Noob Question about Nitto Ridge Grappler
Discussion in 'Wheels & Tires' started by treihing, Jun 25, 2017.
  1. Jun 25, 2017 at 4:10 PM
    treihing
    treihing [OP] MAGA
    TR
    Washington State
    2018 Black Limited CrewMax
    Hey Fellas-
    Happy Sunday!
    I have begun my search for new tires for my 2017 Tundra and made the decision to keep the 20" Stock Wheels and have them Powder Coated black.I like to look of the various Nitto tires and really like the Ridge Grappler. Does anyone know if these will fit my truck without any modifications to my truck?
    My goals of my new tires are:
    • Less Road Noise
    • Good performance in Pacific NW Weather
    • Less tire and more wheel but still able to have fun in the mud if I ever get the balls to do it
    As you can tell, I am new to truck wheel and tire sizing so any feedback would be of great help. If you think another tire is better, I would love to hear about it.
    Thanks in advance!
    TR
    cmrock likes this.
  2. Jun 25, 2017 at 4:54 PM
    FlashCulprit
    FlashCulprit ColoradoTJ's whipping boy/Gino's illegitimate son.
    Joe
    Salt Lake City, UT
    2010 Super White SR5 TRD 5.7 4x4
    Depends on the size of the tires...
    Lots of guys like 18's cause it allows them to have more tire, less wheel, and wheels are technically cheeper at 18".
    If you stick with the 20's you'd probably be okay at 275/55.
    Tomcat, Bob, Patriot and 2 others like this.
  3. Jun 25, 2017 at 5:04 PM
    treihing
    treihing [OP] MAGA
    TR
    Washington State
    Thanks - I like the look of 275/65r20 or 295/60r20
  4. Jun 25, 2017 at 5:14 PM
    treihing
    treihing [OP] MAGA
    TR
    Washington State
    Double R (Your official new nickname) do you get any rub at all?
    NewImprovedRon likes this.
  5. Jun 25, 2017 at 5:15 PM
    treihing
    treihing [OP] MAGA
    TR
    Washington State
    Fantastic!!!
  6. Jun 25, 2017 at 5:44 PM
    Netmonkey
    Netmonkey Don't be a Dumbass
    Georgetown, TX
    2016 Texas Edition, 5.7, CM, MGM
    Icon stage 2 lift, 295 60 20 nitto ridge grapplers, fuel kranks, TRD dual exhaust, TRD rear sway bar
    295 55 20 ridge grapplers on the factory 20x9 +50mm offset wheels with the 5100's on the middle setting. Removed the front flap. No rubbing.
    NCinCO, CaptTyler, 757TUNDRA and 3 others like this.
  7. Jun 25, 2017 at 6:16 PM
    2014_platinum
    2014_platinum New Member
    Casey
    2014 Crewmax Platinum 4x4
    bilstein 5100's, diff drop
    How much room do you have between the tire and your upper control arm? I have stock platinum wheels and they're a +60 offset, just wondering if I can run 295's..
    Thanks in advance!
  8. Jun 25, 2017 at 6:22 PM
    FlashCulprit
    Joe
    Salt Lake City, UT
    295 might be a little big. But it looks like Ron has 85s sized out. :thumbsup:
  9. Jun 26, 2017 at 4:36 AM
    Netmonkey
    Georgetown, TX
    I have about a pinky width of room:
    on the 20x8 +60mm offset, a 285 might be the widest you could go.
    FlashCulprit likes this.
  10. Jun 26, 2017 at 5:30 AM
    Black Wolf INCOGNITO undercover mafia
    Aurora CO
    TuwaPro headache rack
    I've had 20" rims before but not on my Tundra. I prefer 18" rims because I like more rubber and there is usually more tire size choices with the 18" rims but that is changing too as more mfr's are constantly adding new tire sizes to their line ups. It all comes to what you want, what look, etc. Can't go wrong with Nittos either.
    zcarpenter92 and NewImprovedRon like this.
