Nitto Trail Grapplers Tripping the Traction Control Per Toyota Dealership
Discussion in '2nd Gen Tundras (2007-2013)' started by CaptainJohnnySR5, Jul 5, 2018.
  1. Jul 7, 2018 at 2:27 PM
    #61
    the_midwesterner
    the_midwesterner New Member
    Luis
    None, yet....
    If swapping to stock solves your problem, then you have a tire issue. If the problem persists and they can recreate the effect seen by the tech stream data, you have an issue with the Hall effect sensors reading, the sensors themselves, or possibly debris in the reluctor rings giving false readings.
    Good to hear the tire guy is willing to help.
    CaptainJohnnySR5[OP] likes this.
  2. Jul 7, 2018 at 2:30 PM
    #62
    Rica25
    Ricardo
    Tulare
    I swap Toyo at2s for same size with in the first week for VSC going off and didn't help now that I went even bigger after 3 months only made thing a little worse but I have to say that the looks of it pays off I just have to slow down when going on the on ramps
  3. Jul 7, 2018 at 2:55 PM
    #63
    Black Wolf Bigfoot Hunter, Sasquatch too, but not Yeti
    Aurora CO
    I forgot about the ABS reluctor rings. I've seen some pulled off and were mis-shapened due to crud buildup. Caused all sorts of problems but didn't cause limp mode if I recall correctly. (Not that it can't) This whole limp mode thing just plain sucks.
  4. Jul 7, 2018 at 2:57 PM
    #64
    Aurora CO
    This is good news....
  5. Jul 23, 2018 at 11:15 AM
    #65
    IndyTundra
    IndyTundra Did someone say beer?
    Ronnie
    Indianapolis, IN
    2015 Radiant Red SR5 CM TRD
    Toytec, 34" Ridge Grapplers, MBRP Exhaust, Linex'd TRD Pro grill
    Any update on the tire issue? Did swapping the tires fix the problem?
  6. Jul 23, 2018 at 2:38 PM
    #66
    CaptainJohnnySR5
    CaptainJohnnySR5 [OP] Tundra Lifer Now!
    Capt Johnny
    Winter Garden Fl
    2012 Silver Tundra 5.7 SR5 2WD DC TRD Upgraded. 2017 SR5 TSS Off Road 4x4 DC Blazing Blue. 2019 1794 White TRD Off Road 4x4 CM
    I am totally addicted to Tundra Life now!
    I will update tonight.
    Black Wolf likes this.
  7. Jul 23, 2018 at 3:14 PM
    #67
    Aurora CO
    :popcorn:
  8. Jul 23, 2018 at 3:26 PM
    #68
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 Long Travel DC
    Sounds very similar to what Joe Shaker went through. I can't find him nor that thread. Did he delete his account? Do you know @Grey Wolf ?
    GNTundra likes this.
  9. Aug 7, 2018 at 6:45 PM
    #69
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    Lies!
  10. Aug 7, 2018 at 6:46 PM
    #70
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    joonbug[QUOTED] likes this.
  11. Aug 7, 2018 at 8:49 PM
    #71
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
    FWIW I run between 30/35 on my load range E....and I feel that's too high
  12. Aug 8, 2018 at 3:51 AM
    #72
    SgtNewundies
    SgtNewundies New Member
    Eric
    I am now running 38 in front 34 in the rear. I was at 36 in front and it appeared to need a little more wear in the center so I upped the pressure.
  13. Aug 8, 2018 at 8:08 AM
    #73
    IndyTundra
    Ronnie
    Indianapolis, IN
    Was there ever a resolution to JoeShaker's problem? I read through both of his threads and never noticed one. Nitto Exo or Ridge Grapplers are on my list of tires I'd like to get later this year, but now I am a little hesitant. 2 members having similar traction control issues and both with Nitto seems weird.
  14. Aug 8, 2018 at 9:21 AM
    #74
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    Nitto Tires and no updates with resolutions seem to be the common things here, don’t they?
    IndyTundra[QUOTED] likes this.
  15. Aug 8, 2018 at 3:58 PM
    #75
    CaptainJohnnySR5
    Capt Johnny
    Winter Garden Fl
    Update: I still have the same issue. I removed the Bullydog Tuner from the truck and the issue stopped. I had the performance tune on it set on Perf Shift, Perf throttle, unlimited speed and it tripped it every time. Took it out (BDT) of the truck and it went away. Re installed it removing 1 performance setting at a time and still tripped it. Did all this with BullDog TS on the phone. So they made a full report and sent it to the engineers. Its been 3 weeks and I have not heard a word from them.
    So I still have it installed and I have to disable the nannies every key cycle and that blows. Im not sure if its the power increase lifting the front of the truck when taking off or the wheels breaking loose. Sorry for the delay in updating guys Ive been very busy at my shop.
    JMB, Albertaundra and landphil like this.
  16. Aug 8, 2018 at 4:28 PM
    #76
    IndyTundra
    Ronnie
    Indianapolis, IN
    That sucks. Just to be clear, the truck still had issues with the Bully Dog and stock sized tires or is it just with the Nittos?
  17. Aug 8, 2018 at 5:01 PM
    #77
    Jengel451
    Jengel451 Misanthropist
    The Bitterroot, MT
    2017 Barcelona TRD Limited CrewMax
    3/1.5 Toytec/Icon AAL, 17" Rebounds, 317-70-70 ST Maxx's
    I guess the bullydog is the problem. Not the tires or the truck. Easy fix. Not sure how I missed you having a tune in it.
  18. Aug 8, 2018 at 5:12 PM
    #78
    Albertaundra
    Albertaundra aka...IgnorantlyAlberta
    David
    '16 SR5 crewmax TRD, '06 Taco walletbreaker
    Bone stock tundra...
    Subbd cause I read the whole damn thread
  19. Aug 8, 2018 at 5:21 PM
    #79
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    Interesting that @Joeshaker also had a bullydog tuner involved, at least partway though his ordeal.
  20. Aug 9, 2018 at 7:06 PM
    #80
    tigerpaw
    tigerpaw New Member
    Louisiana
    Grey Tundra 4x4 no mod's
    I'm running 285's on the front and 305's on the rear both BFG T/A KO's traction control lights up some times and slow down truck then when I back out of it light goes out and returns to normal. It's 4x4 but the selector will not engage so can't use 4x4 anyway. What will be the mechanical failings of this set-up. Will it damage transmission or transfer case.
