New Exhaust System
Discussion in 'Performance and Tuning' started by reywcms, Jan 27, 2024.
  1. Oct 10, 2025 at 2:05 PM
    #871
    Oz_zy
    Oz_zy Member
    2016 magnetic grey tundra tss off-road
    Morimoto headlights+tailights +3rd brake light Morimoto xb led fog light Db custom tundra grill with led 3 inch lift with elka 2.5 ifp suspension with bds uca. Jba lth with full 3 inch midpipes w/factory cats along with full 3 inch true dual stainless steel exhaust with x pipe with 2 corsa pro series mufflers And s&b intake
    What is yalls return policy
  2. Oct 10, 2025 at 2:07 PM
    #872
    reywcms
    reywcms [OP] New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
  3. Oct 10, 2025 at 2:50 PM
    #873
    ThatGuyTheCooler
    ThatGuyTheCooler New Member
    PA
    I'm still waiting for that black Friday sale lol
  4. Oct 10, 2025 at 6:56 PM
    #874
    Oz_zy
    Oz_zy Member
    As far as of i order the exhaust and i dont like the sound and stuff
  5. Oct 10, 2025 at 7:11 PM
    #875
    Ryuu
    Ryuu potato
    Oscar
    SouthEast, TX
    2017 TRD PRO Barcelona Red
    See signature
    don't think spd would sell the the "S" piece they use but a pre-fabbed equalizer loop could also be an option too if you already welded up your own exhaust. think someone here is running one on their custom exhaust and they don't seem too expensive
    Saltyhero13 and reywcms[OP] like this.
  6. Oct 10, 2025 at 8:00 PM
    #876
    centex
    centex New Member
    Call and ask.
  7. Oct 10, 2025 at 8:24 PM
    #877
    reywcms
    Rey
    North Plains,Oregon
    Don’t think they’d take it back. Not many companies would after installing something.
  8. Oct 10, 2025 at 8:27 PM
    #878
    Oz_zy
    Oz_zy Member
    I was also thinking of just ordering it to get the dimensions off the loop pipe and then return it without installing the exhaust
  9. Oct 10, 2025 at 8:28 PM
    #879
    reywcms
    Rey
    North Plains,Oregon
    You could order a loop pipe like mentioned above for less trouble for both you and Spd.
    Mdl and PolishedTRD like this.
  10. Oct 10, 2025 at 9:17 PM
    #880
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    JBA 1 7/8 Longtubes, Snivs 1.88 SC pulley, ASP crank overdrive pulley 6.71 in, DD Full 3inch dual exhaust, IPT Trans/valve body, 4.5inch intake with 10x2 SABM, FIC 880/930cc injectors, 450 Walbro, Direct Port W/M injection, GM 95mm TB, DW fuel regulator, E-fan, Remote engine air/oil cooler, Camburg UCA, Icon shocks, Speedmaster LSD, Motive 5.29 Gears, Mickey Thompson Baja Legend EXP 35's, Solid Offroad engine and transmission mounts, DIY Traction Bars, Tuning by Snivspeedshop.com
    Any good exhaust shop can fabricate the s section. And you can do an axle dump with a hemholtz resonators after the muffler for drone. Keith at dirty deeds has done some hemholts res's for the spd.
  11. Oct 20, 2025 at 10:08 AM
    #881
    Torque
    Torque New Member
    Ft Collins, CO
    2016 DC TRD 4x4
    Agri-Cover,RCI skid,ADARAC,Fox 2.0,TruDuals
    Two U pipes and a couple of 30deg or 45deg elbows with 2-4" legs is what you need to make a loop like above. The offset using the elbows to get the loop back onto the same plane as the passenger side will be dependent on how your custom 3" system is designed. I made the loop on my system using 2.5" tubing.
    FWIW, I'm going to be pulling my system off and putting stock back on again in a few weeks (like I did last Winter) because when the temps drop and stay around freezing, the resonance is horrible on my commute to work. I never got around to building the resonators because life. But over the Winter I'm going to cut out the X pipe and add a Y so I can attach it to the stock tailpipe. Hoping that will cut down on resonance so I can run it year around. I do love the sound and clean appearance without the tailpipe though.
    ZPhilip likes this.
  12. Oct 31, 2025 at 7:18 PM
    #882
    Oz_zy
    Oz_zy Member
    Of i were to get this would it go on the passenger or driver side?
  13. Oct 31, 2025 at 7:25 PM
    #883
    reywcms
    Rey
    North Plains,Oregon
    Reference page one.. passenger side
    blenton likes this.