  11. Jun 26, 2017 at 5:47 AM
    benrichardson87
    benrichardson87 New Member
    Ben
    2014 Double-Cab SR5 Off-Road Silver
    I just put 275 75r18 ridge grapplers on my Tundra and love them. There is a little hum of the tires at 75-80 but they are a lot more aggressive that stock. I put the bilstein 5100 on middle setting on my truck and have not had them rub yet, if they ever will. My friend has them on a duramax and is on his 2nd set. Said they are great all around tires, he did get stuck in his field with a 24ft gooseneck trailer and 12 round bails of hay with 8inches of mud. But I wouldn't blame the tires on that.
    zcarpenter92 likes this.
  12. Jun 26, 2017 at 3:33 PM
    2014_platinum
    Casey
    I'm seriously thinking about getting some 1.25" spacers until I feel like dropping the money on wheels because I really want to run 295's or 305's .. Thanks for the help!!!
  13. Jun 26, 2017 at 3:59 PM
    Netmonkey
    Georgetown, TX
    Yeah, with spacers, you will only be able to fit 295's. the minimum wheel width for 305 ridge grapplers is 8.5". That means that you are limited the the following sizes:
    • 295 55 20
    • 295 60 20
    • 295 65 20
    The 55 series will definitely fit without a lift, but you may need to trim a little. the 60 series will require a 1.5-2.0" lift and trimming. The 65 series with require a 2.0-3.0" lift and trimming.
    Good luck :)
    Dgjman and FlashCulprit like this.
  14. Jun 28, 2017 at 11:40 AM
    JerseyTundra1260
    JerseyTundra1260 08 Silver streaking!!!!!
    Marc
    New Jersey
    08 Silver Tundra DC Limited 4x4
    Too many to list.....
    How close are you to the front plastic liner? I want to go 295/60/20 in the same tire. Running 5100's on top setting currently.
  15. Jun 28, 2017 at 12:12 PM
    Netmonkey
    Georgetown, TX
    the 295 60's are 1.18" taller than the 295 55's. so you will need an extra 0.6" of clearance from what you see in the pics below. For me, I have about 1/2" inch clearance on the front liner and I would only need a small amount of trimming to fit 295 60's. however, keep in mind that I have +50mm offset wheels. if you have a lower offset wheel (+32 for example), then you will have even less room (and will require more trimming).
    front fender liner. about 1/2" of clearance
    mud flap. about 1/2" of clearance
  16. Jun 28, 2017 at 12:14 PM
    FirstGenTundra
    FirstGenTundra R2R
    Daniel
    Wyoming
    2014 Toyota Tundra TRD
    How are the ridge grapplers road manners? I love the look of these tires but I don't want a lot of noise or poor pavement handling as 99% of my driving is on the road (unfortunately).
  17. Jun 28, 2017 at 12:20 PM
    Netmonkey
    Georgetown, TX
    These tires are awesome and handle very well. They are super quiet on the highway for what kind of tire that they are. Above 70mph, you can hear them, but it is so slight that you don't even notice it. My last tires were Mickey Thompson MTZ's and those tires slapped the pavement as they rolled. They were so fricken loud. I am glad that I have the Ridge Grapplers now.
  18. Jun 28, 2017 at 3:02 PM
    JerseyTundra1260
    Marc
    New Jersey
    Thanks I know mud flap removal and trimming are in my future. Wheels I want are +20 Fuel boost. Thanks
  19. Jun 29, 2017 at 4:25 AM
    benrichardson87
    Ben
    I like these tires 100 times better than stock in all the aspects I've has them in so far. In rain I was really surprised. They have alot of siping in the thread to help. I can only based these off the BFG KM2 I had on my Tacoma. Which are a great tire on and off the road but are a little expensive. But handling wise and they are really responsive. I have yet to have them on mud or snow.
  20. Aug 3, 2017 at 3:09 PM
    treihing
    treihing [OP] MAGA
    TR
    Washington State
    After driving on my Grapplers for a month, I have noticed no noise increase whatsoever. These are amazing tires.
