New Tundra, need help
Discussion in 'Suspension' started by Kwc2210, Oct 16, 2019.
  1. Oct 16, 2019 at 5:03 PM
    Kwc2210
    Kwc2210 [OP] New Member
    2014 white SR5
    Leveled, bags, 295/70/18
    Hey guys, still new to the Tundra world. I’ve had my 2014 SR5 for about two months. Can anyone help me with the leveling kit I have, UCA spacing and possible next tire size I can fit. Currently running 275/70/18 but would like to go to 285 or possibly 295. I’m used to doing the work myself and also not dealing with the UCA closeness. Thanks in advance.
  2. Oct 17, 2019 at 7:04 AM
    Toytec Lifts
    Toytec Lifts New Member
    Denver, CO.
    Good morning and welcome to the forum!! Good looking Tundra!
    So its hard to tell exactly how much of a lift you have (take a ride height measurement from center of wheel hub to edge of fender in all 4 corners that will tell us what your height is).
    But the brand can be a hand full of different companies overall such as Revtek, Procomp, BDS, etc..
    For wheel clearance wise on the upper control arm, that is a really simple fix by adding on a set of Spidertrax wheel spacers that will be a hub centric bolt on style wheel spacer. The spacer is a 1.25'' thick spacer that will push out the wheel/ tire away from the upper control arm to help insure you get the proper clearance. Or you can do an aftermarket wheel with more aggressive backspacing/ offset.
    Here is a link to the wheel spacers: Take those measurements and lets see what you are working with height wise!!!
    If you have any questions, please don't hesitate to give us a ring at 303-255-4959!
    -David
