No range on 2014 1794 key fob.
Discussion in '2.5 Gen Tundras (2014-2021)' started by wspearce3, Jun 20, 2017.
  1. Jun 20, 2017 at 4:32 AM
    wspearce3
    wspearce3 [OP] New Member
    Will
    2014 Black Tundra 1794
    I can be about 10' away and the lock/unlock doesn't work. This happens on both of my fobs with brand new batteries. Anyone else having this issue?
  2. Jun 20, 2017 at 6:34 AM
    Nothing here. Does it occur only at 10' away from multiple locations? Just to eliminate the possibility of it being so sort of electrical interference.
  3. Jun 20, 2017 at 6:40 AM
    Patriot
    Patriot Member
    Western NC, “Boondocks”
    I have not had this issue. And this is the first time I have heard of it. There has to be a solution.
  4. Jun 20, 2017 at 6:50 AM
    Patriot
    Patriot Member
    T-Rex266 likes this.
  5. Jun 20, 2017 at 8:23 AM
    wspearce3
    Will
    Yes multiple locations. It's consistently bad and interment. The thing is is that it happens with both key fobs so I don't believe it's the key fobs that are the issue.
  6. Jun 20, 2017 at 8:24 AM
    wspearce3
    Will
  7. Jun 21, 2017 at 1:02 PM
    JH5370
    JH5370 Member
    Josh
    Eastern WA
    2017 White DC TRD PRO
    Mine works from down the block.
    I had the same issue with an old car I had and it was the batteries in the remote. Have you tried fresh batteries?
  8. Jun 21, 2017 at 1:27 PM
    wspearce3
    Will
    I sure have. I put fresh batteries in both fobs. Exact same range on both even with new batteries.
  9. Jun 21, 2017 at 1:43 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 Long Travel DC
    Mine works from atleast 50' away. Maybe you bought bad batteries? Only explanation if it's both fobs.
  10. Jun 21, 2017 at 2:07 PM
    JH5370
    JH5370 Member
    Josh
    Eastern WA
    The hokey solution is to put the key fob to the underside of you chin when using it. Effectively turns your body into an antenna to extend the range. Seems stupid but it works haha
    https://m.youtube.com/watch?feature=youtu.be&v=_jACSPipPSE
    Tundracollector likes this.
  11. Jun 21, 2017 at 2:14 PM
    15whtrd
    15whtrd Mr. Blonde
    I wonder if there is some type of receiver or antenna under the dash or hood somewhere? Maybe it's not connected if there is one.
  12. Jun 21, 2017 at 2:16 PM
    JH5370
    JH5370 Member
    Josh
    Eastern WA
    That's what I'm thinking too. It's got to be some kind of interference.
    @wspearce3
    Do you have any aftermarket electrical stuff on your truck? Sub wires, amps, etc?
    15whtrd[QUOTED] likes this.
  13. Jun 21, 2017 at 2:16 PM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    Easy...slap on some of these babies...problem solved!
    15whtrd and JH5370 like this.
  14. Jun 21, 2017 at 2:26 PM
    wspearce3
    Will
    No aftermarket electrical stuff as far as I know. Everything seems to be stock. I got the truck used in really good condition.
  15. Jun 21, 2017 at 2:27 PM
    wspearce3
    Will
    That's what I'm thinking it has to be. This would make the most sense. I have no idea where to start looking for this antenna.
  16. Jun 21, 2017 at 2:30 PM
    Tundra Fan
    Tundra Fan Got 17's?
    Toby
    Nor Cal (Placer Co.)
    Mine too, thats why I'm hesitant to change my fob. I like the AJT one , but my remote start works through buildings from decently far away right now. I really don't want to lose that.
    I'm wondering as well if there is some sort of antenna on the truck that receives the signal, and the OP's isn't working. My old car was like that after I switched remotes and it was frustrating.