    Dustydirt19 and csuviper like this.
  21. Aug 3, 2017 at 6:37 PM
    motorswin
    motorswin Back the blue
    2017 Tundra Limited TRD
    Maxtrac 3.5" lift Kmc Grenades with Cooper St Maxx 295/75/18
    I like the terra grapplers
  22. Aug 3, 2017 at 6:59 PM
    JerseyTundra1260
    Marc
    New Jersey
    Just had delivered my 20x9 Fuel boost wheels mounted on 295 /60/20 Ridge grapplers from Custom offsets :D after mount pics to come.....
  23. Aug 3, 2017 at 8:32 PM
    PMG
    PMG New Member
    Went through a monsoon tonight and they handle the wet stuff well.
  24. Aug 4, 2017 at 1:17 AM
    Dustydirt19
    Dustydirt19 Hoghead
    Dustin
    Duluth, MN
    2015 Blue Ribbon Metallic 5.7L 4WD SR5 TRD DC
    ProComp 6" stage 2 lift 18x9 Fuel Vapor -12 offset 35x12.5 Nitto Ridge Grapplers BullyDog Tuner Gibson Metal Mulisha cat-back exhaust, S&B cold air intake, Color matched TRD PRO Grille, Compustar Remote Start N-Fab Hooped Nerf Bars, AMI Big stick antenna, Salex organizer and tray, Weathertech laser cut floor mats, Weathertech window deflectors Black out badge Black out front and rear bumper Black out flags 24/7 black out TRD Off-road decals Spray in Line-X Bedliner Scosche phone mount Soft rolling tonneau cover TRD pedals and footrest
    I've got 35" ridge Grapplers myself and i love em hardly any highway noise
  25. Aug 4, 2017 at 10:17 AM
    JerseyTundra1260
    Marc
    New Jersey
    Utt ohh........ :bananadance:
    Dgjman, csuviper, Newm and 3 others like this.
  26. Aug 4, 2017 at 1:21 PM
    JerseyTundra1260
    Marc
    New Jersey
    Time for a change.... And some trimming :annoyed:
    Dgjman and benrichardson87 like this.
  27. Aug 4, 2017 at 1:31 PM
    Boondoc89
    Boondoc89 Shit happens when you party naked
    Doc
    '17 mgm DC TRD 4x4
    No mods
    It'll be worth it!! I've got a set of 35's on my jeep and I just rotated them for the first time. They are still very quiet. They do make just slightly more noise now but really it's nowhere near as bad as your run of the mill M/T.
    JerseyTundra1260 likes this.
  28. Aug 5, 2017 at 5:25 PM
    trikebubble
    trikebubble New Member
    2014 Tundra TRD Off Road DC
    I ordered a set of 295 70R 18's and new wheels last week from Discount Tire. I had actually picked another tire, but was talking to Mathew at MCM Fabrication and he suggested either Nitto's or Toyo's based on his experiences.
    Eclipsed & Floating likes this.
  29. Aug 5, 2017 at 7:04 PM
    757TUNDRA
    757TUNDRA Not a New Member
    Illinois
    2018 Barcelona Red Metallic Platinum 4x4
    OEM Bed Cover, OEM Bed Rail System, OEM Bedmat, OEM Doorsill Protectors, OEM TRD Rear Sway Bar, OEM Color Matched Door Handles, OEM Color Matched Mirror Caps, OEM Bed Net, OEM Driver Side Grab Handle, BFG K02 LT275/60/20, WeatherTech Digifit FloorLiners, Salex OCD Console Organizer, Salex Console Tray
    Love my Ridge Grapplers so far. They are a lot quieter then I thought they would be.
    4x4_Angel and benrichardson87 like this.
  30. Aug 5, 2017 at 7:06 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    Making me so jellous. Might have to pull the trigger soon
    4x4_Angel likes this.
