bed lights, driver-side grab handle, TRD Rear Sway Bar, BedRug bed mat and tailgate mat, Morimoto Fog Lights, more to come.....
    I'm not familiar with the light bar you are mounting but I just recently installed a 200 watt light bar on my truck and used a switch from www.your4x4store.com. It is cheaper than the AOB switch by about $10 I think. It is back lit when parking lights/headlights are turned on and lights further when the light bar is turned on. Not sure why you would need 2 separate switches with your application. The switch I have uses 4 connectors: 1 connects to my ignition/accessory source tap using a 3 amp fuse/add-a-fuse, 1 connects a trigger wire (Pin 86) to my relay to turn the light bar on, 1 connects to the dash illumination circuit of a neighboring switch (allows it to be back lit with the parking lights/headlights turned on), and 1 is a ground wire for the switch. Let me know if this doesn't make any sense and I will give more info...
  3. Mar 15, 2016 at 7:34 AM
    TRD15559
    fresno california
    15' PRO CM
    The light bar I'm referring to comes with 2 separate switches because it has a "backlight" feature that comes in 5 different colors. It has little LEDs in the housing that light up. Which is why it needs two switches so one switch turns the backlight and the other will turn on the actual light bar . ImageUploadedByTapatalk1458052409.638438.jpg
    ImageUploadedByTapatalk1458052314.837510.jpgImageUploadedByTapatalk1458052331.056213.jpg
  4. Mar 15, 2016 at 7:37 AM
    Sean266
    Sean266 Mr. Clean Staff Member
    Good choice on the light manufacturer. BD and RI are solid!
  5. Mar 15, 2016 at 7:45 AM
    RowdyRon
    Ron
    Bentonville, AR
    Ok, I understand the need now with the wiring harness. Wish I could assist but, no experience with this type set up. Good luck with your install.
  6. Mar 17, 2016 at 10:03 PM
    TRD15559
    fresno california
    15' PRO CM
    Got the bar mounted today. Thinking about just getting the sPOD setup and be done with it . ImageUploadedByTapatalk1458277372.570243.jpg
    RowdyRon likes this.
  7. Jan 27, 2018 at 7:58 AM
    zlaneb
    zlaneb New Member
    Did you ever find a single switch that could run both the back lighting and the light bar independent?
