**CLOSED**Northstar Battery - Group Buy 8.0**
Discussion in 'Deals & Group Buys' started by ramonortiz55, May 16, 2019.
  1. May 16, 2019 at 7:41 AM
    ramonortiz55
    ramonortiz55 [OP] I don't Even Own A Tundra
    Ramon
    2001 4runner, 2015 tacoma
    CLOSED
    I contacted the same vendor as the previous times and is down for another one.
    If the group size you want isn't available, please put your request in!
    Here we go guys!
    Northstar battery group buy!
    This one took me forever to get started. I tried contacting Excide, they expressed NO interest in this. I contacted Optima and they pretty much ignored my constant requests for a discount. I couldn't get a vendor to provide discounts on Odyssey.
    Northstar, on the other hand replied and directed me to a distributor that's more than willing to work with me with this one.
    For those that are only familiar with Optima, here is a little more information from Northstar:
    http://www.northstarbattery.com/1/2/3.php
    Here are the group sizes PER Toyota's website:
    Group size sizing:
    The groups sizes that will be included in this group buy are:
    24, 24M, 24F, 27, 27F, 34/78, 31M and 35
    See more here:
    http://buy.northstarbattery.com/
    Please make sure to do your research here:
    http://www.northstarbattery.com/northstar/engine/literature.php
    and here:
    http://www.fourwheeler.com/how-to/154-1303-battery-bashing/
    So what is the discount?
    We don't need to achieve every tier level for every battery group. The tier level is per quantity, regardless of how many batteries per group get ordered.
    FREE SHIPPING TO CONUS (ALASKA, HAWAII AND CANADA - will be custom shipping quotes) for ALL TIER LEVELS
    How do I sign up? Here!
    If you are interested in this:
    Sign up by replying to this thread. Don’t chicken out. You are either in or you aren’t. NO maybe, no waiting on the wife, gf or bf to get permission. There is enough time to make up your mind or find a doctor to sell your kidney or pawn your wife’s jewelry. If you are on the fence to see if it’ll go up to max discount before you jump in, you are HOLDING the group buy back. Don’t be that dude.
    Durobumps, FirstGenVol and Black Wolf like this.
  2. May 16, 2019 at 7:42 AM
    ramonortiz55
    Ramon
    List:
    1. @Run4Runnerr (t4r.org) - 31A
    2. @Ripcord - 27F
    3. @Littles - 35
    4. @Littles - 35
    5. @cekeel - 27F
    6. @tallpilot - 24F
    7. @08BajaBoy - 27F
    8. @whatstcp - 27F
    9. @DaMaDo - 27M
    10. @Toki - 27F
    11. @yota 4X4 - 27F
    12. @Mrbeer426 - 27F
    13. @Major (tundras) - 27F
    14. @jjckfc (t4r.org) - 24F
    15. @JasonLee - 27F
    16. @WildBill1990 (t4r.org) - 31A
    17. @Chewy (t4r.org) - 31M
    18. @unholymess (4runners) - 34M
    19. @whizz (t4r.org) - 35
    20. @whizz (t4r.org) - 35
    21. @Kleach18 - 27F
    22. @sleepybear723 (4runners) - 24F
    23. @jaketino (t4r.org) - 31A
    24. @sugjavier (t4r.org) - 24F
    25. @MJonaGS32 - 35
    26. @MJonaGS32 - 35
    27. @underaroof - 35
    28. @BlueYourMyBoy (tundras) - 27F
    29. @Jwlinthicum - 35
    30. @Jwlinthicum - 35
    31. @Cawolf - 24F
    32. @djm68 - 27F
    33. @bigfish 055 (tundras) - 27F
    34. @joonbug (tundras) - 27F
    35. @atcpup (t4r.org) - 24F
    36. @PNW_4thGen4R (t4r.org) - 27F
    37. @halflife78 (t4r.org) - 31M
    38. @fullofbs (tundras) - 27F
    39. @chilow (t4r.org) - 24F
    40. @mightym - 31M
    41. @TN4RNR (t4r.org) - 24F
    42. @buffalojay (t4r.org) - 24F
    43. @mulisharydr - 27F
    44. @Superman910 - 27F
  3. May 16, 2019 at 9:44 AM
    ramonortiz55
    Ramon
  4. May 16, 2019 at 9:44 AM
    ramonortiz55
    Ramon
    Ill ask
  5. May 16, 2019 at 10:22 AM
    realtorblake
    realtorblake Tundra Thunda
    Redneckistan... aka Cypress, TX
    2019 Crewmax Platinum 5" Zone lift Fox 2.5 /OME suspension 12.5x35x18 ProComp's
    The AGM34M is available for the group buy?
