New head unit
Discussion in 'Audio & Video' started by Mike Haines, Dec 23, 2019.
  1. Dec 23, 2019 at 7:33 AM
    Mike Haines
    Mike Haines [OP] New Member
    2017 Black TRD DC
    I was looking to change my head unit and eventually speakers and factory amp. My question is should I bypass the amp for now and power just off the head unit or leave in place until I change the amp. Thanks Mike
  2. Dec 23, 2019 at 7:57 AM
    bsavoir
    bsavoir New Member
    Killeen, TX
    2016 Tundra Limited CM 4x4
    Gibson Metal Mulisha Exhaust, Replaced bulbs w/ LED's, AFe intake, Bullydog Tuner, Aftermarket Audio system, Rhino Bed Light sports bar, Tonneau Cover, Spyder Auto Headlights and Taillights, Recon 3rd Brake Light, Kensun HID's, Fender Flares, Custom Leather Interior, Heated Seats, 5% Tint on the Rear Windows, Pod light Foglights, 31" light bar behind the grille, linex spray bedliner, linex sprayed grille, ditch lights w/ dual 3in LED pods, 60" Tailgate LED strip.
    I would just leave the amp hooked up until you get the new one and speakers. The stock radio only powers the dash speakers and the amp does the doors. You might have some issues trying to power the dash speakers and and the door speaker without the amp. I got a Tesla unit and had the stock speakers and amp and the sound is way better, just finished my ********* 4ch and mono amp install.
  3. Dec 23, 2019 at 8:10 AM
    Mike Haines
    2017 Black TRD DC
    I’m looking at the alpine ilx-f309tnd
  4. Dec 23, 2019 at 8:30 AM
    bsavoir
    bsavoir New Member
    Killeen, TX
    I would keep the stock amp hooked up. The rear door speakers in my 2016 CM were 35w @ 2ohms not sure of the fronts. The sound quality might be hindered if you bypass the amp. Like I said, the stock headunit sucks for sound, upgrading to an aftermarket will be an improvement.
    These are the output specs for the alpine.
    • Built-in internal amp: 18 watts RMS CTA-2006 (50 peak) x 4 channels
  5. Dec 23, 2019 at 8:36 AM
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    Yep, like @bsavoir said, keep the amp in place until you replace the speakers. At that point, you can either bypass the amp with the ********* or similar harness or go with an aftermarket amp if your speakers could use the extra power. I put JBL components at all 4 corners and just bypassed the amp. My Pioneer has more than enough power to push those, so I'm good. Your mileage may vary depending on how much of an audiophile you are. Either way, dumping the stock head unit nets some major audio quality improvement.
  6. Dec 23, 2019 at 8:55 AM
    Mike Haines
    2017 Black TRD DC
    Thanks for the replies I will let you know which one I go with
  7. Jan 2, 2020 at 6:38 PM
    RitcheyRch
    RitcheyRch New Member
    Richard
    Santa Clarita, CA
    TRD Lowered and Supercharged
    That's a nice system.
  8. Jan 2, 2020 at 6:51 PM
    Rocman
    Rocman New Member
    Randall
    Reno, NV
    2019 Tundra Platinum
    I've been thinking about switching out to the T style too. My only issue is that I'm not finding anything that has built in SiriusXM.
