not shifting 5th or 6th
Discussion in 'New Member Introductions' started by krisfelmet, Dec 30, 2021.
  1. Dec 30, 2021 at 7:26 AM
    krisfelmet
    krisfelmet [OP] New Member
    kris
    2007 tundra 5.7 2wd
    none
    Good morning, searching for some help, My 2007 tundra 5.7 2wd 328,000 miles will not shift out of 4th gear into 5th or 6th my check engine light is on, vsc and traction control lights are all on. The code read it as a solenoid in the transmission.
  2. Dec 30, 2021 at 8:17 AM
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    Sounds like you need a solenoid replaced in the transmission. I would take it to a trans shop unless you want to tackle it yourself.
  3. Dec 30, 2021 at 8:19 AM
    Johnsonman
    Johnsonman New Member
    Austin
    Sequoia
    I'd try a drain/fill first....
  4. Dec 30, 2021 at 9:25 AM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    BTW, Welcome from LA (Lower Alabama)!