  6. May 16, 2019 at 10:34 AM
    Cement
    Cement ...
    2019 Cement Trundra TRD
    So if I have a "3UR" 5.7 in my 2019, am I reading it right that I'd want the 27F size?
    Or to put it another way, what model number for the biggest baddest NorthStar (winch, pod LEDs, 20" light bar...) I can fit in there with no modifications?
  7. May 16, 2019 at 10:49 AM
    ramonortiz55
    Ramon
    no sir
    NewImprovedRon likes this.
  8. May 16, 2019 at 10:49 AM
    ramonortiz55
    Ramon
    bruh.. Did you even see the product/availability list?
    blizz86 and Tundyfundy like this.
  9. May 16, 2019 at 10:50 AM
    ramonortiz55
    Ramon
    Its under "Marine"
  10. May 16, 2019 at 11:01 AM
    realtorblake
    I saw it on there... but this is what confused me.
    "The groups sizes that will be included in this group buy are:
    24, 24M, 24F, 27, 27F, 34/78, 31M and 35"
    I'm in on the buy. Thank you for getting the ball rolling!
  11. May 16, 2019 at 2:49 PM
    Tundyfundy
    Bay Area, CA
    Magnetic Grey DC SR5 4x4 2016
    SUSPENSION: Bilstein 6112 coilover (1.9") w/ Powder Coated Springs and Spring Perch (TRD Red), JBA Upper Control Arms, Bilstein 5160's w/Billet Aluminium Reservoir Brackets, +2 Coachbuilder Shackles, Diff Drop Kit, Carrier Bearing Drop Kit, Brakeline Extensions, ABS Extension, Poly Bushings for Leafs, Coachbuilder Shims (2 Each Side), Coachbuilder Bumpstop Extensions, TRD Rear Sway Bar, TRD Front Sway Bar, Air Lift 5000 airbags w jounce bumpers, Daystar Airbag Cradles WHEELS AND TIRES: BF Goodrich KO2's 275/70/r18, BORA wheel spacers 1.25", TRD Wheel Caps,TRD Valve Stem Caps, Spare Tire Lock PERFORMANCE: Bullydog GT Tuner(Performance Tune), TRD Intake, TRD Dual Exhaust (with Modified Exhaust Hangers for Levelling Tail Pipe),TRD Brake Pads, TRD Oil Cap (US), TRD Radiator Cap, TRD Oil Filter, Optima Yellow Top Battery,GP Battery Distribution Blocks, StopTech Slotted Cryo Treated Rotors, Goodridge G-Stop Steel Braided Brake Line Kit PROTECTION: PNP Engineering Type 4 Rock Sliders (With Full Dimple Plate) ,ADD Stealth Fighter Rear Bumper w Red/Blk Shackles and Custom Stomp Pad, TRD Skid Plate with ReadyLift Spacer Kit, Victory 4x4 LCA Skid Plates, JOMAX ABS Sensor Armor, Rear Diff Breather Mod, ARK splash guards INTERIOR: Husky Liners X-Act (Front and Full Coverage Rear and Front Weather Beater Trans Hump), Interior LED Bulbs, WheelSkins Genuine Leather Steering Wheel Cover(EuroPerf), Clazzio Genuine Leather Seat Covers(BLK/DRK GRYwith custom stitching and embroidered headrests), Clazzio Seat Heaters (Front and Rear), Entune Startup Screen MOD, Entune Off Screen Mod, Tinted Windows with Windshield Visor, AJT Key Fobs,Eagle Claws Floor Mat Clips, Bodyglove Visor Organizer,Custom Door Cup Inserts, Glass Break Sensor,AJT Radio Knobs, Custom Dior Cup Inserts EXTERIOR: Full Debadge, LED Brake Light Bulbs, LED Rear Turns, LED Reverse, LED Plate Lights, LED Cargo Lights, LED Third Brake Lights, LED Front Marker Lights, LED Fog Light Bulbs, Lamin-X Fog Light Covers (Amber),2018 OEM LED Headlights, iHacker harness, VLED Universal Puddle Lights, VLED Interior Footwell Lighting (Front and Rear),VLED Extreme Amber Fornt Turns, NSV Knight Rider Light bar, Baja Designs Sport Squadron Pods in Rear Bumper (Driving/wide), Painted Red Tow-hooks, Bed Rail System, Blind Spot Mirrors, Hitch-safe, Tail-gate lock, EAG Raptor Grille, Custom Grille Badge,Full Vinyl Wrap (Matte Black/Matte Pine Green Mettalic), Charvonia Designs Tie Bed Tie-Downs, Bull Ring Bed Rail Anchors, Line-X, Tundra Bed Mat, Bakflip F1 Bed Cover SOUND: Noico 80Mil Sound Deadening and Noico 170 Mil Thermal Insulation (All 4 Doors, Roof, Floors, Rear Panel, Dash). Hertz Uno K170's Component Speakers (Front Doors with Upgraded Sail Panels), Hertz Uno K170 Coaxial Speakers (Rear Doors), JBL C1-075ct Tweeters (Total 4) in Side Dash and Center Speaker, JBL Stadium 5 Amp w/Remote Bass Adjustment Knob and Amp Rack, 12" Infinity Reference Subwoofer in Custom Enclosure w/ “TUNDRA” Logo, Fast Rings Foam Speaker Rings System(4 Doors), Fix 86 DSP
    I read the technology page but why is this battery better than another type such as Optima, etc...? Is there something different about these ones compared to others?
