Normal EGT
Discussion in '2.5 Gen TRD Pro (2014-2021)' started by Kayaking Tundra, Jan 21, 2021.
  1. Jan 21, 2021 at 6:35 PM
    Kayaking Tundra
    Kayaking Tundra [OP] New Member
    2019 White Toyota Tundra TRD PRO
    Just for pure comparisons.... whats the normal EGT of the TRD PRO? I recently bought one and the gauge is showing 1300 ish while driving.
    Curious.
  2. Jan 22, 2021 at 2:58 AM
    Bad Cow
    Bad Cow GOD Bless The USA
    Georgia USA
    2019 TRD PRO - SUPER WHITE
    Leather Steering Wheel, +1.5" Shackles
    EGT, exhaust gas temperature? What exactly are you referring to? The term EGT is normally in reference to turbo-diesel-powered vehicles. You lost me. :confused:
    Black Wolf and Haggis777 like this.
  3. Jan 22, 2021 at 3:51 AM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    I had one on my 3.4L S/C'd Tacoma for tuning. 1400°-ish was considered max safe for WOT. 1300°F sounds like it could be toward high for what I would suspect is cruising speed.
    Tangent: Tell us more about what you installed, and where in the exhaust stream you installed it....and maybe why.
  4. Jan 22, 2021 at 3:53 AM
    Bad Cow
    Georgia USA
    I guess my question is WHY would you want, or need an EGT gauge on a gasoline engine without a turbo?
    Blue Thunder, baron and Black Wolf like this.
  5. Jan 22, 2021 at 5:34 AM
    Bootleg
    Bootleg New Member
    Brandon
    2020 MGM TRD Pro
    This won't do anything to answer your question. EGT is also measured in gasoline engines with force induction (turbo, supercharger, procharger, etc.). It's not just limited to diesel engines. Why OP would need it for a normally aspirated engine makes no sense unless he is using it for baseline tuning.
    Bad Cow[QUOTED] and JohnLakeman like this.
  6. Jan 22, 2021 at 5:52 AM
    JohnLakeman
    Outside of Weird, TX
    2017 MGM DC TSS 4.6L
    Yep, when I see "EGT", I immediately flash back to the old days of my youth. In those days, drivers had to watch their EGT gauge to keep from shedding all their turbine blades in a rather dramatic fashion. :eek:
    I thought those Tundra Pros just had an ordinary 5.7L NA ICE under the hood, not one of these: :D
    https://www.youtube.com/watch?v=Oj4w7i-TqsE
    MatD13, JimboSlice413 and Bad Cow like this.
  7. Jan 22, 2021 at 9:36 AM
    JohnLakeman
    @Kayaking Tundra , if there's a member that can help you with bone-stock 5.7L exhaust gas temperature for tuning purposes, it'll probably be @ViktorG.
    Black Wolf and ColoradoTJ like this.
  8. Jan 22, 2021 at 11:41 AM
    ViktorG
    ViktorG Lexus/Toyota Master Tech
    Viktor
    Calgary, Canada
    2010 RCSB and 2008 DCLB
    World's fastest supercharged Tundra - 2010 RCSB - 10.8 @122 - All wheel drive conversion, lowered, supercharged 2008 DCLB - All wheel drive conversion, 13" lift on 37's
    How are you measuring the EGT? Do you have a dedicated sensor and gauge or is this just an estimate from the ECU read by an OBD2 scanner/app?
  9. Jan 24, 2021 at 11:40 AM
    Kayaking Tundra
    Sorry for the delay, took the truck camping this weekend to see what else I wanted to buy before the real camping and floating season gets here.
    Some back story is necessary. I recently bought this 2019 tundra trd pro. The previous owner out a lot of time and money into it. Part of all of this is a Kenwood head unit and and there are some features that show voltage, in temp, Load, Percent Throttle, and EGT among 3 or 4 other gauges.
    All I was wondering was a bench mark for future reference. I was 20 mins on the highway when I started pressing buttons and found this... thats all.
    The only thing I have planned for it eventually is a light bar and before next winter an AGM battery. But I know there are a few other things I could be talked into.
  10. Jan 24, 2021 at 1:45 PM
    ViktorG
    Viktor
    Calgary, Canada
    That is not an actual measured EGT, it is an ECU estimated catalyst temperature and is used in component over temperature protection enrichment strategy.
    Don’t worry about that number, it is not relevant to you as a consumer.
    DR132, Black Wolf, Wynnded and 2 others like this.
  11. Jan 24, 2021 at 2:15 PM
    Kayaking Tundra
    Thanks!, I was thinking something along those lines, I didnt see any performance mods, so I would know why someone needed that info.
    Thanks!!
    ViktorG likes this.
