not on sticky so 295/65/20s on 1794
Discussion in 'Wheels & Tires' started by trw008, Feb 28, 2021.
  1. Feb 28, 2021 at 2:36 PM
    trw008
    trw008 [OP] New Member
    Does anyone have any experience on putting on 295/65s/20s Toyo open country MT on a 1794 2016 model?
    Curious if this will be possible on stock
    or if it needs a level first and even thing does it then need trimming/mud flap removal?
  2. Mar 1, 2021 at 8:59 PM
    2019-1794 New Member
    2019 1794 Crew Max 4x4
    Gonna need at least a level and some trimming. That’s a true 35” OD tire
    size.
  3. Mar 2, 2021 at 9:40 AM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    That size is a 35x11.6 so yes, at lease a level -2+ inches, address the flap and plastic wheel liner probably. Stock wheels may have the tires rubbing the UCA, may work but it could be tight. Choosing wheels that stick out from the truck more gives more room for the UCAs but then you may rub the body mount. But all this has been discussed at length in the tires and lifts threads here.
  4. Mar 2, 2021 at 9:43 AM
    Danman34
    Danman34 New Member
    Danny
    2018 White Tundra TRD Sport
    Not going to work on a stock truck. You’ll need at least 3-4” of lift and a new set of lower offset wheels in order to clear the UCA.
