Octane if towing
Discussion in 'Towing & Hauling' started by T-Guy69, Dec 15, 2019.
  1. Dec 15, 2019 at 8:14 AM
    T-Guy69
    T-Guy69 [OP] New Member
    Long Island
    Black 2020 Tundra SR5
    This is on my Ridgeline. I was towing my car down to New Jersey Motor Sports. One the way down I put Premium (93)in to see if there was a difference. I used the entire tank on the way down. On the way home, I used Regular (87). I got half the distance and had to refuel.
    My hypothesis is that the Regular must have caused knocking. Maybe the computer retarded the timing, which knocked the bottom out of performance and gas mileage.
    Or maybe NJ is uphill to NY ;)
    Has anyone tried different octane and noticed a difference?
  2. Dec 15, 2019 at 8:18 AM
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    NY is mostly higher in elevation than NJ...I would assume very little had to do with the octane and more with the surface profile on the route...Higher octane does help, but not an incredible amount on N/A vehicles...
    snivilous, Rica25 and TTund16 like this.
  3. Dec 15, 2019 at 8:22 AM
    Jrharvey02
    Jrharvey02 New Member
    2010 Tundra CM 5.7 Platinum Dark Black
    Yes, higher octane gets you better mpg, but not anywhere near 50% better as your hypothesis suggests. much more to do with terrain, elevation, wind, etc.
  4. Dec 15, 2019 at 8:34 AM
    triharder
    triharder Sorry, Not Sorry
    Jake
    Southern, Maine
    2010 RWB Black
    Billstein 6112/5160's, coachbuilder spacer on driver side/ 20" rockstar wheels/ 33" nitto ridge grappers/SS Brake lines (or as most people write Break), Painted Calipers/Powercoated Tow hooks/pocket flairs/heated seats,bed leds/line-x liner/xtang trifold/tow mirrors/Stereo Work/Compustar Remote Starter/ retrofit Morimoto Minin H1 and switch back LEDs/ plenty I'm forgetting
    Jrharvey02 and 1794x4 like this.
  5. Dec 15, 2019 at 8:52 AM
    WNY PAT
    WNY PAT New Member
    Western New York
    2017 Crewmax Limited (Mines) 2019 Crewmax SR5 (Work)
    If I remember right, the Honda recommends using premium when towing with the RL. My guess is you were a victim of wind and terrain... and maybe the pump shut off too early and you weren’t really full? When I used to drive from Buffalo NY to Albany to see family, I’d always get 3-4 MPG better driving East to Albany. Coming back west, of course, I was generally driving in to the prevailing winds... maybe terrain too. ThTs what I always figured at least.
  6. Dec 15, 2019 at 9:00 AM
    Green Thunder
    Green Thunder Smooth in the Cruise
    Washington
    2020 Burnt Green TRD Pro
    Food crumbs and dog fur
    There would have to be a massive energy density difference between the two fuels, which there isn't. If there was, we'd all be buying premium because it would pay for itself. The Ridgeline is new enough to know the difference in octane, so you're being hit by terrain and wind differences. Even a slight uphill or downhill will make a big difference in MPGs.
    TTund16 likes this.
  7. Dec 15, 2019 at 10:17 AM
    flyfisher
    flyfisher Member
    David
    Sunnyvale, CA
    2005 Tundra SR5 Double Cab 4x4
  8. Dec 16, 2019 at 6:02 AM
    T-Guy69
    Long Island
    I did not check the exact miles. But to the point you are making, it may not be 50%. I would have to agree. Plus gas was cheaper in NJ than NY. So I may have seem I was using more gas and filled up in NJ. But the point I made is supported by the video, the regular gas caused knocking under the load of the heavy car trailer and car. It retarded the timing and thus less MPG and less performance.
  9. Dec 16, 2019 at 6:03 AM
    T-Guy69
    Long Island
    You are 100% correct.
  10. Dec 16, 2019 at 6:17 AM
    15whtrd
    15whtrd Mr. Blonde
    I’m going to have to ask. Why are you using your Ridgeline to tow a car when you have a perfectly good Tundra that is made for it? I don’t imagine gas mileage was much better with the car behind the Ridgeline.
    NewImprovedRon likes this.
  11. Dec 16, 2019 at 7:09 AM
    T-Guy69
    Long Island
    I ordered my 2020 Tundra last week. It should be here late Feb 2020 or March 2020. The Ridgeline trans went at 100,000 and now, at 211,000 I feel it slipping again. So, while I considered the Ridgeline Black edition, the 5,000 tow limit may be exceeded. That also ruled out a Tacoma. I have a Corolla XRS now and went with a Toyota due to reliability and towing capacity.
    15whtrd and SprinterAE86 like this.
  12. Dec 16, 2019 at 7:43 AM
    SprinterAE86
    SprinterAE86 New Member
    Ian
    Charlottetown, PE, Canada
    2012 Toyota Sequoia Platinum
    What are you towing. With my open trailer I have to remove or adjust my aero foil on my car to get better mileage. And yes, elevation makes difference even.
  13. Dec 16, 2019 at 9:19 AM
    T-Guy69
    Long Island
    I have JB Enterprise Trailer and I pull my car to various tracks like NJMS and Lime Rock (I miss Bridgehampton). I also tow my 17 foot Proline from Mount Sinai to Montauk.
  14. Dec 16, 2019 at 10:44 AM
    Stumpjumper
    Stumpjumper New Member
    Fate, Tx
    2017 Tundra TSS 4x4
    I have gotten as much as 2.3 MPG difference on a 200 mile drive depending on the wind direction. I drive mostly north south this time of year when headed to hunting ranch. Wind can make a big difference but temperature can do. I will average almost 1 mpg less in cold temps.
  15. Dec 16, 2019 at 11:12 AM
    Devcom
    Devcom Miles per Gallon? More like Smiles per Gallon!!
    2018 Blazing Blue Tundra Double Cab SR5 5.7L 4x4
    I still use 87 when towing and have had no issues and it pulls great. On average I get 10-11 towing mpgs for the most part.
    EDIT: I have no idea with a Ridgeline just read the title and assumed you meant the Tundra.
