No start tundra 2017 with 5.7 liter
Discussion in 'New Member Introductions' started by Fuelpot2017, Mar 29, 2023.
  1. Mar 29, 2023 at 6:29 AM
    Fuelpot2017
    Fuelpot2017 [OP] New Member
    2017 Tundra,4X4,SR5
    Tow package, v8
    2017 tundra no start first of day. Just cranks. When it starts it is good all day long.
  2. Mar 29, 2023 at 6:52 AM
    2mchfun
    Seems like a fuel pump/pressure/strainer issue. I'm guessing that the fuel supply pressure is bleeding off overnight and taking a long time to build enough pressure to get going in the morning. You should probably do a fuel pressure test first thing in the morning and see what that delivers. These trucks have a variable speed fuel pump that is controlled by a module mounted on the frame near the tank. If you hit the air intake with a burst of starting fluid and it starts and then dies when you stop it simply don't have enough fuel. Curious, what is the odometer reading? What is the fuel guage reading?
  3. Mar 29, 2023 at 7:24 AM
    CTundraForMe
    CTundraForMe New Member
    FFV or non FFV?
  4. Mar 29, 2023 at 8:06 AM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
  5. Mar 29, 2023 at 8:22 AM
    Blueknights75
    Ron
    Clayton, NC
    Welcome from NC!
  6. Mar 30, 2023 at 9:38 PM
    Fuelpot2017
    2017 Tundra,4X4,SR5
    Tow package, v8
    I thought there is a service bulletin that covers replacement through Toyota?
  7. Mar 30, 2023 at 9:48 PM
    fuelpot2023
    fuelpot2023 New Member
    Edward
    2017 White SR5, TRD Pro
    Heavy towing Package
    It is not FlexFuel equipped and I have a 38 gallon tank.
  8. Mar 31, 2023 at 4:32 AM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
  9. Apr 1, 2023 at 7:48 AM
    2mchfun
    Not sure, but I think that might be for flex fuel only trucks. Something to do with them getting confused as it pertains to alcohol percentage levels in the fuel or similar. Another thing is you may have a weak battery, these trucks are known to do funny things when the batteries become weak. I mostly doubt it, but maybe.
  10. Apr 11, 2023 at 5:29 AM
    RitcheyRch
    RitcheyRch New Member
    Richard
    Santa Clarita, CA
    TRD Lowered and Supercharged
    Welcome from So Cal