  14. Oct 31, 2025 at 7:27 PM
    #884
    blenton
    blenton New Member
    Passenger side. The exhaust exits on passenger side, so the driver side has longer to travel; the s bend is to add length to the passenger side to make them equal length.
    ..like rey said.
    bflooks and reywcms[OP] like this.
  15. Oct 31, 2025 at 7:28 PM
    #885
    Oz_zy
    Oz_zy Member
    Thanks I honestly didn't even think of going to your first post and look
    reywcms[QUOTED][OP] likes this.
  16. Nov 24, 2025 at 7:51 PM
    #886
    Toe404
    Toe404 just a poser
    Tomas
    Bay Area, CA
    '21 Cavalry TRD Sport CM Tundra & 25 TRD Pro Sequoia
    Keep waiting for someone to steal my cats so I can replace them with the SPD high flow’s
    Silver17 and reywcms[OP] like this.
  17. Nov 24, 2025 at 8:11 PM
    #887
    VWTim
    VWTim Mid-Travel Crew
    Corvallis, OR
    HA! Now that I'm not living out of state, I pulled the cat guards off my RCI skid plate; halfway hoping the same...
    Silver17 likes this.
  18. Nov 25, 2025 at 5:28 AM
    #888
    Chad D.
    Chad D. New Member
    Western Oregon
    2018 CrewMax Platinum
    Is cat theft still a thing? Seems like it died off in my area. Maybe I’m just not hip enough to hear about it anymore…
  19. Nov 25, 2025 at 5:31 AM
    #889
    Silver17
    Northeast
    2026 Chevy 2500HD L8T 2017 Toyota Sequoia Limited
    Buy the SPDs, then sell your stock ones to someone in need of some, or a scrap yard to pay for them. :gossip:
  20. Nov 25, 2025 at 5:34 AM
    #890
    reywcms
    Rey
    North Plains,Oregon
    What’s everyone’s address I’ll come by in the middle of the night with a hacksaw lol
    Toe404 and Silver17 like this.
  21. Feb 1, 2026 at 2:07 PM
    #891
    ZPhilip
    ZPhilip Custom title here
    Philip
    West Chester, PA
    2015 Platinum Super White Crewmax
    Harrop supercharger, TRD Pro Fox suspension, CB +1 shackles, 295/70-18 Toyo ATIII, TRD Pro forged rims
    Any upcoming sales?
    Or does anyone want to sell me their downpipes?
  22. Feb 1, 2026 at 2:17 PM
    #892
    reywcms
    Rey
    North Plains,Oregon
    They don’t typically do sales since the price is already a good deal.
  23. Feb 1, 2026 at 2:38 PM
    #893
    ThatGuyTheCooler
    PA
    I am going to sell my 8" BAM and go SPD. Just need to find a buyer
    reywcms[OP] likes this.
  24. Feb 24, 2026 at 2:27 AM
    #894
    ThatGuyTheCooler
    PA
    SPD exhaust will ship this week. I look forward to comparing the two and will do a write-up with my thoughts. I also noticed the price went up +$100 right after my order.
    easleycrawler and reywcms[OP] like this.
  25. Mar 6, 2026 at 2:33 PM
    #895
    easleycrawler
    Travis
    Easley, South Carolina
    2020 Limited DC 4X4 CEMENT
    Any updates?
  26. Mar 6, 2026 at 3:00 PM
    #896
    ThatGuyTheCooler
    PA
    After multiple calls, it finally shipped after 1 month. SPD kept giving me different answers or just not calling me back. Expected delivery Wednesday. Unless its obnoxious, I'm pretty sure I'll be keeping the SPD and selling the DD 8"
    easleycrawler[QUOTED] likes this.
  27. Mar 6, 2026 at 3:48 PM
    #897
    easleycrawler
    Travis
    Hate runarounds like that. Hopefully thays not a normal business. I really like the sound and am seriously considering getting. Appreciate the update.
  28. Mar 6, 2026 at 3:56 PM
    #898
    reywcms
    Rey
    North Plains,Oregon
    It’s not normal
    easleycrawler likes this.
  29. Mar 6, 2026 at 3:57 PM
    #899
    easleycrawler
    Travis
    Good to know. :thumbsup:
  30. Mar 6, 2026 at 6:26 PM
    #900
    centex
    centex New Member
    Wasn’t my experience at all. Shipped next day from order. Sorry that happened. I’m still completely satisfied with mine.
    easleycrawler and RobertD like this.
