NSV Light Bar on 2019 Pro. Help
Discussion in 'Lighting' started by fatalkhaos, Jan 13, 2019.
  1. Jan 13, 2019 at 10:29 AM
    fatalkhaos
    fatalkhaos [OP] New Member
    2019 Tundra TRD PRO CM
    Sway Bar 20x10 Fuel Assault 295/55r20 Toyo AT
    So I ahve it installed now for the wiring... Headlight Revolution video is for older lights so not as easy as follow the video and the instructions read like jibberish. Looking for help
    ryanwgregg likes this.
  2. Jan 13, 2019 at 10:32 AM
  3. Jan 13, 2019 at 10:48 AM
    1UPPER
    1UPPER Not A New Member
    TEXAS
    Flux capacitor!
  4. Jan 13, 2019 at 4:18 PM
    fatalkhaos
    Did anyone get the added USB? Any install instructions to replace the lighter for it?
    Greywind Tundra likes this.
  5. Apr 15, 2020 at 9:21 PM
    Greywind Tundra
    Greywind Tundra New Member
    Stephen
    San Diego, CA
    2020 Cement Tundra TRD Off-Road CM
    @fatalkhaos im struggling with that double usb now....
  6. Apr 16, 2020 at 4:42 AM
    fatalkhaos
    You have to cut lighters wires and use those for the USB
  7. Apr 16, 2020 at 4:52 AM
    Tundyfundy
    Bay Area, CA
    Magnetic Grey DC SR5 4x4 2016
    SUSPENSION: Bilstein 6112 coilover (1.9") w/ Powder Coated Springs and Spring Perch (TRD Red), JBA Upper Control Arms, Bilstein 5160's w/Billet Aluminium Reservoir Brackets, +2 Coachbuilder Shackles, Diff Drop Kit, Carrier Bearing Drop Kit, Brakeline Extensions, ABS Extension, Poly Bushings for Leafs, Coachbuilder Shims (2 Each Side), Coachbuilder Bumpstop Extensions, TRD Rear Sway Bar, TRD Front Sway Bar, Air Lift 5000 airbags w jounce bumpers, Daystar Airbag Cradles WHEELS AND TIRES: BF Goodrich KO2's 275/70/r18, BORA wheel spacers 1.25", TRD Wheel Caps,TRD Valve Stem Caps, Spare Tire Lock PERFORMANCE: Bullydog GT Tuner(Performance Tune), TRD Intake, TRD Dual Exhaust (with Modified Exhaust Hangers for Levelling Tail Pipe),TRD Brake Pads, TRD Oil Cap (US), TRD Radiator Cap, TRD Oil Filter, Optima Yellow Top Battery,GP Battery Distribution Blocks, StopTech Slotted Cryo Treated Rotors, Goodridge G-Stop Steel Braided Brake Line Kit PROTECTION: PNP Engineering Type 4 Rock Sliders (With Full Dimple Plate) ,ADD Stealth Fighter Rear Bumper w Red/Blk Shackles and Custom Stomp Pad, TRD Skid Plate with ReadyLift Spacer Kit, Victory 4x4 LCA Skid Plates, JOMAX ABS Sensor Armor, Rear Diff Breather Mod, ARK splash guards INTERIOR: Husky Liners X-Act (Front and Full Coverage Rear and Front Weather Beater Trans Hump), Interior LED Bulbs, WheelSkins Genuine Leather Steering Wheel Cover(EuroPerf), Clazzio Genuine Leather Seat Covers(BLK/DRK GRYwith custom stitching and embroidered headrests), Clazzio Seat Heaters (Front and Rear), Entune Startup Screen MOD, Entune Off Screen Mod, Tinted Windows with Windshield Visor, AJT Key Fobs,Eagle Claws Floor Mat Clips, Bodyglove Visor Organizer,Custom Door Cup Inserts, Glass Break Sensor,AJT Radio Knobs, Custom Dior Cup Inserts EXTERIOR: Full Debadge, LED Brake Light Bulbs, LED Rear Turns, LED Reverse, LED Plate Lights, LED Cargo Lights, LED Third Brake Lights, LED Front Marker Lights, LED Fog Light Bulbs, Lamin-X Fog Light Covers (Amber),2018 OEM LED Headlights, iHacker harness, VLED Universal Puddle Lights, VLED Interior Footwell Lighting (Front and Rear),VLED Extreme Amber Fornt Turns, NSV Knight Rider Light bar, Baja Designs Sport Squadron Pods in Rear Bumper (Driving/wide), Painted Red Tow-hooks, Bed Rail System, Blind Spot Mirrors, Hitch-safe, Tail-gate lock, EAG Raptor Grille, Custom Grille Badge,Full Vinyl Wrap (Matte Black/Matte Pine Green Mettalic), Charvonia Designs Tie Bed Tie-Downs, Bull Ring Bed Rail Anchors, Line-X, Tundra Bed Mat, Bakflip F1 Bed Cover SOUND: Noico 80Mil Sound Deadening and Noico 170 Mil Thermal Insulation (All 4 Doors, Roof, Floors, Rear Panel, Dash). Hertz Uno K170's Component Speakers (Front Doors with Upgraded Sail Panels), Hertz Uno K170 Coaxial Speakers (Rear Doors), JBL C1-075ct Tweeters (Total 4) in Side Dash and Center Speaker, JBL Stadium 5 Amp w/Remote Bass Adjustment Knob and Amp Rack, 12" Infinity Reference Subwoofer in Custom Enclosure w/ “TUNDRA” Logo, Fast Rings Foam Speaker Rings System(4 Doors), Fix 86 DSP
  8. Apr 16, 2020 at 7:54 PM
    Greywind Tundra
    Stephen
    San Diego, CA
    how many original lighter wires did you have? I only have two but there are 4 on the new double usb. I know it’s not designed for my 2020 but still trying to make it work..
  9. Apr 23, 2020 at 5:53 AM
    fatalkhaos
    If i remember correctly there is a red/black and grey/black.
    I can link you to there support giy he was great and helped me do a couple things I was unsure of
  10. Sep 2, 2020 at 6:49 AM
    Beesta
    Beesta New Member
    Jay
    Loudoun County
    2019 Pro Midnight Black Metallic
    Hey guys .. as far as the 2 T taps ignition and illumination... on 2019 PRO did you all go to the cig lighter or trailer hitch ...? I went to the cig lighter per video but i’ve notice that the DRL on NSV does not dim auto when headlight and fogs comes on ..? Will that fix it if i went to the trailer hitch instead ..? Thank you much ..