  12. May 16, 2019 at 3:50 PM
    ramonortiz55
    Ramon
    anything is better than Optima these days.
    Optima isnt what it used to be
    BTBAKER, TheBeast, blizz86 and 2 others like this.
  13. May 16, 2019 at 5:53 PM
    Black Wolf Bigfoot Hunter, Sasquatch too, but not Yeti
    Aurora CO
    Yes it is. Been covered here on the forum as pretty much wives tales. "Anything is better than Optima these days" is simply not fact. North Stars are great batteries too. Good luck with GB.
    Tundyfundy likes this.
  14. May 17, 2019 at 5:58 PM
    Major
    Major TTC #0181
    Josh
    NC
    2017 CM Attitude Black Platinum
    Stock.
    Would have to reach more than 21 for it to be cheaper than HERE If we can get there then I would be in, not sure if that will happen though.
  15. May 20, 2019 at 5:45 AM
    ramonortiz55
    Ramon
    Added to the list.
  16. May 23, 2019 at 2:54 PM
    itsdchz
    itsdchz 50statesoverland
    Clovis, CA
    2018 SR5 CM Cement 4x4
    Icon, UCAs, Method, SSO, KB VOODOO, Skids and Sliders
    If the group 25 batteries were in the GB, this may help people buy 2 for the Genesis Dual Battery system.. Just sayin. As of right now, I am getting ready to order Odyssey...
  17. May 23, 2019 at 2:57 PM
    UTTundra
    UTTundra New Member
    Lou
    Utah
    Doesn't look like Northstar makes a group 25. Maybe there's a similar size?
  18. May 23, 2019 at 3:07 PM
    itsdchz
    Clovis, CA
    well... that thought is out then...
  19. May 23, 2019 at 3:10 PM
    pbcolt
    pbcolt New Member
    San Diego
    2022 SR5 TRD-OR CMSB Lunar Rock
    So dumb question - is there a way to know how much life your battery has left in it? Voltage still shows normal on the dash, but the truck is 2 years, 50k miles old.
  20. May 24, 2019 at 8:00 AM
    blizz86
    blizz86 New Member
    No way to really tell. Mine pooped out at 2 years ~35k mi
  21. May 25, 2019 at 7:31 AM
    ramonortiz55
    Ramon
  22. May 28, 2019 at 11:25 AM
    nowayout
    nowayout New Member
    NY
    17 CM
    Did you ever get an answer to this?
  23. May 28, 2019 at 11:42 AM
    Cement
    Cement ...
    No sir.
  24. May 28, 2019 at 11:58 AM
    nowayout
    nowayout New Member
    NY
    17 CM
    Cement likes this.
  25. May 28, 2019 at 12:01 PM
    nowayout
    nowayout New Member
    NY
    17 CM
    Im in for a 27F
  26. May 28, 2019 at 1:35 PM
    ramonortiz55
    Ramon
    got it!
  27. May 28, 2019 at 3:25 PM
    nowayout
    nowayout New Member
    NY
    17 CM
    @ramonortiz55 my apologies, I thought my battery that was going bad would make it till this group buy. Ends up I had to run to Napa Auto parts and get a new one 30 minutes ago. Again my apologies but I need to be removed form the buy.
  28. May 29, 2019 at 7:20 AM
    ramonortiz55
    Ramon
    yesssir, not a problem
  29. May 29, 2019 at 8:03 AM
    ramonortiz55
    Ramon
    what battery size do you want? need to finalize a count
  30. May 29, 2019 at 10:38 AM
    Major
    Major TTC #0181
    Josh
    NC
    Stock.
    27F
