No TPMS for snows
Discussion in 'Wheels & Tires' started by Camp60, May 25, 2020.
New to Tundras. Any issues if using a set of rims without tpms sensors just for winter use?
  1. TPMS
    1 vote(s)
    100.0%
  2. tpms
    0 vote(s)
    0.0%
Multiple votes are allowed.
  1. May 25, 2020 at 5:53 AM
    Camp60
    Camp60 [OP] New Member
    Dave
    2020 Tundra
  2. May 25, 2020 at 8:35 AM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    2015 MGM Limited 2x4 Sequoia
    Nope. Bolt them on and go. Just ignore the stupid idiot light.
    Sleeper16plat likes this.
  3. May 25, 2020 at 8:41 AM
    bleach
    bleach MEME Fiend
    DJ
    Battle Ground, WA
    1991Toyota Xtra-cab SR5 4X4 V6 5 speed 157K
    Like he said. It won't hurt anything.
  4. May 25, 2020 at 5:43 PM
    Camp60
    Dave
    2020 Tundra
    Thank you.
  5. May 25, 2020 at 5:48 PM
    Rex Kramer
    Rex Kramer Vinyl Spinner
    Georgia
    I dumped the sensors in all of my wheels... the little light stops flashing in about 90 seconds.
  6. May 25, 2020 at 5:53 PM
    Zebruaj
    Zebruaj New Member
    MN
    08 CM SR5
    I'm ghetto. I have a piece of electrical tape over the dummy light.
    One sensor was seized doing a wheel swap. Just went with regular rubber valve stems.
  7. May 25, 2020 at 5:58 PM
    bleach
    bleach MEME Fiend
    DJ
    Battle Ground, WA
    I think TPMS is not worth the trouble they eventually cause. The only start to give you a low pressure warning only after they're obviously low. Any observant driver could notice they have a low tire before the sensors kick in. They also add an unnecessary expense when their batteries go bad.
    Rex Kramer likes this.
  8. May 25, 2020 at 7:26 PM
    BENWALES
    BENWALES New Member
    Ben
    2020 Tundra White SR5
    There are a few alternatives that can be cloned to your existing sensors if you’re interested.
  9. May 26, 2020 at 3:17 AM
    Camp60
    Dave
    2020 Tundra
    I appreciate the info. Going without sensors for winter tires. I can deal with an idiot light.
  10. May 26, 2020 at 4:10 AM
    phabej
    phabej New Member
    Washington
    2018 Platnium
    In my older cars I use to take the gauge unit out and remove the bulb. Lol not sure how way a tundra is.
  11. Apr 14, 2021 at 6:09 AM
    cdavi060
    cdavi060 New Member
    Virginia Beach, VA
    2017 Super White Tundra Platinum CM
    285/70r18 NITTO RG | Method NV 18x9 | Bilstein 6112 @2.5" w/CB shims, SPC UCA, 5100 & CB +3 Shackles | Entune 3.0 Swap | 2018+ Platinum grille + Pro LED Headlights
    I am planning on switching over TPMS from my stock 20in tires to aftermarket Method wheels a week or two ahead of installing my lift. Will everything go back to working as normal once the lift is installed and the method wheels with the TMPS sensors are on the truck? Even after sitting off the truck for a week or two?
  12. Apr 14, 2021 at 7:34 AM
    Yes they should since they are the same sensors.
